    ⚠️ Important | Libfredo 15.6a introduces important bugfixes for Fredo's Extensions Update
    Need help with a broken/corrupted skp model
    11 Posts 5 Posters 2.0k Views 5 Watching
    • W Offline
      windbladezero
      basically sketchup crashed while i was working on a model
      it was saved correctly minutes before sketchup crashed
      after reinstalling sketchup
      everything worked again, every model but that one
      it the backup (skb) file of said model was empty and the model itself not, is still the same size as before the program crashed and even has the thumbnail, but when i try to open, it just doesnt
      just appears a message saying: failed to open document
      i just cant just do the model again,ive been working on it almost for 4 months
      i need to recover it
      by the way the models is less than 1.7mb, but was really difficult to make and was almost complete
      • Rich O BrienR Online
        Can you share the file? If not publicly via PM?
        • W Offline
          windbladezero
          For some reason i cant browse for the file from the upload attachment tab
          • W Offline
            windbladezero
            here's the file, I really hope there is a way to fix it
            Jolt Upgrade Set V1.skp
              chrisjk
              I am afraid I can't open it on my Mac - crashes SU. I can see a thumbnail with a number of objects in it.
              • Alan FraserA Offline
                Alan Fraser
                It's almost there. If you try to import it rather than open it, you get the thumbnail and even all the materials in the browser...it just can't handle the geometry. Google might be able to fix it if it's really important.
                Have you tried looking for and opening any autosave skp? It's usually located in the same folder as your work file.
                3D Figures
                • W Offline
                  windbladezero
                  i said it before, the autosave was empty
                    Alan Fraser
                    Actually, you didn't. You said the skb was empty. That's not the same thing at all....that's why i asked.
                    3D Figures
                    • W Offline
                      windbladezero
                      then no, just the skb and the broken skp,
                      and deleted the skb since it was empty
                      • W Offline
                        windbladezero
                        thanks anyway
                        i still wont make the model again from th beginning
                        • E Offline
                          errror404
                          In a PC:
                          right click the file -> Properties -> Previous Versions TAB
                          If you moved or copied the file, it won't work
