    Calque window
    4 Posts 3 Posters 309 Views 3 Watching
      biarddany
      I have been using Sketch up 8 for a while without (major) problem.
      Suddenly I am unable to open de calque window on all the files I have created.
      The other windows are opened OK. I have reloaded the program but no effect.
      Anybody with an idea on what is the problem?
      Thanks in advance for the help.
      DB
      • BoxB Offline
        Do you have multiple monitors?
        Sometimes a window can get lost hiding on a different monitor position.
        If you do have more than one monitor, use display settings to reposition the monitors and see if the Layer window appears, if it does, move it back to the main window and reset your monitor position.
        If no multiple monitors, ignore me.
        Perhaps try Reset Workspace under preferences.
        • TIGT Online
          OR try using the maximum screen resolution to bring the errant window back into view...
          If none of this works...
          Close Sketchup and use
          Start > Run... > regedit
          HKEY_CURRENT_USER\Software\Google\SketchUp8\SnappyLayers
          set x and y to 0 so it moves into view after you close the regedit session and restart Sketchup...Capture.PNG
            biarddany
            Thanks to all. Problem solved.
            This was indeed a monitor problem.
            Dan
