    Orthographic rendering in vray?
    renderpluginsextensions
    8 Posts 5 Posters 10.8k Views 5 Watching
    • john2J Offline
      john2
      i'm trying to render an elevation [orthographic view] of my building in vray with the physical camera on. but vray renders the front elevation in perspective. when i switch off the physical camera, the render turns out to be completely white..what should i do. ? im using the default settings for render
      Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
      • andybotA Offline
        andybot
        this may help:
        http://forums.sketchucation.com/viewtopic.php?f=322&t=37666
        • V Offline
          valerostudio
          Align View - set Field of View to 1.
          VRay cannot rendering ortho views and cannot render 2 pt perspectives... yet.
          • john2J Offline
            john2
            thanks πŸ˜„ ..is it the same way as when u click the magnifying glass and chnge the value from 35 degrees to 1?
            • chonC Offline
              chon
              Hello
              Are you sure of that ? I've made a test and no problem with 2 pts perspective mode ???
              • andybotA Offline
                andybot
                certain perspectives can work (2 pt is not the same as orthogonal). also, ortho does work with physical camera off. Problem then is less control over lighting and exposure.
                If you really want to test this, you can pan your 2pt perspective off center until it's very skewed and see if it still renders.
                • V Offline
                  valerostudio
                  If you want to render an elevation, I just go to that elevation, turn on perspective, change you field of view to 1 and render with the physical camera. FOV of 1 looks like an elevation.
                    Moni165454564
                    But after changing FOV to 1, render is extremly bright - nearly white. What set, change then?
