    Podium V2 interior
    72 Posts 24 Posters 13.0k Views 24 Watching
    • StinkieS Offline
      Stinkie
      I find it still resembles a game engine.
      I've checked out their gallery today, and I feel the same. The quality of the output doesn't compare to Podium's, let alone Vray's or Maxwell's. (I imagine that's not the developers' main concern, either.) Interesting app, but as I said ... apples, oranges.
        dbalex
        great render! makes me wanna try podium πŸ‘
        http://www.bocostudio.com
          steelers05
          This is great...its awesome to see how far podium has come. Props to all the developers and users.
          • StinkieS Offline
            Stinkie
            New one. Tad too gloomy, me thinks. 36 mins for a 5000 x 2694 render -not bad. πŸ˜„
            • david_hD Offline
              david_h
              just show some light coming out of that fixture over the island, and you've got a winner there.
                congellous
                Nice work, 36 mins what are you running on ?
                The floor looks nice is that lots of tweaking, can you give us a run down of how you got to this quality.
                  sepo
                  looks good....really like the atmo.
                  • david_hD Offline
                    david_h
                    The wall opposite the island looks like it could use a cool piece of art.
                    • StinkieS Offline
                      Stinkie
                      I was thinking the same thing, although I'd possibly opt for 4 or 5 equally sized works rather than one big one. I suspect that would work best.
                      I should also up the lamp's polygon count.
                      • StinkieS Offline
                        Stinkie
                        Thanks, lads.
                        David -yes, I should do that, shouldn't I? I'm quite keen to find out what Podium light would work best in this case.
                        Congellous -I'm using a 4 or 5 year old Mac Pro. The floor is a mat from Podium's Component Browser. Podium's mats are pretty straightforward. There's reflection, bump, and a blur tickbox. That's it. There's some stuff on mats over at http://www.suplugins.com. Pretty much all you need to know.
                        After the render finished, I took it into Photoshop, lowered the saturation of the yellows and the reds, added a curves layer, sharpened the image up using the high pass filter, did some manual blurring, and added a blueish cast to the right of the image. Then I downsampled it.
                        If I remember correctly. My postprocessing tends to be capricious rather than methodical. 😎
                        • N Offline
                          notareal
                          New one. Tad too gloomy, me thinks...
                          I like the atmosphere!
                          • StinkieS Offline
                            Stinkie
                            I could do a version with Thea ... if there were interior rendering presets available to pick apart. πŸ’š
                            • N Offline
                              notareal
                              For biased rendering? I'd start from "04. Final Gathering" preset and improve quality if needed. Or perhaps new Adaptive (AMC) from interactive renderer, as it's fairly fast if bias is set high (also enable caustics for better light).
                              • StinkieS Offline
                                Stinkie
                                Hm, I'll try that. Thea's biased engine is still somewhat of a mystery to me. πŸ˜„
                                • N Offline
                                  notareal
                                  You could try this Adaptive (BSD) -preset. Save in "C:\ProgramData\Thea Render\Presets" in Win7. If it feels too slow, downgrade settings towards "04. Final Gathering" -preset. Also you can disable or tune down "Ambient Occlusion" under Render | Biased RT, if it disturbs.
                                  Also some material tuning may be needed. Under material general, set Perceptual Level(%) to 10,000 if your material has textures (higher will give better quality but difference is small as textures do hide imperfections) also if you have glossy materials you can set they Tracing Depth to 8-12 (if some black areas appear as result of too low tracing depth).
                                  Final Gathering Interior.zip
                                  • soloS Offline
                                    Tom
                                    Can you share the model? I'd like to play with Thea's biased engine to see what speeds I can get...when I get the time.
                                    • StinkieS Offline
                                      Stinkie
                                      Pentti -thanks!
                                      Pete -of course. Tomorrow, after I've dropped of Wee Satan at school. I'll have to take the wall and floor textures out, though -they're from the non-free section of the Podium Component Browser. Did I notice familiar looking plants in there, btw?
                                      In the meantime, here's a version with the lamp switched on.
                                      • stefanqS Offline
                                        stefanq
                                        Looks fantastic Tom. As for the "art on the wall" you can use your own prints.
                                        • StinkieS Offline
                                          Stinkie
                                          I tried that. Looked "meh". πŸ˜„ So ... it's done. 😎
                                          • soloS Offline
                                            Tom,
                                            Firstly thanks for pm'ing me the .skp, Notareal sent me the link to the original model here: http://www.3dallusions.com/Site/Vault/ArchModels/Kitchen_SKP.zip which by the way is horrible as it is totally out of proportion, off axis and spends way more poly's than it needs, yours is nicely optimised...thank you.
                                            On opening yours I noticed your setup, which I believe is way more relevant than any render preset/setup. You have used L.E.M's in order to mimic exterior light as well as one to give light behind the camera.
                                            I was instantly reminded of my days with Podium 1 and remember this being the best way to get soft shadows and good even lighting, however I wondered if this was the fastest way (I cannot remember) did or does LEM's come at a speed cost?
                                            Does Podium 2 have HDRI support? as I was wondering if deleting the exterior LEM and using Image based lightning would not be faster with even better soft lighting?
                                            I'm assuming the LEM behind the camera is to assist and give some light volume as without it all surfaces facing camera would be black, however I am wondering if there was a way of using ISO, shutter speed and f-number settings to enhance lighting without the need for the LEM?
                                            What my rambling is about is the setup of scene may actually be just as if not more important than the actual render settings.
                                            • 2 / 4
