    PolygonMesh#normal_at == [0, 0, 0]?
    10 Posts 4 Posters 736 Views 4 Watching
      Jim
      I'm trying to create a PolygonMesh from faces (works,) but does anyone know why the mesh normals are all Vector3d(0, 0, 0)?
      model = Sketchup.active_model
      entities = model.entities
      selection = model.selection
      mesh = Geom;;PolygonMesh.new
      faces = entities.select{|e| e.is_a?(Sketchup;;Face)}
      faces.each { |face|
          verts = face.outer_loop.vertices
          pts = verts.map{|v| v.position}
          mesh.add_polygon(pts)
      mesh.count_points.times do |i|
          n = mesh.normal_at(i+1)
          p n
        Not sure... maybe it's populated only when you extract a mesh from existing faces....?
          I you use mesh=face.mesh 4 what are the normals ?
            Jim
            Thanks, but how can I get more than a single face into the mesh using this?
            Why do you expect mesh = Geom::PolygonMesh.new to create normals for you?
            If a mesh exists and has polygons, the normals can be calculated. I was hoping this would be done by SketchUp internally. I'm not even sure of the meaning of "normal" in this case - does it mean vertex normal, face normal, or something else.
              tomasz
              Face.mesh
              The mesh method creates a polygon mesh that represents the face. See the PolygonMesh class for more information.
              Valid flags are:
              0: Include PolygonMeshPoints,
              1: Include PolygonMeshUVQFront,
              2: Include PolygonMeshUVQBack,
              4: Include PolygonMeshNormals.
              mesh=face.mesh 4
              Why do you expect mesh = Geom::PolygonMesh.new to create normals for you? You have passed just points. I guess normals simply aren't initialized or default to 0,0,0.
                tomasz
                Polygonal mesh is a set of triangles. You could write a method to merge several faces into one polygonal mesh. There is no such a solution in Ruby API.
                  tomasz
                  From my experience and understanding the "normal" here is a normal of a vertex in a face. If a face has one edge smoothed, it can result in two normals at those two vertexes different then face.normal.
                    What I'd normally do is get each face's mesh [with normals etc] then export each face in the mesh with its normals.
                    Why do you want to export a mesh made from a combo of faces ?
                    Aren't you going to export the faces of each face's mesh one by one anyway ??
                      tomasz
                      I guess Jim wants to weld all vertices... or at least export one material as one mesh.
                        Jim
                        Just looking for a shortcut way to get vertex normals. I know it can be done in Ruby, but was hoping SketchUp did it faster when using a PolygonMesh.
