    Chose your deckchair
    16 Posts 12 Posters 1.6k Views 12 Watching
      2134 ๐Ÿ˜„
      For number 4 there is no distinction between white background and cushion ! ๐Ÿ˜ฎ (on my screen monitor)
      • daleD
        dale
        For me its 4-3-2-1. 4 just looks so comfy!
          steved
          I like the cusions in the order 4,3,2. what an awsome birthday present! not bought, but built! ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
          Oh by the way it is only illegal if you comercialise it I an not a lawyer but that is my understanding ๐Ÿ˜‰
          I have attached an image of a modification sugestion for your consideration. (Rear leg end point)
          Can I sugest you do a visual where the cusion extends beyond the extent of the "slats" by say 30mm I think that would really work
          "If I agreed with you on that, then we would both be wrong"
          • irwanwrI
            irwanwr
            2134 ๐Ÿ˜„
            might need to set the brightness and contrast of your display probably ๐Ÿ˜›
            • Z
              zapwizard
              I like number 4 as long as the cushion doesn't end up sliding down.
              However the others are a better technical design for outdoor furniture as they won't retain water.
                steved
                Design considerations for the cushion. The No 4 option is ok in regards to drainage (look at fabrics such as: Phifertexยฎ) the main concern is its ability to conform to the curvilinear surface without assistance other than gravity. This will depend on the fabric/filler combination. The articulated versions (smaller the better) would more readily conform to the surface. If you use a professional upholsterer they should know. If you can get the right materials combination for number 4 it will be cheaper as there is considerably less work in it. Might pay to employ ties or Velcro to force the cushion to conform to the surface form, for version 4, best of both worlds.
                Cheers
                • C
                  Cherryni
                  I like the first one. ๐ŸŽ‰
                  • michaliszissiouM
                    michaliszissiou
                    the first one. if it comes with a parasol and someone else sitting on the next chair
                    Agreed except... why sitting on the next chair? If you mean what I mean then 3,4 look more comfortable. ๐Ÿ˜ฎ
                    • irwanwrI
                      irwanwr
                      ๐Ÿ˜† i knew what she meant to draw or design was really a deckchair. and that obviously an exterior furniture. that's why i prefer the first one. because it makes sense more to be an ext furniture.
                      since it's an exterior furniture, climate and sun ray might come into consideration. ultraviolet for instance. in higher degrees of sun like near mid day or noon, might be better to have something as a partial cover from the sun. there's where the parasol may come.
                      well, "someone else sitting on the next chair" was merely an intermezzo. since it might be good to spend some time just the two of, looking at scenery around. under the same parasol ๐Ÿ˜‰
                      • F
                        FoXar
                        I prefer 2 or 3, 2 looks especially more temporary to me and the cushion is easy to store compared to 4.
                        Would love to see the finished product! ๐Ÿ‘
                        Cheers!
