    Ellipse with equal faces/segments
    11 Posts 6 Posters 3.0k Views 6 Watching
      If you have ever used a plugin, you will know how to install this one:
      http://rhin.crai.archi.fr/rld/plugin_details.php?id=124
        ellipse where each face got exactly the same size
        Can you put an image of what do you want ?
        Something like this where the surfaces A must be equal?
          stoferr
          What I mean is that, when you create a default circle in sketchup, It consists of 24 faces/lines. All those lines are of equal length, however when you stretch the circle, those lines will be stretched differently resulting in unequal lengths. What I need is an ellipse that has equal segments, where those 24 lines are alike. To precise what exactly I need, it's an ellipse being 189x156 meter, consisting of 80 faces. Now, I'm no noob at sketchup, in fact I believe that I'm pretty good after 4 years of working with the program, but this thing really bugs me. And ofcourse you don't have to tell me how to add more segments to a circle, it was just an example. πŸ˜„
          I'll be home in 1 hour then perhaps I can show you a screenshot to specify more clearly.
          Btw I already tried that plugin but it also creates unequal segments.
            Faces can have any forms but must equal in surface ?
            Curious problem πŸ˜„
            It's like a quadrature of circle πŸ˜„
            take the circumference lenght = one segment length
            Divide it by the number of segments wished
            And draw / adapt them above the original ellipse πŸ˜„
            Now the headache : found 80 surfaces equal!
              stoferr
              How stupid of me! Ofcourse I mean Edges and not faces, damn how could I mess that up?
              Well, heres a simple picture of what I mean:
              Normally, when creation ellipses I (and most people) would probably draw a circle, press S on the keyboard (1) and then stretch it. But as you can see (2) this method results in each EDGE having a unique length because that it was stretched. So, how do I make an ellipse where all the edge segments are of equal length?
              http://i118.photobucket.com/albums/o88/stoferr/sketchup87354034.jpg
                The more segments the ellipse has the nearer they get to being equal...
                IF you want exactly equal segments you need to code it from scratch...
                  stoferr
                  Alright, well, its just not the answer for me, I do understand that the more segments you make the more accurate they will be. But you see, I need an ellipse divided into 80 edges, so that can work on yeach of those edges (they have to be the same) Adding more segments would solve that, lets say, i doubled the number to 160 segments, then I would just have to work with two of them, in the end resulting in the same inaccuracy, and ofcourse, heavier and more demanding geometry.
                  But I thank you guys, if its not possible, then its not possible, atleast i can stop wondering about all the time πŸ˜„
                  Oh but while we are it, out of clean curiosity; why do the "Divide" function not work on circles or arches which has been stretched, cut or modified in any way?
                  • oganocaliO Offline
                    oganocali
                    If you have to have equal length segments, you can use resample paths feature of Tgi3D (training free version has this feature unlimited). After drawing your ellipse remove the face (this feature will work with naked paths only), select the ellipse and apply with the desired length. (you have to supply the correct length somehow otherwise you will have one short segment).
                    good luck
                    • gillesG Offline
                      gilles
                      Ellipse from Didier Bur as Gaieus mention,
                      Very simple, you can choose the number of segment; this really what you are looking for.
                        stoferr
                        Thank you very much! Tgi3D did exactly what I wanted, and I figured it out pretty fast thanks to you πŸ˜„
                        You just made my day!
