    How do you render flythroughs and object animations?
    extensions
    19 Posts 7 Posters 3.7k Views 7 Watching
    • andybotA Offline
      andybot
      Thanks for taking the time to respond. Good to know more about the Thea workflow. I think I better hold off on coming to any conclusions on Thea until I have a chance to get through some tutorials. I also haven't ventured into the Thea forums. Sort of a chicken or the egg kind of situation. I want to get a sense of a program before I invest too much time into it, but then it's hard to get a sense of it until you do invest some time...
      I hear you about the integrated renderers being hamstrung by the SU poly limits. For my still image work, that has not been a problem as I can post-pro things I need to in Photoshop. But for animations, SU plugins really hit a wall. That's why I am looking to jump ship into Blender for movies.
      I've dabbled with 3DsMax, but atm I just can't afford the program. Blender's got a great price point!
      • N Offline
        notareal
        Perhaps you should start from Thea video tutorials; overview, studio, mini and complex motion case study (revision 627 and afterwards required).
        For Thea, best place to get info is naturally Thea forums. Remember to register using same email that was used when Thea was ordered (Naturally most of the forum is available for all users, with or without license, but some areas are only for licensed users). If mail has changed you need to contact to us so proper forum permission can be given, although there is lot of Thea users here too.
        For walk troughs I believe watching "Complex Motion Case Study" can help a lot... also some animated dummy object (a small box hidden from rendering that you move around the scene) is helpful as camera targets.
        As a render method, perhaps some biased mode is fastest; Final gathering with locked irradiance cache (better disable photon mapping unless all lights are near camera in a closed space) or alternatively the new Adaptive(AMC) with caustics and fairly high Adaptive Bias (%).
        See you at Thea forums πŸ˜‰
        • iichiversiiI Offline
          iichiversii
          Shaderlight will do all the above, i have the licenced version and works great, it did have problems before but the fix beta was released last week and works wonders, it works with su_animate and keyframe animation, what more can you ask for, i would like to see it work with SP but thats something they might consider for future releases ( i hope ) πŸ˜„
          Bring on the Rain...
            dbalex
            When I tried I found shaderlight a little too slow. They have a nice integration with sketchup but if it's already slow in stills it must be really time consuming to render an animation. (I must admit I tried it only once and not the latest version so maybe it's faster now)
            http://www.bocostudio.com
              iichiversii
              Yes it is slow and time consuming but it does render the animations quite well, time again can be hurried by changing the video res output though
              • andybotA Offline
                andybot
                @iichiversii said:
                Shaderlight will do all the above... it works with su_animate and keyframe animation, what more can you ask for...
                Thanks for the suggestion Damien. Let's see: biased (hopefully speedy) render - check! artficial lighting options - check! simple integration with SU - check! Hopefully I'll have a chance to give it a go soon.
                  iichiversii
                  Any joy with shaderlight??
                  • andybotA Offline
                    andybot
                    Thanks for asking, I haven't had a chance yet. Still making my way through understanding Blender. And my Thea trial...
                      iichiversii
                      Ha iv being trying blender from time to time,, got nowhere, let me know when you get the chance to use shaderlight, im sure you will be impressed, unfortunately in the trial version you cant render animations, but if you would like i could do a test for you also if you look at my blog you will find a short animation i did useing keyframe animation and shaderlight for rendering, its only a quick test, not the best but working on something much better at present
                      • andybotA Offline
                        andybot
                        Thanks for the trial details. Based on this, I will definitely wait on Shaderlight until I can focus on using the trial - after all it's the animation I'm concerned about.
                          mckillip
                          I just downloaded the trial of LumenRt on Monday and purchaced it on Tuesday. I was very supprized on how fast the program worked. There were several items that I did like about the live cube and several items that I posted on thier forum about and it seems that E-on is working on solving allot of the issues that have been brought up in the past. I am a novice at animation but created this from the live cube. The video is 44 seconds long and out of LumenRT there were 2 -1.4 gig files and another 450 meg file to make 3 sections of the video. It exported the AVI files in under 5 min. and I ran the files thru Handbrake and squashed the crap out of them down to 12 megs. I then used Quicktime to put the files together and again squashed them down to a very nice 6 meg file. This process in total took under an hour, the last video I took out of VUE PLE for 30 seconds took over 8 hours to produce. To say the least I am very happy about my results and the fast animation that LumenRT Produced. I am now in the process of looking into Sketchy Physics and seeing if I can create some moving clouds, people, doors, ect. The face me trees are off of 3d warehouse and am working on gatherig up better examples soon.
                          My 2 cents
                          • andybotA Offline
                            andybot
                            Thanks for this info, this is helpful to see the finished result. There are two reasons why this is not what I am looking for as far as rendering. One - this is not really rendered, it's just at game quality. See how sharp the shadows are, how would a semi-enclosed or enclosed area look? Also, the transparency mapping is very poor. Two - I see you are just using SU camera directly - and I am trying to find solutions that have much more control over camera keyframing as well as including object animation. I'd like to know if it supports at least keyframe animation or camera keymaker for example.
                              cmckillip
                              I dont know if it matters or not, but again this was my first animation with this product, the settings were on the review mode witht he lowest settings (under 1 min processing) I am sure the other 4 modes from 5 to 1 hour will produce better results.
                              I am sold just on the time process to produce something quick to get into the clients hand for review. If I am really doing post production and real animation I will switch over to 3DS Max design.
                                Schmeade
                                The "Trial" version should give you all the features of the full pro version (which includes animation) but it expires after 14 days, so just register on shaderlight.com and they will send you an activation key which unlocks the pro version.
                                Once your trial is up Shaderlight will revert to the free version which as iichiversii says does not allow you to use the animation feature.
