    How do you render flythroughs and object animations?
    extensions
    19 Posts 7 Posters 4.0k Views 7 Watching
    • iichiversiiI
      iichiversii
      Yes it is slow and time consuming but it does render the animations quite well, time again can be hurried by changing the video res output though
      Bring on the Rain...
      • andybotA
        andybot
        @iichiversii said:
        Shaderlight will do all the above... it works with su_animate and keyframe animation, what more can you ask for...
        Thanks for the suggestion Damien. Let's see: biased (hopefully speedy) render - check! artficial lighting options - check! simple integration with SU - check! Hopefully I'll have a chance to give it a go soon.
        • iichiversiiI
          iichiversii
          Any joy with shaderlight??
          • andybotA
            andybot
            Thanks for asking, I haven't had a chance yet. Still making my way through understanding Blender. And my Thea trial...
            • iichiversiiI
              iichiversii
              Ha iv being trying blender from time to time,, got nowhere, let me know when you get the chance to use shaderlight, im sure you will be impressed, unfortunately in the trial version you cant render animations, but if you would like i could do a test for you also if you look at my blog you will find a short animation i did useing keyframe animation and shaderlight for rendering, its only a quick test, not the best but working on something much better at present
              • andybotA
                andybot
                Thanks for the trial details. Based on this, I will definitely wait on Shaderlight until I can focus on using the trial - after all it's the animation I'm concerned about.
                  mckillip
                  I just downloaded the trial of LumenRt on Monday and purchaced it on Tuesday. I was very supprized on how fast the program worked. There were several items that I did like about the live cube and several items that I posted on thier forum about and it seems that E-on is working on solving allot of the issues that have been brought up in the past. I am a novice at animation but created this from the live cube. The video is 44 seconds long and out of LumenRT there were 2 -1.4 gig files and another 450 meg file to make 3 sections of the video. It exported the AVI files in under 5 min. and I ran the files thru Handbrake and squashed the crap out of them down to 12 megs. I then used Quicktime to put the files together and again squashed them down to a very nice 6 meg file. This process in total took under an hour, the last video I took out of VUE PLE for 30 seconds took over 8 hours to produce. To say the least I am very happy about my results and the fast animation that LumenRT Produced. I am now in the process of looking into Sketchy Physics and seeing if I can create some moving clouds, people, doors, ect. The face me trees are off of 3d warehouse and am working on gatherig up better examples soon.
                  My 2 cents
                  • andybotA
                    andybot
                    Thanks for this info, this is helpful to see the finished result. There are two reasons why this is not what I am looking for as far as rendering. One - this is not really rendered, it's just at game quality. See how sharp the shadows are, how would a semi-enclosed or enclosed area look? Also, the transparency mapping is very poor. Two - I see you are just using SU camera directly - and I am trying to find solutions that have much more control over camera keyframing as well as including object animation. I'd like to know if it supports at least keyframe animation or camera keymaker for example.
                    • C
                      cmckillip
                      I dont know if it matters or not, but again this was my first animation with this product, the settings were on the review mode witht he lowest settings (under 1 min processing) I am sure the other 4 modes from 5 to 1 hour will produce better results.
                      I am sold just on the time process to produce something quick to get into the clients hand for review. If I am really doing post production and real animation I will switch over to 3DS Max design.
                        Schmeade
                        The "Trial" version should give you all the features of the full pro version (which includes animation) but it expires after 14 days, so just register on shaderlight.com and they will send you an activation key which unlocks the pro version.
                        Once your trial is up Shaderlight will revert to the free version which as iichiversii says does not allow you to use the animation feature.
