    Intersect With Model Problem
    3 Posts 2 Posters 417 Views 2 Watching
      Stu
      Hi Guys,
      For some reason I am having a problem with the 'Intersect With Model' command.
      I am using the free version of SU 7 and until recently it worked fine....its a command I use frequently and is essential in my work flow.
      Im finding a reasonably complex intersection just hangs the model and even a simple intersection of a couple of planes takes ages.
      I cant really figure what's happening....a video card playing up?.....a RAM problem?.......I havent noticed any other problems with my computer.
      Any suggestions appreciated πŸ˜„
      http://www.landesign.com.au
      • TIGT Online
        Don't try to select everything and intersect it with everything else - it takes ages... although it might finish eventually...
        If you have some faces that you know need to be intersected, then select only those and use intersect with context/model... the intersecting should then be much swifter...
          Stu
          Thanks Tig,
          Partial selecting would certainly help...but it does seem like a recent problem....Ive been using this function constantly since it was first introduced way back in version? without much trouble.
