    Construction & Working Drawings - Discussion
    layout
    453 Posts 114 Posters 404.0k Views 114 Watching
    • pbacotP Offline
      Sonder,
      Elegant output!(I said that didn't I?) I see you are in Truckee, hence the Tahoe style houses. I am in Sonoma.
      Now, don't you find LO still cludgy on many 2d functions? I have so many great tools in my CAD for text, dimensions, manipulations, super easy lineweights and types etc...Take leader text for example: So limited in style and difficult to manipulate in LO. But I see your leader text doing things that I don't find in LO โ“ (Edit: I guess you just duplicate Scrapbook items--works).
      I never used AutoCAD, except in classes. I find PowerCADD is pretty cool. How is it you say they are having inaccuracies with AutoCAD and Revit?
      If I could make an interface that is LO connectivity (links and updating etc.) and PowerCADD tools... ๐Ÿ˜› I can pretty well put SU or LO output into PowerCADD but it's just a graphic (unless I bring the vector pdf or dwg and lose the SU textures, shading etc.) So I can't snap to anything.
      So I am one of those stuck between. I am still too fast in my CAD to run everything by SU. I use more apps all the time. Today I worked on a presentation. I used at least 7 apps directly and repeatedly.
      Keep up the good work and posting!
      Peter
      • mariochaM Offline
        mariocha
        Wow Sonder ! really good work.
        I see you are enjoying your work.
        I especially like the way you emphasized the foremost part of the house on elevations by downplaying the others parts. Is it made with a transparent overlay on the paper space ?
        %(#008000)[Mario C.
          sonder
          Hi Mario - this affect is Fog in SU so it is part of the reference drawing.
          • zx10r_GazZ Offline
            zx10r_Gaz
            Well, the last time I commented on this thread was back in 2009!!! and I have not really used SketchUp in any real way since I gave up on layout back then. But I have been using it for the last month or so mainly on the project below. It is a small domestic extension that is being adapted for disabled use. Its for a very good friend of mine who has no clue about reading 2D CAD plans and his Mrs is even worse!
            To cut a long story short I did the model in SketchUp so they could understand what was going on and have input. Then it came time to prepare for drawings to be done. I stuck with SketchUp only because I had invested a load of time and effort up to that point and didn't want to start from scratch in AutoCAD.
            Its taken be a good while to figure out Layout and how to get around things. I think I have spent more time in Layout than SketchUp, unlike AutoCAD where very little time was spent in paper space. I have found that the dimensioning side of things is utter rubbish. Why is it associated with the shape style dialog? Why has it got to have a dim format? I have to edit single dimension to get rid of the "mm" reference. The shape style would be 100% better if you could FILL with an image or tiled image as well as just plain colours. This would help massively on cross sections and with hatch patterns etc. Unless there is a way and I haven't figured it out yet?
            I'm still learning new bits & short cuts every day with layout. One thing I did find out is that it is easier to use 3 or so models instead of just one cluttered model with umpteen hidden layers/styles/scenes etc and reference each of the models at a specific stage of the drawings.
            If anyone has any tips on speeding things up, I'm all ears ๐Ÿ˜‰
            Gaz...
            http://www.drawingplans.co.uk/images/P1_1.jpg
            http://www.drawingplans.co.uk/images/P1_2.jpg
            http://www.drawingplans.co.uk/images/P1_3.jpg
            http://www.drawingplans.co.uk/images/P1_4.jpg
            http://www.drawingplans.co.uk/images/P1_5.jpg
              sonder
              I think those drawings are beautiful! - Especially sheets 3 & 4. While getting used to Layout does take time, I think the graphic output possibilities are far superior then ACAD drawings.
              Regarding Dimensions - I think I remember someone saying you can create your own template. I need to do this as well.
              Regarding Hatch - color is the only option right now. Hatches would be nice, but I do not mind the look of color transparencies to define "hatched areas".
              I am also finding that my output in raster set on high, prints extremely fine line work. Fine enough that I am foregoing vector output at this point. Doing so helps eliminate the need for hatch as you can define hatches and materials in the model that appear only in raster mode. Right now, I am leaning to only running vector drawings when I need to export an ACAD file for my poor structural engineers still using Revit and ACAD.
              • pbacotP Offline
                Gaz,
                Those drawings look great, and pretty bold to be using those 3d styles and artistic layout for construction drawings. 3d floor framing with shadows? Thanks for posting! Now I know better how boring my drawings are. (Once in a while I put in a 3d detail.)
                You guys may be interested in this: [Plugin] Hatchfaces (v1.6 beta) http://forums.sketchucation.com/viewtopic.php?f=323&t=38637&start=0&hilit=hatch+plugin
                Peter
                  zx10r_Gaz
                  Sonder,
                  Like you, It's still a big learning curve for me. Knowing what I know from this drawing I will tackle the next SU model/Layout differently. The output was also a bit of an issue for me. These drawings have had to be raster because of the styles & shadows etc, but exporting on HIGH level the PDF file was around 28Mb. The same file in AutoCAD would be around 700-800kb. So I have had to export MEDIUM (11Mb) just so I can submit it to the local authority (20Mb file size limit)
                  @Peter,
                  The 3D construction I spent a bit of time on. The reason is the "Blocks" I have created can be used unlimited times on future drawings except maybe the "roof lantern roof joist" I have even created all the wall straps, joist hangers, truss clips etc. So the next project will have these blocks inserted and just reference to from the SU model. So this should mean less work on future projects???
