<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Component parts disappearing]]></title><description><![CDATA[<p dir="auto">Hello Forum,</p>
<p dir="auto">Attempting to create metal piece components for welding projects.  Have created a few Angle Iron pieces, but then I created one with a 45 degree slice on one end from one of the previous components and saved it as a different component.<br />
Problem is when I delete the previous components it also deletes parts from the new component.  Does one have to create a component from scratch without saving it till it is completed?</p>
<p dir="auto">Lot of work having to redo.</p>
<p dir="auto">Thanks in advance for an explanation.</p>
<p dir="auto">Pablo</p>
]]></description><link>https://community.sketchucation.com/topic/132149/component-parts-disappearing</link><generator>RSS for Node</generator><lastBuildDate>Sat, 07 Nov 2026 04:04:46 GMT</lastBuildDate><atom:link href="https://community.sketchucation.com/topic/132149.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 26 Dec 2011 15:33:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Component parts disappearing on Tue, 27 Dec 2011 02:29:07 GMT]]></title><description><![CDATA[<p dir="auto">And the description of what you did in your reply is yet another lesson, or reminder for me.  So, Thank you.</p>
]]></description><link>https://community.sketchucation.com/post/1298335</link><guid isPermaLink="true">https://community.sketchucation.com/post/1298335</guid><dc:creator><![CDATA[mitcorb]]></dc:creator><pubDate>Tue, 27 Dec 2011 02:29:07 GMT</pubDate></item><item><title><![CDATA[Reply to Component parts disappearing on Mon, 26 Dec 2011 23:27:00 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for the reply mitcorb,</p>
<p dir="auto">I made the copy of the component &amp; made it unique.  It was added to the outliner with a # instance.  Tried to rename it via the Outliner dialog box, but it would add my name to the name already there.  I then renamed it in the Entity Info dialog box and the name in the Outliner showed up fine.</p>
<p dir="auto">Thanks for the help.</p>
]]></description><link>https://community.sketchucation.com/post/1298329</link><guid isPermaLink="true">https://community.sketchucation.com/post/1298329</guid><dc:creator><![CDATA[IronLogic]]></dc:creator><pubDate>Mon, 26 Dec 2011 23:27:00 GMT</pubDate></item><item><title><![CDATA[Reply to Component parts disappearing on Mon, 26 Dec 2011 18:17:02 GMT]]></title><description><![CDATA[<p dir="auto">Hi, IronLogic:<br />
If I understand your concern correctly, try this:<br />
If you have created a component, and you wish to make a different component based on the original, make a copy with Move+Control.  Then right click on the new copy, select from the context menu "Make Unique".  Edit this new unique component as you wish.  It will have no effect on the others.</p>
]]></description><link>https://community.sketchucation.com/post/1298302</link><guid isPermaLink="true">https://community.sketchucation.com/post/1298302</guid><dc:creator><![CDATA[mitcorb]]></dc:creator><pubDate>Mon, 26 Dec 2011 18:17:02 GMT</pubDate></item></channel></rss>
