    [Plugin] Slicer5
    338 Posts 83 Posters 408.0k Views 82 Watching
    • cottyC
      cotty
      @tig said:
      Some options are only available to 8-Pro users.
      Are these advanced options or are the basic functions affected?
      my SketchUp gallery
      • kenK
        ken
        Is it possible to make the selection in % of total instead of a set length. This was one could get 50%, 25% or 10% cut for viewing. With this option, a 50% cut would divided the section into two parts.
        Thank you in advance
        Ken
          Please [re]read the notes...
          Firstly it only works on v8+ because it now needs 'manifold solids' to work correctly...
          It now has built-in one-axis slicing or two-axes slicing with optional slotting and dogboning; and flattening of slices, which can then be exported as individual PNG image files etc...
          Additionally v8-PRO users can now export consistently structured DXF files of each individual slice for CNC work...
          Also all users can now benefit from the slices which are now made as components - so editing a flattened one changes the assembled ones too, AND if desired they could also export these slice-components as individual SKP files in a new 'collection'...
            ...Is it possible to make the selection in % of total instead of a set length. This was one could get 50%, 25% or 10% cut for viewing. With this option, a 50% cut would divided the section into two parts.
            ...Ken
            'fraid not - but a little measuring and a calculator should give you the values to enter to get the same result...
            It's a slice-maker - not 'Zorro'... πŸ˜•
              sepo
              TIG, it works fine. I know that currently geometry has to be manifold and group or component, but is there a way that group/component could be made of subgroups or subcomponents.
                If a selected group/instance doesn't show as 'Solid' in the 'Entity Info' dialog then it will fail.
                It's no great hardship to copy selected objects off to one side and edit them...
                before Slicer5 runs on the selected object...
                If necessary you must explode inner groups/instances and tidy up loose-edges/partitions etc.
                My SolidSolver and Thomthom's Solid-Inspector tools can help you fix 'non-solid' objects...
                πŸ€“
                  sepo
                  Yes I understand that. I was really thinking in terms of having SU model of say site with several houses sliced for arch model. It is not always easy to make every bit of model perfect.
                  • X
                    xrok1
                    SWEET! thanks TIG! you're the best of the best. 😍
                    • X
                      xrok1
                      Oh wait... 😳 I thought this was slice modeler. 😳
                      Well its still great. Just not as... You're still the best but slice modeller would be 1 step higher. πŸ˜‰
                        I'm no sure I understand you ?
                        It's not SliceModeller - which is an old tool that someone else made from my original Slicer.
                        It's my "Slicer5" - which is superior.
                        It has more robust algorithms.
                        It has most of the same options as Slicer, plus many additional ones.
                        It makes plain Slices if you choose an X/Y/Z axis option.
                        It makes slotted Slice sets IF you choose one of the dual-axis options XY/XZ/YZ, and confirm you want slotting, optionally these slots can then be 'dogboned' for CNC cutting.
                        There are also 'Export' options to save the Slices as 2d PNG images, and for Pro users DXFs, consistently structured for CNC use...
                          Here's v5.1 http://forums.sketchucation.com/viewtopic.php?p=374969#p374969
                          Slicer5 Exporter tool added.
                          This additional tool now allows you to Export Slices later on from a selected FLAT-1234 set.
                          So after Slicer5 makes the Slices you can edit them [e.g. move Text-tags or edit Slices' geometry] before doing a [re]Export as PNGs [or DXFs for Pro-users]...
                          • kenK
                            ken
                            ...Ken
                            Well thanks for looking at request.
                            Thank you for all your plugins.
                            Ken
                            • B
                              boilingsnow
                              Similiar to Slicemodeler...
                              Any new functions?
                                Any new functions?
                                Read the Notes ! πŸ˜’
                                  Here's v5.2 http://forums.sketchucation.com/viewtopic.php?p=374969#p374969
                                  Please [re]read the notes because a lot of new functionality has been added.
                                  5.1 Slicer5 Exporter tool added.
                                  5.2 New Spacing2/Thickness2/Insets'2/Tolerance dialog added - this now lets you have dual-axis Slice sets with different spaces/thickness and insets at the start/end AND slotting etc.
                                  The new Tolerance feature allows you to oversize the slots slightly for CNC cuttingm for an easy fit of panels [e.g. 0.2mm].
                                  The Slot ? option [Yes/No, to slot or not to slot] and an Overcut [dog-boning] options are also added to the same new dialog - entering anything > 0 for this will then ease the slot ends where the CNC router-bit rounds off the slots' internal corners and prevents a perfect mating of slots, so that then the overcut slots will fit together neatly.
                                  Entering a Spacing of '0' now opens another dialog where you can enter the number of Spaces required, rather than using a fixed Spacing: this also works independently for the two Slice-sets when using dual-axes, so one axis can have 2 Spaces [3 Slices] while the other axis has 8 Spaces [9 Slices]...
                                  Tip: to adjust which is the first of the made/slotted Slice-set [XY/XZ/YZ] rotate the Sliced Object in 3d so its X [or Y] direct matches the first set required...
                                  Hopefully it's now approaching AutoCAD-123d in the 'slice-slot-modeling' department...
                                  The solid side for 3d printing is a separate issue...
                                  • jim smithJ
                                    jim smith
                                    Thank you for the update TIG and Happy New Year!
                                    "Out of clutter find simplicity,
                                    from discord find harmony,
                                    In the middle of difficulty lies opportunity"
                                    Albert Einstein
                                    • guanjinG
                                      guanjin
                                      I just change my language, you have upgraded, I really admire, rapidly! πŸ‘ πŸ‘
                                      • guanjinG
                                        guanjin
                                        I use the slice, the second parameter set, waiting for a long period of time slices, the reason is the operation?
                                        The exported file Where can I find?
                                        Thank you TIG!
                                          @guanjin said:
                                          I use the Slicer5 tool, with the second parameter set; I waited for a long time for the Slices - the reason is the [number of] operations ?
                                          The exported files... Where can I find them?
                                          A form that is that complex with slots etc WILL take a long time to process all of the parts...
                                          It looks like it failed - because there are no proper slots made***.
                                          Is the sliced object very small ?
                                          If you have exported the files initially [OR you do it later] the PNG files are put into their own folder in the same folder as the SKP itself - read the Notes about its naming etc [if you use Pro the DXF files are in another similar folder]. Ensure your SKP's folder has security-rights to be written to by all, so the folder get made.
                                          ***Keep the Ruby Console open for any error messages IF it's not working as you expected...
                                          • I
                                            ivreich
                                            Hi TIG
                                            I'm experiencing some problems as well. The slots aren't properly cut, faces are deleted etc. I've attached the file for you to look at.
                                            Cheers,
                                            Joel
                                            File for TIG
                                            • 16
                                            • 17
                                            • 1 / 17
