    Top view issue[Solved]
    layout
    4 Posts 3 Posters 616 Views 3 Watching
    • T
      thestranger
      I hope someone can help. I am having trouble getting the correct top view in layout. I want the top view of the model to be viewed horizontally across the page however whenever I select left or right view and then go to top view the top view is always vertically on the page. Does anyone have any ideas how to get around this?
      John
        Make a scene tab in the SKP and use that to save a view.
        You can rotate the 'top' plan view by any angle, using my script 'Rotate Plan View' - see the Plugins Index button for the link...
          sonder
          Great TIG - I'll get that. Another simple work around is to simply rotate the SU view in layout 90 degrees.
          • T
            thestranger
            Thanks, that plugin is fantastic!
