    [Plugin] Export Batch DAE
    29 Posts 7 Posters 48.0k Views 7 Watching
      driven
      hi TIG,
      I've got a reasonably stable set of well organised plugins that don't interfere with my launcher app.
      if I add anything ropey it usually interferes with my launch so I eliminate or fix it first.
      most of the rubies are in additional folders and I just load them when I need to use them, I have some of yours, thomthom's, jim's and chris's and fredo's in the wild and these are the floating toolbars that I use all the time.
      I also have some of the oldtimers like weld, rotated rectangle, mesh additions, etc...
      the only installed ones that ever play up are EEby Vector to Obj [if I extrude bezier curves] and a couple of webDialog issues with the latest version of Safari.
      it really does appear to be something to do with this, so I'll clarify what happens.
      if I open SU and 'save' the empty file, and then use 'Export Batch DAE' everything works and on completion SU stays open, if I then quit SU and reopen I still have my 'floating toolbars'
      if I don't save the initial file, on completion SU closes itself and when I reopen my 'floating toolbars' have gone.
      my 'custom toolbar' remains intact in both scenarios...
      CHANGE OF PLAN
      removed almost all to test
      ok, problem still persists... and I also tested without tt_shell...
      I don't actually have a current use for this plugin, I'm just mac testing it out of curiosity...
        From your description the code that runs if you didn't have a 'saved' SKP open when you started exporting is Sketchup.send_action('terminate:')
        On the PC that line closes the window belonging to the last SKP exported.
        However, if the open SKP had been saved before exporting then it's reopened again, so the last SKP exported window closes.
        Perhaps the ' terminate:' code on a MAC behaves differently from a PC...
        Change the line
        to
        ###Sketchup.send_action('terminate:') UI.messagebox('Please close this last SKP window manually!')
        The last exported SKP stays open and you are asked to close it yourself
        Retry - it shouldn't then affect your toolbars ??
        Of course the simple trick to avoid this is to open one of the SKPs in the folder of SKPs you want to batch-export, then the folder selection jumps to that folder as the start point and you select any SKP + OK and you are off and running - the originally opened SKP is reopened on completion...
          driven
          tried that,
          toolbars remain intact, but none of the windows are closed by SU, you need to manually close them all.
          one of the reasons for my interest is your use of Sketchup.send_action('terminate:')
          as I was hoping to use it in something else.
          it seems quite stable when used on it's own from Ruby Console with 'saved', 'un-saved', 'individual' or 'multiple' skp's.
          I currently use an shell script killall SketchUp in a couple of things, but have to run a separate app to send it [as SU won't] and I also keep looking for a less harsh way to instantly 'close all' when a process is taking far longer then the results warrant.
          • RoidsanR
            Roidsan
            Quick Newbie question 👊 -Can't find an answer with multiple searches, so I guess I have to ask, what does DEA refer to?
            Everything's alright now, the photographer's here.
              😒 "DEA" is an unknown file type!
              I suspect you meant "DAE" [as in this exporter] which is the Collada file format [developed by Sony Computer Entertainment and the Khronos Group]; it is short for "digital asset exchange", it's an 'xml' format; it's now widely used for 3d data transfer - similar to DXF - it is also very similar to Google Earth's own .kmz file-format etc.
              • RoidsanR
                Roidsan
                Thank you TIG for the answer AND your patience. 😄
                  😄 That's OK, I suffer fools gladly, as I am one on occasion!
                    davdup
                    Hi TIG,
                    Thanks a lot for all your plugins!
                    I managed to adapt this one to be able to batch export skps into OBJ files, but I still have to clic "OK" on the "OBJ Export Results" popup to move to the next file, which is a little bit annoying for a batch process! 😄
                    And of course I don't know how to code this to do it automatically... could you or anyone else help me? Thanks!
                    David
                      @davdup said:
                      Hi TIG,
                      I managed to adapt this one to be able to batch export skps into OBJ files, but I still have to click "OK" on the "OBJ Export Results" popup to move to the next file, which is a little bit annoying for a batch process! 😄
                      David
                      IF you had posted your script we might be better able to see where it needs fixing !
                      However, using my super-powers of clairvoyance I suspect that you need code along these lines...
                      model.export(objpath, **false**)
                      which might help - the second argument controls the appearance of the prompt in all exports other than DAE, which can take an 'options-hash' - OBJ can't take a 'hash' [it uses Sketchup's 'current-settings'] - so if you pass a 'hash' the exporter sees it as just 'true', and so it pops up the report each time !
