    Mysterious Bug [followme related]
    30 Posts 4 Posters 1.1k Views 4 Watching
      Chris88
      Hi all,
      i have this code (i know it looks confusing, because i don't know
      how to program the 'followme'-function, but it's not the problem)
       module LineA
        def LineA.create_line
        unless Sketchup.active_model;
          until Sketchup.active_model.active_entities
          model = Sketchup.active_model
          entities = model.active_entities
          # Add the group to the entities in the model
          group = entities.add_group
          # Get the entities within the group
          entities2 = group.entities
          @width_small = 55 # 55
          @depth_small = 45 # 45
          @height_small = 30 # 30
          @width_big = 70 # 70
          @depth_big = 60 # 60
          @height_big = 70 # 40
          @height_line = (4/3) * @height_small
          @radius = 1
          @arcradius = 3
          @mat_linie=model.materials.add("Material_Linie")
          @mat_linie.color=Sketchup;;Color.new(124,252,0)  # => LawnGreen
          @anzahl_arcs = ((@depth_small-6)/6).to_i
          @pts =[]
          @helpvar_depth = 3
          @helpvar_pts = 1
          @helpvar_baseline = 1
          @helpvar_basearc = 1
          1.upto(@anzahl_arcs) do |x|
            @helpvar2_pts = @helpvar_pts +1
            if (x%2 > 0)
              @pts[@helpvar_pts] = [((@width_big-@width_small)/2)+5.35, ((@depth_big-@depth_small)/2)+@helpvar_depth, @height_line]
              @pts[@helpvar_pts+1] = [@width_small+((@width_big-@width_small)/2)-5.3, ((@depth_big-@depth_small)/2)+@helpvar_depth, @height_line]
              # arc_point
              @pts[@helpvar_pts+2] = [@width_small+((@width_big-@width_small)/2)-5, ((@depth_big-@depth_small)/2)+(@helpvar_depth+3), @height_line]
              arc_circle_odd = entities2.add_circle @pts[@helpvar_pts+1], X_AXIS, @radius, 42
              arc_circle_face_odd = entities2.add_face arc_circle_odd
              arc_circle_face_odd.material = @mat_linie
              arc_circle_face_odd.back_material = @mat_linie
              line_circle_odd = entities2.add_circle @pts[@helpvar_pts], X_AXIS, @radius, 42
              line_circle_face_odd = entities2.add_face line_circle_odd
              line_circle_face_odd.material = @mat_linie
              line_circle_face_odd.back_material = @mat_linie
              @helpvar_baseline_odd = entities2.add_line @pts[@helpvar_pts], @pts[@helpvar_pts+1]
              @helpvar_basearc_odd = entities2.add_arc @pts[@helpvar_pts+2],[0,-1,0],[0,0,1],@arcradius,-5.degrees,185.degrees
              arc_circle_face_odd.followme @helpvar_basearc_odd
              line_circle_face_odd.followme @helpvar_baseline_odd
            elsif (x%2 == 0)
              @pts[@helpvar2_pts-1] = [((@width_big-@width_small)/2)+5.3, ((@depth_big-@depth_small)/2)+@helpvar_depth, @height_line]
              @pts[@helpvar2_pts] = [@width_small+((@width_big-@width_small)/2)-5.35, ((@depth_big-@depth_small)/2)+@helpvar_depth, @height_line]
              # arc_point
              @pts[@helpvar2_pts+1] = [((@width_big-@width_small)/2)+5, ((@depth_big-@depth_small)/2)+(@helpvar_depth+3), @height_line]
              arc_circle_even = entities2.add_circle @pts[@helpvar2_pts-1], X_AXIS, @radius, 42
              arc_circle_face_even = entities2.add_face arc_circle_even
              arc_circle_face_even.material = @mat_linie
              arc_circle_face_even.back_material = @mat_linie
              line_circle_even = entities2.add_circle @pts[@helpvar2_pts], X_AXIS, @radius, 42
              line_circle_face_even = entities2.add_face line_circle_even
              line_circle_face_even.material = @mat_linie
              line_circle_face_even.back_material = @mat_linie
              @helpvar_baseline_even = entities2.add_line @pts[@helpvar2_pts], @pts[@helpvar2_pts-1]
              @helpvar_basearc_even = entities2.add_arc @pts[@helpvar2_pts+1],[0,1,0],[0,0,1],@arcradius,-5.degrees,185.degrees
              arc_circle_face_even.followme @helpvar_basearc_even
              line_circle_face_even.followme @helpvar_baseline_even
            end # if
             if (x == @anzahl_arcs)
              @pts[@helpvar_pts] = [((@width_big-@width_small)/2)+5.35, ((@depth_big-@depth_small)/2)+(@helpvar_depth+6), @height_line]
              @pts[@helpvar_pts+1] = [@width_small+((@width_big-@width_small)/2)-5, ((@depth_big-@depth_small)/2)+(@helpvar_depth+6), @height_line]
              @helpvar_baseline_ende = entities2.add_line @pts[@helpvar_pts], @pts[@helpvar_pts+1]
              line_circle_face_odd.followme @helpvar_baseline_ende
            end # if
            @helpvar_depth = @helpvar_depth + 6
            @helpvar_pts = @helpvar_pts + 3
          end # upto - do
        end # def
      end # module
      LineA.create_line
      When i execute it in SU there's no error, but if i load it in the plugins of SU,
      the hole SU break down and show me a 'Bug Splat', however no significant error message.
