    Exact effect of a 40 watt fluorescent light
    renderpluginsextensions
    29 Posts 9 Posters 8.5k Views 9 Watching
    • V Offline
      valerostudio
      So here is my testing on this. I did a quick box model and created a cylinder with an emitter materials applied to it. In the Vray rendering the tube has 2 rectangular lights emitting the light and in the Maxwell version the might is emitting solely from the material on the tube.
      • andybotA Offline
        andybot
        This is exactly illustrating the problem I have with vray. The edges of the area light create a shadow effect, you can see it in the end, and you can see a line along the floor too. This is why I want to have a linear ies type. Would make modeling fluorescent fixtures much simpler and better.
        • V Offline
          valerostudio
          Guess I never thought of that, you could grab and IES file for a tubular light. Andybot, if you have one, can you share with the class πŸ˜„ ?
          • andybotA Offline
            andybot
            Well, that's just the issue - ies as it is currently implemented in vray is a point source. The ies profile would have to be "stretched" along the length of the tube for it to represent a fluorescent bulb. You can only get sharp shadows from an ies source currently.
              rspierenburg
              So with the model shown above, what effect would you get if you completely incased the tube in 6 rectangular lights? Sort of a Cubic light if you will.
              • andybotA Offline
                andybot
                I played around with simple rectangular lights, here are some results. You can see the light pattern is different depending on how many facets you make with the rectangular lights. It ends up with a bit of a hotspot on the ceiling using 5 planes, I actually think the 3 planes turned out better. The thing I made different from what valerostudio showed above is that I made the rectangular lights much larger than the bulb in order to get a softer more spread out effect. I have the lights set as hidden in vray.
                • V Offline
                  valerostudio
                  Andybot, nice work. The thing that we need to disclaim here is that nothing we are showing you is the "exact" effect of a 40w bulb. I am fairly certain this cannot be done in Vray, unless I am wrong. You can give an light a Watts setting, but I dont think this is directly related to how a real bulb works. Someone correct me if I am wrong here.
                  • andybotA Offline
                    andybot
                    Correct, this is all approximate and relative. With IES files, there is actually a relationship to real values, but even then, the render engine uses an approximation (biased)
                      There is not a tool for that in Light Up ?
                      • V Offline
                        valerostudio
                        I have no experience with Light-Up but I think only an unbiased rendering engine will give you "real" world results.
                        • N Offline
                          nomeradona
                          if its using wattage then biased render cant replicate that.
                          • N Offline
                            nomeradona
                            andy that is cool tests.
                            • john2J Offline
                              john2
                              what is biased rendering and unbiased rendering??..and andybot. awesome effect. πŸ‘
                              Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                              • V Offline
                                valerostudio
                                I think this article has the basic answers to this question.
                                http://galaxycityradio.com/2012/01/04/biased-vs-unbiased/
                                • 2 / 2
