    Designing the site for oil separation
    25 Posts 18 Posters 2.6k Views 18 Watching
    • peter_shawP Offline
      peter_shaw
      amazing, which plugins did u use?
        redfox11
        I used next plugins:
        -Profile Builder
        -Tube along path
        -Pipe along path
        -Weld
        -Rotate 90,180.
        And my own engineering sketchup database (pipes, elbows, tees, caps, flanges, valves, pumps, supports, result of my 4-year sketch practice)
        http://sketchupengineering.blogspot.com/
        • boofredlayB Offline
          boofredlay
          Impressive.
          • DanielD Offline
            Daniel
            Impressive work. Hope we see some more in the future.
            My avatar is an anachronism.
            • jo-keJ Offline
              jo-ke
              that's great. nice to see that sketchup is used in many branches
              http://www.zz7.de
              • pbacotP Offline
                Excellent, Excellent!
                Great to see your work.
                Given your subject matter you might look at other methods of rendering, ala
                Iakov Tchernikov...
                Peter
                  redfox11
                  Iakov Tchernikov...
                  [attachment=0:3aw5buph]<!-- ia0 -->IT.png<!-- ia0 -->[/attachment:3aw5buph]
                  Peter
                  Wow, that drives me mad, looks like the martian tripod from War Of The Worlds.
                  • hellnbakH Offline
                    hellnbak
                    Wow, very intricate, well-modeled. 👍
                      Slimdog
                      What kind of drawings are you supplying? Structural or piping? Got any examples?
                      Great work by the way. Good to see sketchup being used in the real world.
                      S
                      • hellnbakH Offline
                        hellnbak
                        So this is designed to be functional? I mean, each pipe in the model has a specific function, not there just for show?
                        • mitcorbM Offline
                          mitcorb
                          There are so many details here that indicate attention to safety and management of product. You have even included secondary containment in case of spills. There is expansion relief and pressure equalization using elevated tanks, etc. All to achieve separation with responsible use of active systems only where necessary and in an economical manner. Excellent modeling and rendering. Well presented.
                            raineysky
                            Great job Redfox11. That is the kind of drawings I would love to learn how to do!!! Please do show more.
                              redfox11
                              Yes, this is functional model, I made it for purpose of oil separation. I used flow chart and pipe and instrumentation diagram ( i took part in design of this object). My oil and gas department (where i work) isnt large and we havent money for expensive Autoplant or PDS so I desided to use free SketchUp to design piping and equipment.
                              • hellnbakH Offline
                                hellnbak
                                Thanks. This just keeps getting more impressive. Now, just one more dumb question and then I'll leave you alone - what is "oil separation"? Separating the various grades of oil?
                                  redfox11
                                  @hellnbak said:
                                  @redfox11 said:
                                  Shortly - we need to separate well fluids produced from oil and gas wells into gaseous and liquid components.
                                  Separation can be carried out in several stages. You may burn the resulting gas or you may prepare it and use as fuel for electric station.
                                    redfox11
                                    I`m both piping and mechanical engineer so my job is to suply drawings of piping.
                                    But to find collisions I need structural drawings, so in this model I used help of structure engineers from my department.
                                    I can show some examples of final drawings, which I received by 2D export from SketchUp in AutoCAD. The application of the text, dimensioning, I performed in AutoCAD.
                                    Common view with simple service areas
                                    Common view in SketchUp working area
                                    Plan in SketchUp prepared for 2D export
                                    Exported 2D plan. I use colors to separate elements by layers
                                    Final result of the work in AutoCAD. Piping drawing.
                                    Section plain 1-1 after 2D export
                                    Final section plane 1-1 with text and dimensions.
                                    • Mike LuceyM Offline
                                      Mike Lucey
                                      • mojtabata2001M Offline
                                        mojtabata2001
                                        wow the model is so big and complicated! well done
                                        • cheddaC Offline
                                          chedda
                                          Excellent work 😮
                                          Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                                          • RichardR Offline
                                            Richard
                                            Nice job on the pipe work mate, I know myself just how hard this would be without the option of SU and NOT end up with an issue somewhere!
                                            Reminds me of a job given to me as a drafty and still a teenager. I had to do all the layout drawings, pipework, steel fabrication, concete and reo details and scheduling and ALL BY HAND and with just drawing board and calculator - problem was the project was 4 cylindrical tanks with conicle roofs and octagonal walkways / access around the top and landing on the cone. BY HAND WT_? For a kid! Talk about thrown in the deep end!
                                            Iakov Tchernikov...
                                            Peter
                                            Wow - I'd love to see that too!
                                            [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                                            • 2 / 2
