    Chose your deckchair
    16 Posts 12 Posters 971 Views 12 Watching
    • jarynzlesaJ Offline
      jarynzlesa
      i would like to know your opion on these deckchairs. which one of those would you buy in store?
      http://www.vizualizaceschodiste.mypage.cz/
      • irwanwrI Offline
        irwanwr
        the first one. if it comes with a parasol and someone else sitting on the next chair ๐Ÿ˜‰
        • Rich O BrienR Online
          Looks like the cushions would store smaller than the other alternatives.
          • soloS Offline
            Last one, looks most comfortable.
            I'd also suggest calling it a deck chair and not a deskchair as in title.
              sepo
              no 3
                jarynzlesa
                hi boys, thank you for your feedback ๐Ÿ˜Ž .
                this is supposed to be deckchair, not a deskchair - thank you solo for correction.
                the reason why i post this is that i would like to find the best upholstered option for this deckchair.
                it is a birthday gift for my friend (set - 2x deckchair and coffee table).
                i didnt design construction (very simple - reason why i chose it).deckchair_simple_construction.jpg
                i hope, i didnt do anything illegal (http://forums.sketchucation.com/viewtopic.php?f=15&t=42399).
                  2134 ๐Ÿ˜„
                  For number 4 there is no distinction between white background and cushion ! ๐Ÿ˜ฎ (on my screen monitor)
                  • daleD Offline
                    dale
                    For me its 4-3-2-1. 4 just looks so comfy!
                      steved
                      I like the cusions in the order 4,3,2. what an awsome birthday present! not bought, but built! ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                      Oh by the way it is only illegal if you comercialise it I an not a lawyer but that is my understanding ๐Ÿ˜‰
                      I have attached an image of a modification sugestion for your consideration. (Rear leg end point)
                      Can I sugest you do a visual where the cusion extends beyond the extent of the "slats" by say 30mm I think that would really work
                      "If I agreed with you on that, then we would both be wrong"
                      • irwanwrI Offline
                        irwanwr
                        2134 ๐Ÿ˜„
                        might need to set the brightness and contrast of your display probably ๐Ÿ˜›
                        • Z Offline
                          zapwizard
                          I like number 4 as long as the cushion doesn't end up sliding down.
                          However the others are a better technical design for outdoor furniture as they won't retain water.
                            steved
                            Design considerations for the cushion. The No 4 option is ok in regards to drainage (look at fabrics such as: Phifertexยฎ) the main concern is its ability to conform to the curvilinear surface without assistance other than gravity. This will depend on the fabric/filler combination. The articulated versions (smaller the better) would more readily conform to the surface. If you use a professional upholsterer they should know. If you can get the right materials combination for number 4 it will be cheaper as there is considerably less work in it. Might pay to employ ties or Velcro to force the cushion to conform to the surface form, for version 4, best of both worlds.
                            Cheers
                              Cherryni
                              I like the first one. ๐ŸŽ‰
                              • michaliszissiouM Offline
                                michaliszissiou
                                Agreed except... why sitting on the next chair? If you mean what I mean then 3,4 look more comfortable. ๐Ÿ˜ฎ
                                • irwanwrI Offline
                                  irwanwr
                                  ๐Ÿ˜† i knew what she meant to draw or design was really a deckchair. and that obviously an exterior furniture. that's why i prefer the first one. because it makes sense more to be an ext furniture.
                                  since it's an exterior furniture, climate and sun ray might come into consideration. ultraviolet for instance. in higher degrees of sun like near mid day or noon, might be better to have something as a partial cover from the sun. there's where the parasol may come.
                                  well, "someone else sitting on the next chair" was merely an intermezzo. since it might be good to spend some time just the two of, looking at scenery around. under the same parasol ๐Ÿ˜‰
                                  • F Offline
                                    FoXar
                                    I prefer 2 or 3, 2 looks especially more temporary to me and the cushion is easy to store compared to 4.
                                    Would love to see the finished product! ๐Ÿ‘
                                    Cheers!
