    Too many plugins
    42 Posts 16 Posters 5.5k Views 16 Watching
    • V
      Vicspa
      Does anyone know at what point do some plugins start to grey out?
      My plugins folder is now at 1.10 GBs but all are working fine. I did have the greyout problem before, but I removed some unused ones and solved the problem.
        On a very old computer (only one giga, near ten years) I begin to have problems with more 500 scripts ! ๐Ÿ˜‰
        I am mad scripts testor ๐Ÿ’š
        • V
          Vicspa
          Hi Pilou, my plugins folder at this time has 7,057 files, 383 folders
            When the SketchUp has allocated 1000 UI::Command objects.
            What on earth do you have in your plugins folder??? Plugins are mostly just plain text files - with the occational folder with cursor, icon and webdialog resources. In no way can I see how any of that makes to to 1GB!!! ๐Ÿ˜ฒ ๐Ÿ˜ฎ ๐Ÿ˜•
            Sounds to me that your plugins folder is in dire need of some cleaning up.
            I've stopped copying my plugins folder around when I format my computer. Instead I just start to add plugins again - that way I make sure I only have the plugins I use.
            • V
              Vicspa
              thomthom, I gotta admit to being a plugin junkie, ๐ŸŽ‰ and yeah I got way too many that I do not use, ๐Ÿ˜• I made a new year's resolution to better manage them. ๐Ÿ˜›
              You guys just gotta stop making them, I'm joking of course.And thanks by the way. ๐Ÿ‘
              • sdmitchS
                sdmitch
                A very useful plugin to add to your collection.
                404 Not Found
                (forums.sketchucation.com)
                http://sdmitch.blogspot.com/
                • V
                  Vicspa
                  Thanks sdmitch, I'm in the process of cleaning out my plugins folder, got it down to only 100 megs so far. ๐Ÿ‘
                  It seems that when a new version of a plugin came out, I installed it without deleting the old one, and some had several versions in there. Now to solve the "error loading" window that comes up opening SU. I got my work cut out for me.
                    What message is it?`It should give good leads to where the error is.
                    • V
                      Vicspa
                      Here Thomthom, how do I resolve this?
                      • L
                        lapx
                        Is there a Plugins anonymous I can attend? 175mb, 3747 files, 164 folders!
                        And I have not resolved my greying issues, either in my beard or my rubies ๐Ÿ˜ž
                        • V
                          Vicspa
                          Hey Lapx, maybe I can be your sponsor in PA (Plugins Anonymous). ๐Ÿ˜†
                          The beard greying issues can be resolved with beard dye, at least temporarily. Believe me I know.
                          See avatar on left.
                          • L
                            lapx
                            Well Thanks ๐Ÿ˜„
                            I'm trying to clean up my folder again! Here are images of my current plugin floder. Can I delete what appears to be duplicate folders ie.
                            Fredos folders with diff numbers? I assume the higher number is the lastest and the greatest.
                            Thanks,
                              TT_Lib2 does not replace TT_Lib! TT_Lib version 1 is required by Selection Toys.
                              • L
                                lapx
                                Thanks Tom,
                                What about Fredo's stuff? Am I doubling up on his rubies ๐Ÿ˜„
                                • charly2008C
                                  charly2008
                                  I think this is the only option. I had problems for several days and "BugSplat" with "SKP 7" and "SKP 8". After I disabled the plugins folder in each case, both versions ran flawlessly.
                                  I decided to reinstall both programs. I have the same plugins as before. These I had already reduced to the actually needed "plugins". My plugins folder contains currently 42 plugins folders and 137 plugins. The size of the plugin folder is now 27.1 MB. I think with any additional plugin increases the risk that in the system at some point gets something out of control.
                                  At 137 plugins, I also have a relatively good overview of the capabilities of the plugins. With a larger number, this is always difficult, especially when they are little or hardly used.
                                  Charly
                                  • fredo6F
                                    You normally keep only the folders with the highest number and safely delete the others.
                                    Since LibFredo6_40, you have a menu to purge the obsolete files and folders (go to Windows --> LibFredo6 Settings.... > Purge Obsolete Files. Also the ZLoader_xxx.rb files are no longer useful.
                                    • L
                                      lapx
                                      Thanks Fredo!
                                      BTW Fredo,
                                      I tried to use your menu to delete the folder and files without success so I deleted the noted files manually.
                                      Still a major help.
                                      Thanks again!
                                      • emerald15E
                                        emerald15
                                        Oh good! That answers my question too - having been advised to have a clean up (TIG). After just a little bit of clearing I'm down to 18MB (13 plugins) & all non-essential extensions dutifully disabled. Actually, I was only keeping them all open in order to learn to use them when ever possible!
                                        • fredo6F
                                          @lapx said:
                                          BTW Fredo,
                                          Still a major help.
                                          Thanks again!
                                          Strange! Did you get messages in the Ruby console?
                                          • L
                                            lapx
                                            Fredo,
                                            so very sorry I'm getting back to you late. Your plugins are working fine. Don't know what the problem was back then. But it appears that the deletion is working.
                                            Thanks so much!
                                            • 2 / 3
