    Bringing life to my 32 Ford Rod
    36 Posts 18 Posters 6.2k Views 18 Watching
    • JMJOhioJ Offline
      JMJOhio
      Thanks - EscapeArtist, pbacot, Boo, andybot & swagen. πŸ‘
      Continuing the rendering exploration and learning efforts on the 32. Purchased an IndigoRT license Sat. and can now work with a more dynamic toolset and lack of resolution restriction. Did initial mapping of paint, chrome (bright & satin), glass and cast wheels. Everything else is still the original SU materials and textures that Indigo maps as low value diffuse. I placed an image, actually a wall using an image as texture, behind the camera and in the scene in an attempt to project reflections in the paint. Have not been able to get this to work yet. Probably something very basic that I have not stumbled over yet. Until I do, the car body will look plastic. Using the sun as my only light source thus far. That's not true, mapped the "reflection wall" as Phong and gave it some medium intensity emitter values. I'll keep searching.
      The learning curve is steep, but enjoying it so far.
      JMJOhio
      • hellnbakH Offline
        hellnbak
        I have run out of adjectives for this model. So I created a new one -
        Superincrediblefantasticalamazingunbelievablewowgeewhizohmygodhow'dyoudothatjawhittingflooreyesgoingboingdroolingheyIcoulddothat
        (not)absolutelyflawlesshowlongdidthatthingtakewhycan'tIdostufflikethatbeyondbeliefbestmodelI'veeverseenwowtoinfinitygollyjeezmakesmy
        stufflookliketinkertoysdamdamdamstopshowingthisstuffI'mgonnastartcryingfessupthisisn'tamodelit'sjustphotosofarealcarI'mgonnastart
        drinkingagainIhateyouforcryingoutloudmakesomethingcrappysoIcanfeelbetteraboutmycrappyworkyoushouldhaveyourhandsinsuredeachtime
        Ilookatyourworkmycomputerlaughsatmewowwowwow.
        Nuff said
        • irwanwrI Offline
          irwanwr
          Nuff said
          πŸ‘ πŸ˜†
          • IdahoJI Offline
            IdahoJ
            JMJOhio, outside of the "usual" tools that come with SU, are there any additional tools that you're using of particular note?
            I think your work on this is simply amazing! πŸ‘
            Cheers.
            "For a moment, nothing happened. Then, after a second or so, nothing continued to happen."
            • JMJOhioJ Offline
              JMJOhio
              Nuff said
              These images represent the efforts of an individual with absolutely no talent. I think you will all agree. No sense of proportion or attention to detail. Obviously does no research at all. And he creates these things at an alarming rate - one right after another. You can see more of them here.
              404 Not Found
              (forums.sketchucation.com)
              I downloaded the 56 Fairlane from the warehouse, mapped a few textures, did very quick renders and no pp. The greatest effect by rendering is the shine of the paint. Otherwise his works are render quality directly from SU. I really feel sorry for you Steve. 🀣
              @Idahoj -- Thank you - No additional tools, No plugins (for the modeling), No imports except for some textures.
              Hellnbak 56
              Hellnbak 56
              • IdahoJI Offline
                IdahoJ
                You must have the patience of Job considering all the curved surfaces! Wow ... 😲
                • hellnbakH Offline
                  hellnbak
                  Wow, is that my '56? Didn't look that good for me. Hey, maybe I should try to sell it somewhere! πŸ˜†
                  • JMJOhioJ Offline
                    JMJOhio
                    Still working on the 32. This image is just out of the oven after a 30 minute bake. Will generate about a page of criticisms, observations and notes relative to a single image. Then more mapping, tweaking of existing maps and possibly some model geometry adjustments before I hit the render button again. I think it may take me longer to achieve satisfactory renderings than it took to build the model.
                    32 Engine Bay
                    • hellnbakH Offline
                      hellnbak
                      explthrusyssweemovxxxrythopaq!!!!!!
                      • JMJOhioJ Offline
                        JMJOhio
                        Is that a quote from?
                        Cape Fear, 1991
                        • hellnbakH Offline
                          hellnbak
                          Yes, I often speak in tongues (I have three of them, all forked)
                          • 3 Offline
                            3eighty
                            You should let me hold a copy of that for you to --um--safeguard...
                            • KrisidiousK Offline
                              Krisidious
                              what an amazing piece of work. insane detail and it really sells the renderings.
                              By: Kristoff Rand
                              • andybotA Offline
                                andybot
                                I concur. That looks so lifelike, it's amazing!
                                • JMJOhioJ Offline
                                  JMJOhio
                                  @ Kristoff and Andy - Thanks guys
                                  This level of model detail does lead to more realistic renders but makes the texture and lighting application process much more involved. I'm just starting to experiment with individual lights versus using the sun only. Also have not ventured into any serious post p efforts yet. Learning as I go and I work very slowly.
                                  • 3 Offline
                                    3eighty
                                    Only a suggestion: Place a piece of shinny sheet metal on the firewall... 😎
                                    • irwanwrI Offline
                                      irwanwr
                                      πŸ‘ another gang member of Steve, Elisei and Marian πŸ˜„
                                        Can I have mine in black please? Lovely model/render.
                                        • JMJOhioJ Offline
                                          JMJOhio
                                          View through the rear window of the 32. 160 mph speedo and 10K tach with redline set at 8500 rpm. Currently limiting the revs to about 6000 because Steve doesn't think the engine sounds good at idle. Waiting for him to tune it for me. πŸ˜†
                                          This image created after 60 minute bake at 2400x1200 res. Used combination of sun and an interior overhead light panel (300w) for lighting. Still limited on render lighting as IndigoRT doesn't support light layers or ies files.
                                          • hellnbakH Offline
                                            hellnbak
                                            What, no 8-track? It's gotta have an 8-track. Please take care of that. Thank you
