    Podium V2 interior
    72 Posts 24 Posters 13.0k Views 24 Watching
    • david_hD Offline
      david_h
      just show some light coming out of that fixture over the island, and you've got a winner there.
        congellous
        Nice work, 36 mins what are you running on ?
        The floor looks nice is that lots of tweaking, can you give us a run down of how you got to this quality.
          sepo
          looks good....really like the atmo.
          • david_hD Offline
            david_h
            The wall opposite the island looks like it could use a cool piece of art.
            • StinkieS Offline
              Stinkie
              I was thinking the same thing, although I'd possibly opt for 4 or 5 equally sized works rather than one big one. I suspect that would work best.
              I should also up the lamp's polygon count.
              • StinkieS Offline
                Stinkie
                Thanks, lads.
                David -yes, I should do that, shouldn't I? I'm quite keen to find out what Podium light would work best in this case.
                Congellous -I'm using a 4 or 5 year old Mac Pro. The floor is a mat from Podium's Component Browser. Podium's mats are pretty straightforward. There's reflection, bump, and a blur tickbox. That's it. There's some stuff on mats over at http://www.suplugins.com. Pretty much all you need to know.
                After the render finished, I took it into Photoshop, lowered the saturation of the yellows and the reds, added a curves layer, sharpened the image up using the high pass filter, did some manual blurring, and added a blueish cast to the right of the image. Then I downsampled it.
                If I remember correctly. My postprocessing tends to be capricious rather than methodical. 😎
                • N Offline
                  notareal
                  New one. Tad too gloomy, me thinks...
                  I like the atmosphere!
                  • StinkieS Offline
                    Stinkie
                    I could do a version with Thea ... if there were interior rendering presets available to pick apart. πŸ’š
                    • N Offline
                      notareal
                      For biased rendering? I'd start from "04. Final Gathering" preset and improve quality if needed. Or perhaps new Adaptive (AMC) from interactive renderer, as it's fairly fast if bias is set high (also enable caustics for better light).
                      • StinkieS Offline
                        Stinkie
                        Hm, I'll try that. Thea's biased engine is still somewhat of a mystery to me. πŸ˜„
                        • N Offline
                          notareal
                          You could try this Adaptive (BSD) -preset. Save in "C:\ProgramData\Thea Render\Presets" in Win7. If it feels too slow, downgrade settings towards "04. Final Gathering" -preset. Also you can disable or tune down "Ambient Occlusion" under Render | Biased RT, if it disturbs.
                          Also some material tuning may be needed. Under material general, set Perceptual Level(%) to 10,000 if your material has textures (higher will give better quality but difference is small as textures do hide imperfections) also if you have glossy materials you can set they Tracing Depth to 8-12 (if some black areas appear as result of too low tracing depth).
                          Final Gathering Interior.zip
                          • soloS Offline
                            Tom
                            Can you share the model? I'd like to play with Thea's biased engine to see what speeds I can get...when I get the time.
                            • StinkieS Offline
                              Stinkie
                              Pentti -thanks!
                              Pete -of course. Tomorrow, after I've dropped of Wee Satan at school. I'll have to take the wall and floor textures out, though -they're from the non-free section of the Podium Component Browser. Did I notice familiar looking plants in there, btw?
                              In the meantime, here's a version with the lamp switched on.
                              • stefanqS Offline
                                stefanq
                                Looks fantastic Tom. As for the "art on the wall" you can use your own prints.
                                • StinkieS Offline
                                  Stinkie
                                  I tried that. Looked "meh". πŸ˜„ So ... it's done. 😎
                                  • soloS Offline
                                    Tom,
                                    Firstly thanks for pm'ing me the .skp, Notareal sent me the link to the original model here: http://www.3dallusions.com/Site/Vault/ArchModels/Kitchen_SKP.zip which by the way is horrible as it is totally out of proportion, off axis and spends way more poly's than it needs, yours is nicely optimised...thank you.
                                    On opening yours I noticed your setup, which I believe is way more relevant than any render preset/setup. You have used L.E.M's in order to mimic exterior light as well as one to give light behind the camera.
                                    I was instantly reminded of my days with Podium 1 and remember this being the best way to get soft shadows and good even lighting, however I wondered if this was the fastest way (I cannot remember) did or does LEM's come at a speed cost?
                                    Does Podium 2 have HDRI support? as I was wondering if deleting the exterior LEM and using Image based lightning would not be faster with even better soft lighting?
                                    I'm assuming the LEM behind the camera is to assist and give some light volume as without it all surfaces facing camera would be black, however I am wondering if there was a way of using ISO, shutter speed and f-number settings to enhance lighting without the need for the LEM?
                                    What my rambling is about is the setup of scene may actually be just as if not more important than the actual render settings.
                                    • david_hD Offline
                                      david_h
                                      On second thought. . .I like it this way. It has a very monastic feel to it. A sort of hypo-Tech Austerity that I find appealing. I think putting a big Andy Warhol or worse a Patrick Nagel 🀒 on the wall would be a bit of a cliche.
                                      • michaliszissiouM Offline
                                        michaliszissiou
                                        If two chairs and two apples, then loneliness could be more obvious. 😎
                                        Three chairs? three apples? We all are Stanley Kubrick's funs, aren't we?
                                        This is a "strong" image. Well done.
                                        It's the Ps work that I don't like much. A fake-volumetric effect could turn the scene to a more dramatical way.
                                          Who lives here ? Mystery is complete! πŸ˜„
                                          • marked001M Offline
                                            marked001
                                            beautiful stuff!
                                            http://www.revision21vis.com
                                            instagram: revi21on
                                            • 3 / 4