      I hope you can help me.
        <span class="syntaxdefault"><br />unless Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">;<br /></span><span class="syntaxdefault">        until Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities<br />        end<br />      end<br /></span>
        What is this strange loop?
        Is it that you try to make it run when SU starts? I see you have this line at the end: LineA.create_line
        Why do you have that strange loop?
        Have you tried without it?
        I'd be very surprised if that lop doesn't block up all processing of SketchUp.
        If that isn't the issue - have you tried commenting out blocks of your code to see when it does not crash? When it doesn't then you know the offending line is within that block and you can narrow down further.
          Chris88
          the strange loop ist an advice of TIG... http://forums.sketchucation.com/viewtopic.php?f=180&t=41767,
          it makes sure that all services of SU are loaded succesfully.
          it runs also without this loop.
          And i have commenting out all loops and many lines, but i didn't found the failure.
          It's strange that i can run the script succesfully in SU, this bug is only when loading the script out of the plugins or starting SU per cmd with the script as parameter.
          (P.S. i have SU 8 free version)
            What you explain what you mean by this?
            I'm confused - is it when the script is located in another location? Or if you load the script manually via the Ruby Console?
              I can't start to guess why you might want always to do this weirdness at every startup - for example, why make geometry that might clash with existing stuff etc... why not simply load a premade component, or make a new template containing the desired stuff as the default for your new SKPs ???
              Also do you have require 'sketchup.rb' at the very start of the script ?
              It might be needed somewhere in your code 😕
              Your [my 😳 ] code
              is wrong.
              It waits until the model.active_entities exist before continuing, BUT it only does the pause if there is NOT an active_model ?
              Therefore it never pauses because the active_model always exists as it is loading the script's code, although the active_entities might not [on a MAC for example]...
              Try
                  ### wait
              which WILL wait until there's both an active_model and it has active_entities...
              ALSO , as I suggested in that other thread... why not encapsulate your 'loose' code in a 'timer' which waits a few seconds before kicking off, like this:
              UI.start_timer(2.0, false){LineA.create_line}
              This lurks for 2.0 seconds after the script loads before doing its dirty deeds...
              Then most things will have 'passed' before it works...
              http://code.google.com/apis/sketchup/docs/ourdoc/ui.html#start_timer
                Chris88
                @thomthom: i can start successfully the script in SU per Ruby Code Editor or per Sketchup Bridge in RDE to test it. The error appears when i copy my script in the plugin-folder, load it from ruby console in SU or start SU per cmd and assign my script as parameter in the cmd.
                @TIG: thanks for your corrected code and suggestion, but it doesn't solve the bug. And i don't 'understand' your first lines: "make a new template containing the desired stuff as the default" ... and it shouldn't be premade components (that's was my first attempt 😞 )
                  Why make all of the complex geometry in a new group every time ?
                  Make it as a SKP, load that as a component, and add an instance of it inside a new group's entities, and explode the instance, then erase all of the just loaded component's definition's entities and it is removed from the model [provided there's a start/commit_operation around the actions]... That way you don't need to 'code' the making of the object and it's still inside a group as you have now AND there's no new component been added to the model...
                  IF you explained what it is you are attempting to 'automate' then we might have more insight... 😕
                    Maybe we need to take a step back. What is the overall goal of what you are making?
                      Chris88
                      So because i'm almost at the end of coding my program, i actually don't want to modify the rubyscript, that it loads premade components.