                        davdup
                        Here is the script!
                        model.export function already has a second argument... perhaps changing the last two variables (double_precision, vertex_normals) or adding a new one can help?
                        OBJ batch export script, adapted from TIG's DAE export script
                          You missed my point entirely. 😕
                          You can't pass an 'options-hash' to the exporter... UNLESS it's exporting a DAE file.
                          All of your code/dialog about getting settings for the OBJ is wasted.
                          The OBJ exporter always uses the last used Sketchup OBJ export options.
                          Your code won't affect those and is a waste of time/effort.
                          What it does do is pass 'something' other than 'false' to the exporter, which it then interprets as 'true', so the 'report' dialog pops up each time !
                          The settings in the hash are simply ignored !
                          Its easier than you've made it - just use
                          opts=false
                          it will work without the reports interrupting BUT you need to have the OBJ options set first.
                            davdup
                            Oh I just realized this digging into the Sketchup API reference! 😳
                            So no hash for exports except DAEs. I simply replaced the "opts" parameter with "False" and everything works fine... You just have to set the OBJ export parameters right before running the script.
                            Anyway, thanks a lot again! This will save me a lot of clics! 😉
                            I attached the "revised" cleaned up script if anyone needs it!
                            David
                            Batch OBJ export script
                              riberholt
                              I'm looking for a script that will batch convert files from 3ds to dae format using sketchup.
                              I have found this script in an old thread
                              #convert skp to obj
                              #every thumb is putted in a created dir with name of related skp model's name
                              #skppath is the residence of skpfiles
                              require 'sketchup.rb'
                              if(not file_loaded?("skp2obj.rb"))
                                  plugins_menu = UI.menu("Plugins")
                                  plugins_menu.add_item("skp2obj") {file_export}
                              file_loaded("skp2obj.rb")
                              def file_export
                              #skp file path
                              #beware the end "/" e.g. skppath ="c;\skp"
                              skppath ="C;/Program Files (x86)/Google/Google SketchUp 8/"
                              #open dir and loop all skps
                              dir = Dir.open(skppath)
                              begin
                                dir.each {|x|
                                     next if x !~ /\.skp$/i
                                     x = "#{x}"
                                     sourcefile = skppath+x
                                     x = x[0,x.length-4]
                                     destdir = skppath + x + "/"
                                     destfile = destdir + x +".obj"
                                       #mak dir
                                     Dir.mkdir(destdir)
                                     #open modle file
                                     Sketchup.file_new
                                       status = Sketchup.open_file sourcefile
                                       if (!status)
                                         UI.messagebox "error; " + sourcefile
                                    #export obj
                                       status = Sketchup.active_model.export destfile
                                       if (!status)
                              ensure
                                dir.close
                                  UI.messagebox "Finished"
                              and tried to modify it to import and export
                              #convert skp to dae
                              if(not file_loaded?("3ds2dae.rb"))
                                  plugins_menu.add_item("3ds2dae") {file_export}
                              file_loaded("3ds2dae.rb")
                              def file_export
                              #skp file path
                              #beware the end "/" e.g. skppath ="i;/skp/skptest/model/error/"
                              skppath ="C;/skp/"
                              begin
                                dir.each {|x|
                                     x = "#{x}"
                                     x = x[0,x.length-4]
                                     destfile = destdir + x +".dae"
                                       #make dir
                                     Dir.mkdir(destdir)
                                     #open model file
                                     Sketchup.file_new
                                       status = model.import sourcefile
                                       if (!status)
                                    #export dae
                                       if (!status)
                              ensure
                                dir.close
                              But it seems my RubyFU is not strong enough. Any help would be appreciated.
                                I think this will only work on pro..
