    Shape bender problem
    14 Posts 5 Posters 1.0k Views 5 Watching
      steved
      Hi I have attached the ruby script text image. I am trying to activate the straigt line on the red axis but I can do this till the cows come home to no avail.
      I assume it is normal for the ruby script to scroll like crazy when I use the mouse.
      I reiterate that I have not seen the "progress bar" plugin however it does exist in my SU plugin folder. But does not show in my plugin dropdown when i am in SU.
      Thanks Guys
      "If I agreed with you on that, then we would both be wrong"
      • mitcorbM
        mitcorb
        Hi.
        You keep mentioning the uncertainty about the progressbar.rb Have you tried reinstalling it?
          steved
          I have reinstalled "progress bar" shut down SU opened it and no change. I guess one question I am asking is: Should the "progress bar" appear in the SU plugins drop menu? at least if I know that I can start narrowing it down.
          • GaieusG
            No, it should not. It just runs in the background. And the error message should give some clue if that were the issue.
              steved
              Thanks, I am not getting an error though it simply will not let me select the straight line and thats as far as it goes 😕
              • GaieusG
                Well, there is an error message in the ruby console. I cannot interpret it however...
                  The error is telling you that it can't find files needed to make cursors etc...
                  Therefore it fails.
                  As well as the separately got/installed progressbar.rb... your installation in the Plugins folder should look like this:CaptureLoader.PNGand the subfolder like thisCaptureSubfolder.PNG
                  Are all of the required files in the subfolder ?
                  If so then are you sure you have full-access permission to that folder and that you have installed the files/subfolder properly - e.g. is there a 'Compatibility Files' button on the top bar of the Plugins folder window ? If so Vista might have protected you from yourself and although it lets you think files were installed it's put them into a 'side-folder'... move them back and ensure you have full-rights to the Plugins/Components/Materials/Styles folders... [right-click each folder's icon > properties > security...]
                    Incidentally if you have not installed files/subfolder in the standard Plugins folder, but have added another folder to the $LOAD_PATH then the main .rb will load from the subfolder because the 'loader' .rb looks directly at the subfolder from wherever it is based... but then you need to adjust the lines of code in the main .rb file thus:
                    def make_cursors
                    	line_cursor_path = Sketchup.find_support_file("line_pointer.png", "Plugins/clf_shape_bender")
                    	curve_cursor_path = Sketchup.find_support_file("curve_pointer.png", "Plugins/clf_shape_bender")
                    	default_cursor_path = Sketchup.find_support_file("default_pointer.png", "Plugins/clf_shape_bender")
                    which expect a standard Plugins folder location... becomes
                    def make_cursors
                    	line_cursor_path = File.join(File.dirname(__FILE__), "line_pointer.png")
                    	curve_cursor_path = File.join(File.dirname(__FILE__), "curve_pointer.png")
                    	default_cursor_path = File.join(File.dirname(__FILE__), "default_pointer.png")
                    which will work in any setup provided those png files are in the same folder as the main .rb file...
                      steved
                      def make_cursors
                      def make_cursors
                      Thanks Tig, but I tried real hard to understand what you said but most of it went over my head.
                      Have attached an image of what the files look like. I have a few plugins, never had an issue before.
                        OK - you have the dreaded "Compatibility Files" 'button' in the strap-line on top of the Window for the Plugins folder.
                        This suggests you have insufficient permissions to add files/subfolders into Plugins and Vista is protecting you from yourself.
                        Click on that 'button' and see what's NOT been installed...
                        It's an annoying Vista feature as it gives little indication that things didn't go as you hoped.
                        I suggest you select the Plugins folder icon, right-click > properties > security and give yourself full permissions to the folder [repeat for other folders you might want to work in like Components/Materials/Styles]...Capture.PNG
                        I assume that the 'clf_shape_bender' icon that I can see inside Plugins is the zip file and not the required folder ?
                        Why not adjust 'folder-options' to show all file-extensions - it makes life much easier if you don't use 'details' view for folders...Capture1.PNG
                          steved
                          Thanks Tig, very much appreciated!