                  Thanks for the hatch plugin link, I will have a look at that. I must point out that I don't use any plugins, scripts or additional toolbars at all. I just use it out of the box and as is. Styles & materials are my only additions to SketchUp.
                  Gaz...
                  • O Offline
                    otb designworks
                    How are you guys dealing with printing 24x36 in color?
                    I use color codings with my shop drawings and the boys really like how it works. I have been putting everything on 8.5x11 sheets so we could print them easily. But, it is a whole lot more work making myriad small sheets instead of a few big ones and I would love to migrate to the larger format.
                    The local printer priced each 24x36 in color at $40 ๐Ÿ˜ฎ as opposed to $1.50 for standard laser printed greyscale.
                    Thoughts?
                    Cheers, Chuck
                    OTB Designworks is on Youtube
                    • pbacotP Offline
                      Thoughts?
                      Your local printers are behind a bit, not as expensive here (but grayscale is 2.50). If you wish to print yourself, look at HP111 series for an inexpensive but fine solution.
                      In these tight times, I print many jobs from my plotter and charge the same fee as the printers would. Prints are always reimbursable.
                      • pbacotP Offline
                        You submit pdf's? We are so backwards. Always wet signed paper here. Last week I saw a guy in the building dept. with a dolly full of multiple rolls of plans and boxes of calcs, and he was still going out for more stuff.We're not talking skyscrapers here. ๐Ÿ˜’
                        Gaz...
                        even more impressive!
                          sonder
                          Thoughts?
                          Hi Chuck:
                          That price they are quoting is insane. Are they using a plotter or an OCE printer or are they printing it black and white and using crayons? My cost from my local printer (and I live in the sticks) is $8 per sheet on 20lb stock. I also have a large format plotter that I use for in house use only. Otherwise everything gets printed at the shop and charged to the client as a direct cost. The only time I plot in full color is for the building department permit sets, the owner's set and one color set for the contractor. Otherwise everything is printed grayscale which still looks great.
                            sonder
                            @zx10r_gaz said:
                            Sonder,
                            Gaz...
                            Are you booking or creating individual sheets. I don't think my individual sheets hit the 20mb file size, but I will check. Reno, Nevada, where I do some work, also requires submission of PDF's instead of paper. Very smart and forward thinking. I wish more departments would use this. Heck all the contractors I work with often refer to the pdf drawings over paper.
                              Sawyer
                              Here are a couple more samples - Maybe show your office you are not alone in your thoughts. To me this was a no brainer and I have been using ACAD for more than 20 years.
                              Hey Sonder,
                              This work is really inspirational!!! I have been doing commercial interiors for about 12 years now. I took the entire summer to learn how to use SU/LO. I just took on my first residential remodel project and I am hoping to be able to do the entire set in SU/LO. I am definitely not going to be as efficient or as fast as I am working in ACAD.... But, I really want to push my abilities with SU/LO. One thing I have been really beating my head with are site plans. Your post is an amazing example of a site plan. Mainly because of the different line types and weights you are using. Are you drawing these in SU or LO? I originally drew my site plan in SU. But they are just solid lines. I know I can bring the model into LO and "explode" it and then convert the lines to different line types/weights in LO. But, this seems to really defeat the purpose. Can you share the method you are using to create your site plans? Thanks!
                              P.s. horrible snow fall this year huh?
                                sonder
                                Hi Sawyer:
                                Yes, snow is lacking badly. Looks like it will finally change towards the end of the week.
                                As for the site plan, the line work - property lines, setbacks, tree graphic & notation are all in Layout. Everything else is in sketchup. I generate all my site topography from drawings provided by a land surveyor. Since that work is imported into sketchup, it is a simple matter of copying it into LO. If you have the scale set, it comes in at the correct scale and easily pastes over the model since all the geometry exists in the model. It is still a work in progress for me also.
                                • pbacotP Offline
                                  Actually, Sonder, now that I think of it, I have no idea how you approach this. You copied objects in SU and set over the model in LO--getting linework you can modify with the shape style? I get different results if I do a copy from SU.
                                    sonder
                                    Yes that is correct. You copy line work from the SU model and paste it into Layout. When you do this, LO recognizes it as a SU model. You then set it as Vector rendering. Then you explode it. It remains grouped, and you can edit the line type through Shape Style as well as move the group together. This is especially helpful for property lines, setbacks and contour lines.
                                    The trick to make it easy, is you copy line work from the same scene that is saved in SU and is depicted in the specific LO drawing. That way when you paste it as an overlay in LO it retains orientation and scale, making for very easy placement. So if you have a scene named "Site Plan" in SU, make sure you are copying line work directly from the saved view. I typically use layers to isolate specific items like contour lines, setbacks and property lines, so it is really easy to isolate that line work in a specific scene for copying.
                                    There are a few steps, but it works really well. I hope that makes sense.
                                    • O Offline
                                      otb designworks
                                      Hi Chuck:
                                      Yeah, that was what I thought. It is a plotter printer they are using.
                                      Guess I need to look around and explore out of town options. Ah the joys of living in a small town:)
                                      Cheers, Chuck
                                      • O Offline
                                        otb designworks
                                        Thanks for the suggestion; I will look into that printer.
                                        Cheers, Chuck
                                        • pbacotP Offline
                                          Ah. That is the key element. Thanks! Peter
                                            Sawyer
                                            Thanks for the more detailed explanation! This helps alot!
                                            Cheers!
                                            Jonathan
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 22 / 23
