    Do This Right Now!!!
    24 Posts 18 Posters 2.4k Views 18 Watching
      sonder
      Really sorry to hear this. This happened to me many years ago. Since then I do daily back-ups. I now keep my work current on 2 separate working computers, a portable hard drive and a network drive. The network drives are awesome. I have a buffalo twin single terabyte network drive. It automatically backs up work as well as duplicates it on the second drive should either drive fail. It was probably the best $250 I have ever spent.
      Keep your chin up. The one thing you haven't lost is the knowledge to create new work.
        dtrarch
        Kris
        What a shame but all may not be lost.
        I use File Scavenger 3.0
        Old app but will dig out the files as long as the drive works.
        More than once I have said yes to the delete and kill key 😒
        http://file-scavenger.en.softonic.com/
        My version was about $50 US and worth every penny.
        It will recover a whole drive but must copy to another backup drive.
        Also as I recall it will also copy selected folders to a different folder on the same drive.
        Do take look at the link info.
        It really works.
        Really sorry for you
        dtr
        • KrisidiousK Offline
          Krisidious
          Thanks for all the kind words... I've run several recovery programs and have been able to find the files I lost however all are corrupt. so now I'm going to mail off the hard-drive to professional. I'll be using this company unless one of you knows of a better company or sees some reason why I shouldn't.
          404 Not Found
          (www.salvagedata.com)
          They say I mail it to them and then they diagnose and evaluate the drive and what it will take to get the info out. cost is between $500 and $1100... no data no cost they say. and an estimate before any work starts. so sounds good to me. and they're #1 on Google for the term "data recovery" no easy feat in itself. so fingers crossed.
          Again, I appreciate the comforting and the advice. I'm quite embarrassed, I should know better. but I thought this might stand as a lesson to others... So at least there might be some benefit from my loss.
          I'll keep the thread updated to the progress.
          By: Kristoff Rand
          • Mike LuceyM Offline
            Mike Lucey
            Kris, just a thought! Are you going to make a copy of the drive before sending or is this even possible?
              Krisidious
              I was thinking about that... but I don't think it would do much good as the important files are down below and I would think not copy-able. but I would be interested in hear as I have the cloning software and I have an extra identical sized drive.
              By: Kristoff Rand
                Krisidious
                I learned today that all I have to show for the last 14 years of work is what's in my head... Data Recovery Specialist says... "Files Unrecoverable." Heart Break to Ensue...
                Unfortunately due to the extent of physical/logical damage found on the media, this case has been deemed not recoverable. An email detailing specific findings to follow.
                Regards,
                The SalvageData Team
                By: Kristoff Rand
                • V Offline
                  valerostudio
                  http://www.carbonite.com/en/ $59 a year and it's unlimited. It takes a long time to backup the first copy, but at least you are protected against disasters as well.
                  • pbacotP Offline
                    Really sorry Kris. You still have our undying respect but I guess that's not quite enough at present... And you have the legacy of the projects that were built.
                    • Alan FraserA Offline
                      Alan Fraser
                      That's incredibly bad luck, Kris. I really feel for you...especially in view of the fact that you've been able to recover virtually nothing...and the thought of how this must be affecting your custom house plan business is truly terrifying.
                      You say you've lost the entire 14 years work. I know this is no consolation...but in the spirit of your original post (a lesson to others); how did you manage to go 14 years without backing up at all? By that, I mean...presuming that you have bought new PC systems in that time, how did you transfer the data from your old PC to its replacement?...or upgrade you OS? (I see you're now on Windows 7)
                      Do you still have any old machines lying around, or given to relatives, that might have been reformatted but not had too much new stuff loaded onto them yet? They might be recoverable, even if your work machine isn't.
                      3D Figures
                      • PixeroP Offline
                        Pixero
                        Sorry to hear.
                        Have you installed on top of the data or is the PC just saying the drive can't be read?
                        Why I ask is because I "lost" a drive that couldn't be read even by several recovery software.
                        Eventually it turn out that if I turned UAC off (in Windows Vista/Windows 7) and restarted.
                        It all came back.
                        • N Offline
                          notareal
                          Sorry to hear of your situation. We have got good results with Norman-Ibas data recovery. Part of http://www.krollontrack.com/ (pick your country from the list).
                          About recovery programs, GetDataBack for NTFS has worked well, if data is not badly overwritten or disk is not physically broken. http://www.runtime.org/data-recovery-software.htm
                            cadmunkey
                            Another vote here for "carbonite". Very cheap for the amount of storage you can get and its been a life saver for me on a couple of occasions. Also a handy feature is that you can remotely access all your backed up files no matter where you are in the world. Handy when you realise you left that all important client presentation back at home when your a thousand miles away!!
                            Data recovery specialists seem to be a licence to print money. I've never known anyone that has been able to recover data from a wiped/trashed hard drive. All you ever get is a large bill!
                            • 2 / 2