                        Chris88
                        The course of action of my program, which conduces to woodworking:
                        in C#:
                        • read technical values out of xml-files
                        • generate a rubyscript for every object
                          (tool, wood, machining line,...) in .txt- format
                        • replace the wildcards (i.e: width,height,depth of a wooden box)
                        • put all rubyscripts together an name the file xy.rb
                        • start Sketchup with the file xy.rb as argument
                        ... and my code is all but finished, when i start SU with the file xy.rb it crashes and SU reports a "bug splat"
                        http://images.wikia.com/sketchyphysics/images/6/63/BugSplat.png
                          Right. And I understand that it crashes when you start SU with an argument to execute that plugin? Correct?
                          But not if start SketchUp and use the Ruby Console to load it?
                          If the plugin is located in the plugin folder - does it crash then?
                          This is what is unclear to me.
                          <- I don't understand what you mean there. "out of the plugins"?
                          • Dan RathbunD Offline
                            Dan Rathbun
                            Try it like this:
                            module Chris88
                              module LineA
                                TIMER = nil
                                def self.create_line()
                                  # delete lines 1-4 with loop
                                  begin
                                    model.start_operation( 'LineA' )
                                    # the rest of your method code
                                  rescue => e
                                    model.abort_operation
                                    puts("#{Module.nesting[0].name} Error #<#{e.class.name}; #{e.message}>")
                                    puts(e.backtrace)
                                  else
                                    model.commit_operation
                                end # def
                              end # module LineA
                              # run when file loads
                              if Sketchup.active_model &&
                                LineA.create_line
                              else
                                LineA;;TIMER = UI.start_timer(2.0, true){
                                    UI.stop_timer(LineA;;TIMER)
                                    LineA.create_line
                                  end #if
                            end # module Chris88
                            Your modules need to be wrapped inside your "author" outer module.
                            I'm not here much anymore.
                              Chris88
                              @thomthom: Correct. And yes, it crashes if it's located in the plugin-folder, too.
                              And it doesn't matter, if i load the script with the Ruby Console or if i start SU normally and the script is in the plugin-folder.
                              @Dan: Thanks Dan! I will test it in a few minutes...
                                I tried the code you posted initially. I get no crash. I did however leave out LineA.create_line so that it would not execute when SU loaded.
                                I called the method afterwards in SU.
                                Sidenote - it seems that you create the profile for your shape (the circle) many times. Many small segments for what is in reality one single tube. As you can see- you end up with gaps where the straight sides meets the arced corners.
                                You would avoid that by making the tube as you would in SU. Making one single path, and one profile - then using follow me only once for the whole shape.
                                Should make a cleaner geometry, be faster and simplify the code.
                                  Oh yea - as Dan suggested with his code. several operations should be wrapped in .start_operation - .commit_operation so it produces only one undo step. And if you use the disable_ui argument it should run faster.
                                    Dan Rathbun
                                    Yea, it's dangerous to do stuff during SU load, as all the Google extensions are not yet loaded like Dynamic Components.
                                      Dan Rathbun
                                      maybe a wait timer like this is safer...
                                          UI.start_timer(0.0, false){ LineA.create_line }
                                        else
                                              LineA.create_line
                                            end #if
                                        Chris88
                                        @Dan: Thank you. Now my code looks like:
                                        module Chris88
                                          module LineA
                                            TIMER = nil
                                               # alle Objekte die den entities2 zugeordnet werden, werden automatisch zu einer gemeinsamen Gruppe gemacht
                                              begin
                                                @radius = 1
                                                @arcradius = 3
                                                @pts =[]
                                                @helpvar_depth = 3
                                                @helpvar_pts = 1
                                               if (x%2 > 0)
                                                # arc_point
                                              elsif (x%2 == 0)
                                                # arc_point
                                              end # if
                                              end # if
                                            end # upto - do
                                              rescue => e
                                                puts(e.backtrace)
                                              else
                                            end # def
                                          end # module LineA
                                            LineA.create_line
                                          else
                                                LineA.create_line
                                              end #if
                                        Is this what do you mean?
                                        However it doesn't solve the bug.
                                        @thomthom: Thanks, that could help me. I know this, what you wrote in your sidenode, but it didn't work: When i draw a circle and a path, which starts at the central point of the cricle, Sketchup draw only the lines, but not the curves. This is why i decided alternatively to draw the lines and the curves seperately. Do you think the gaps could be the reason for the bug?
                                          Chris88
                                          Dan, i have to correct myself: It works, when i load the script from the Ruby Console = step forward! 😄 [Edit:] i just noticed, this is what thomthom meant. 😢 [/Edit]
                                          But it doesn't work yet, when i want to load the script from the plugin-folder by starting SU normally and the script is located in the plugin-folder.
                                            Don't think so. Just a sidenote. It is possible to create that shape in one operation.
