    Component parts disappearing
    4 Posts 2 Posters 173 Views 2 Watching
    • I Offline
      IronLogic
      Hello Forum,
      Attempting to create metal piece components for welding projects. Have created a few Angle Iron pieces, but then I created one with a 45 degree slice on one end from one of the previous components and saved it as a different component.
      Problem is when I delete the previous components it also deletes parts from the new component. Does one have to create a component from scratch without saving it till it is completed?
      Lot of work having to redo.
      Thanks in advance for an explanation.
      Pablo
      Simplicity is the Ultimate Sophistication. ~ Leonardo Da Vinci
      • mitcorbM Offline
        mitcorb
        Hi, IronLogic:
        If I understand your concern correctly, try this:
        If you have created a component, and you wish to make a different component based on the original, make a copy with Move+Control. Then right click on the new copy, select from the context menu "Make Unique". Edit this new unique component as you wish. It will have no effect on the others.
        • I Offline
          IronLogic
          Thank you for the reply mitcorb,
          I made the copy of the component & made it unique. It was added to the outliner with a # instance. Tried to rename it via the Outliner dialog box, but it would add my name to the name already there. I then renamed it in the Entity Info dialog box and the name in the Outliner showed up fine.
          Thanks for the help.
          • mitcorbM Offline
            mitcorb
            And the description of what you did in your reply is yet another lesson, or reminder for me. So, Thank you.
