    [Plugin] Camera Recorder v1.7.2 UPDATED May 23, 2013
    136 Posts 32 Posters 277.6k Views 32 Watching
    • Chris FullmerC
      Hi Drew, once plugins start getting to the point where they make their own toolbars, they often have dubfolders to help keep them organized a bit. So that is why there is a subfolder. You should just be able to extract it exactly as it is into your plugins folder.
      You can tell that you are downloading the most current version because you are downloading it here or at http://www.smustard.com. I never deouble release plugins, so they are downloadable either there or here. (There are a few plugins that are translated into other languages that you can download on foreign language forums too. It is up to the translator to keep them current).
      Also though, with this particular plugin, Jan has done some nice re-working of it to make the camera path more editable. What do we think, should I remove this version and just link over to Jan's? I think his has all the same functionality as mine, plus all the awesome features he added. So it is really like an upgrade.
      So I suppose if you download and install the one at the beginning of this thread, you will have my most recent version, though Jan did add to it. So I might recommend downloading that one. I'll see if I can find a link.
      • drewD
        drew
        Thank you for taking the time to explain the plug-in installation, i am lookin forward to trying Camera Recorder. Jan's version sounds cool... if you find the link, please post it. Thanks again...
        Drew πŸ‘
        drew
        • Bob JamesB
          Bob James
          @chris fullmer said:
          So I might recommend downloading that one. I'll see if I can find a link.Chris
          I would also be very interested in that link
          • PixeroP
            Pixero
            Here is the link:
            http://forums.sketchucation.com/viewtopic.php?f=323&t=35121
            • E
              Emilien
              Hi chris, did you work on the FOV problem of your plugin ?
              • Chris FullmerC
                Ni, I have not. No plans to look at it in the next few months either. Sorry, but if you happen to be a code-writer, feel free to do so yourself. I'm just busy beyond capacity for a while.
                  dodomomo86
                  hi, this plug worked fine for the first time, but now when i open skechup i get this:
                  Error Loading File E:/softweres/Google SketchUp 8/Plugins/clf_camera_recorder/clf_camera_recorder.rb
                  private method gsub!' called for nil:NilClassError Loading File clf_camera_recorder_loader.rb private method gsub!' called for nil:NilClass
                  does anyone know how to fix this? (-:
                    shri
                    thanks alot for this wonderful plugin.chris
                    • V
                      vadesigner
                      Chris, I'm having a problem with the Camera Recorder. Everything works fine up til I try to export he images. I see it says "Exporting X of X images", but the program stops at that.
                      Once, I did get two images exported before it stopped (then I got a "Sketchup is not responding").
                      I do have a skydome in the model, but the animation is working fine. Thanks.
                        'Not Responding' doesn't mean it's stopped.
                        Sketchup can 'white-out' during intensive processing and the counter appears to be stick, BUT it is probably still processing in the background.
                        If it's left to it's own devices it will complete, eventually...
                        To see if Sketchup is still working open your PC's Task Manager and you should see its process ticking along...
                        If you run a tool with the Ruby Console open then any internal code errors appear there too, but in this case it's unlikely.
                          Muxima
                          Hello,
                          someone can help me?
                          I need to do a presentation on video. i canΒ΄t douwnload the plugin camera recorder. Thanks for the help!
                          Greetings.
                          • Chris FullmerC
                            Hi, there is a link to the download in the first post of this thread. Its called
                            clf_camera_recorder.zip
                            Click on that and it will download. Then unzip it to your sketchup plugins folder.
                              amrossi
                              Blz Chris, estou enviando essa mensagem para instalar o plugin camera recorder.
                              abraΓ§o
                              • B
                                barttjee
                                Hey Chris,
                                This plugin is awesome. I have a question: Is it also possible to record from scene to scene made in sketchup by adding a scene? So if I create 3 scenes, and than click on scene 1. Then I click on the record button(your plugin). Next I click on scene 2(while recording) and finally I click on scene 3. At last I click on stop recording and then export it to sequece images. Is this possible? I tried this and also exported the images, but they are all the same. I tried to make an animation through a landscape(with the default SU animation tools), but I don't like the stops between every scene. I want the animation flows more smoothly, and your tool is great but it is very difficult to walk through the landscape. The problem is that I want some stops to focus on certain objects(signs, trees etc.) How can I manage this?
                                Ps. english is not my native language πŸ˜‰
                                Thank you very much,
                                barttjee
                                • Chris FullmerC
                                  Hmmm, I don't that I've ever tried to go from scene to scene while using this camera recorder. I could see a reason why it might not work at all. I did not intend for it to work with scenes, so I never tested it. My guess would be that it should work though.
                                  It does sound like what you want should be accomplished with regular scenes though. Make sure you go to the Model Info and look at the animation settings. Turn off the pause between scenes. And if you do have a spot where you want to pause, just add a second scene in a row in the exact same spot, then it will pause at that location.
                                  Not sure if any of that helps.
                                  • B
                                    barttjee
                                    Thanks! Never thought about adding the same scene in a row. I think it will help! thank you very much
                                    • 7 / 7