                                <span class="syntaxdefault">require </span><span class="syntaxstring">'sketchup.rb'<br /></span><span class="syntaxdefault">module TIG<br />def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">makeDAEfrom3DS</span><span class="syntaxkeyword">()<br /></span><span class="syntaxdefault">  model</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />  view</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_view<br />  cam</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">camera<br />  eye</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">cam</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">eye<br />  target</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">cam</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">target<br />  up</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">cam</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">up<br />  import</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">openpanel</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Select 3DS File..."</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> Dir</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">pwd</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">".3ds"</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  return nil unless import </span><span class="syntaxkeyword">&&</span><span class="syntaxdefault"> File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">extname</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">import</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">downcase</span><span class="syntaxkeyword">==</span><span class="syntaxstring">".3ds"<br /></span><span class="syntaxdefault">  import</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">tr</span><span class="syntaxkeyword">!(</span><span class="syntaxstring">"\\"</span><span class="syntaxkeyword">,</span><span class="syntaxstring">"/"</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  dir</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">dirname</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">import</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  dae</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">basename</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">import</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">".*"</span><span class="syntaxkeyword">)+</span><span class="syntaxstring">".dae"<br /></span><span class="syntaxdefault">  export</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">join</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">dir</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> dae</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  puts import<br />  puts </span><span class="syntaxstring">"TO"<br /></span><span class="syntaxdefault">  puts export<br /> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start_operation</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"makeDAEfrom3DS"</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  ents</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities<br />  ents</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">clear</span><span class="syntaxkeyword">!<br /></span><span class="syntaxdefault">  model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definitions</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">purge_unused<br />  model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">materials</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">purge_unused<br />  model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">layers</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">purge_unused<br />  model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">styles</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">purge_unused<br />  model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">import</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">import</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> false</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">select_tool</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">nil</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  tr</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Transformation</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_instance</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definitions</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">],</span><span class="syntaxdefault"> tr</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">export</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">export</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> false</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">send_action</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"editUndo;"</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">send_action</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"editUndo;"</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">send_action</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"editUndo;"</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  view</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">camera</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">set</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">eye</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> target</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> up</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"> model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">abort_operation<br />end</span><span class="syntaxcomment">#method<br /></span><span class="syntaxdefault">end</span><span class="syntaxcomment">#module &nbsp;</span><span class="syntaxdefault"></span>
                                Usage: open a SKP and in the Ruby Console type [or copy+paste] TIG.makeDAEfrom3DS + <enter>. Choose the 3DS file + OK. The SKP's contents are 'removed temporarily', and the 3DS is then imported, it is then exported as a DAE file with the same location, name etc, but with a .dae suffix, the SKP's contents and view are restored on completion. The current 3DS import and DAE export settings are used. You can expand this to use a custom settings-hash, or process files in a batch form without the dialogs etc...
                                • G
                                  glro
                                  @tig said:
                                  Select one SKP from a folder of SKPs to be exported, then OK.
                                  would it be possible to export all skp files in a folder AND subfolders?
                                    Of course... with the right code... 😒
                                      @rasmusl said:
                                      Dear TIG
                                      Sorry, I am completely new to this and I am looking for a batch conversion of 3ds to dae.
                                      I see that you have already the batch export from skp to dae and I guess that the below code would do the trick. However I am completly incapable of joining the information into something that works. May I kindly ask you to do this? I will be super grateful if you will help me.
                                      Is it possible to modify this script to batch import 3ds files instead of skp and export to dae? (and how?)
                                      Reason for asking is that I have more than 1000 3ds files that I need in 3rd party software and I need to have the sketchup version of dae.
                                      I posted some example code that does [could do] exactly this... it's in another post from earlier today... do a Search...
                                        RasmusL
                                        Dear TIG
                                        I see that you have already the batch export from skp to dae and I guess that the above code would do the trick. However I am completly incapable of joining the information into something that works. May I kindly ask you to do this? I will be super grateful if you will help me.
                                          RasmusL
                                          I think it is in this topic, from 4:32 today?
                                          I tried it, but how do I get it to loop through all the 3ds files like a batch.
                                            Get the user to choose one 3DS file in the folder.
                                            Currently the code uses the returned file path.
                                            BUT let's say we have the returned
                                            filepath=UI.openpanel(...)
                                            From that you can find
                                            folder=File.dirname(filepath)
                                            [There's currently no API UI.getfolder() method... 😞 ]
                                            From the folder you can find all of the 3DS files...
                                            There are several ways, e.g...
                                            files=[] Dir.entries(folder).each{|f|files << File.join(folder,f) if File.extname(f).downcase==".3ds"}
                                            Now we have an array of all 3ds files in that folder...
                                            Each array element is a full path...
                                            Use a 'batch' process like this...
                                            ` files.each{|file|
                                            ALL OF THE CODE TO IMPORT/EXPORT '3ds file' GOES HERE...
                                            Unless you want to pay to have a properly written script I'll leave it there... 😒
                                            Hint: to process files in subfolders do something similar to the above but this time make a list of all folders in the 'selected' folder, then iterate through the contents of each of those in turn, adding any 3ds files to the array for the ultimate batch processing 😉
                                            Please be wary - I have typed this from memory, so it's untested... 😲
