    BIM for SketchUp - again?
    51 Posts 14 Posters 14.9k Views 14 Watching
    • jim smithJ
      jim smith
      I just saw this in "ArchDaily"
      http://www.trelligence.com/demos/Affinity7_Sketchup.mp4
      A plug in that links rooms and floor level information to a data base. Seems to add an interesting feature to the BIM potential of SketchUp. Has anyone on the forum tried it or have an idea of the pricing? They are very coy about giving a price, which is usually indicates it is out of sight.
      "Out of clutter find simplicity,
      from discord find harmony,
      In the middle of difficulty lies opportunity"
      Albert Einstein
      • bigstickB
        bigstick
        I saw that too. I have to say that I don't quite understand the point of the Affinity product. If it's just for scheduling areas, it seems a bit overkill to me.
        This does highlight a very interesting question though, "To what extent should SketchUp implement BIM features?"
        From my own personal (selfish) point of view, I could see how creation of 'intelligent' BIM objects like walls, doors, floors, roofs etc, that allow data exchange with other BIM apps via IFC would be the only real features I would need. The complicated stuff like scheduling rooms and objects could be left to the pure BIM applications.
        This I suppose raises the even more fundamental question of, "What is the actual objective of implementing BIM features in SketchUp?"
        Again (just) for me it is data exchange with other apps, so that I can keep modelling and designing with SketchUp, but keep my model, imported into another application, for creating 2d documentation.
        The ability to have a round trip from SketchUp to a BIM app, then back into SketchUp (and back again) would be the ultimate solution. Spirit CAD already does this, but I don't know how it works with IFC, or how data translation works with other BIM apps.
        My own view on the business of BIM is that it will never work effectively unless there is proper data translation between applications. Having the whole design team just use Revit is great for Autodesk, but no-one else. However if the architects could use ArchiCAD, the Engineers Revit, FM managers something else, all operating from the same geometry and attached data, that makes for a much neater solution. Each discipline only needs to concern themselves with the tools they need. The building data then becomes the focus, not any particular software package.
        • P
          Pout
          It's a lot on how far do you want to go? And how many Sketchup users have the need for BIM?
          Get/Send data from and to a database from Sketchup is not that hard, we already do it in our software.
          Link images, costs, planning, resources can be done already. Show it in charts, automated powerpoints, movies, automatically created BOQ or BOM. We have prototypes developed for this.
          I'm not trying to sell anything here, I'm just saying that the technical part is not the issue.
          The main issue is the communication between all CAD/BIM software and Sketchup in both ways. And if IFC is the 'magic' format.
          I'm very fond of the idea of trying to create a certain level of BIM into Sketchup, to have the opportunity to get the information you want into the model and get added value out of it. But the interchangeability is an important factor.
          • pbacotP
            I think it will be driven as far as it goes, given the enthusiasm shown so far.
            For my own purposes and I think for many users, the front-end promises of BIM will be more important:
            1. Parametric or systematic creations of building elements (walls, floors, foundations etc.) that can be modified later based on intrinsic qualities of each.
            2. Placement of elements (windows doors equipment) based on defaults that make sense for those elements. Ease in revisions for these.
            3. Ability to work in plan view, adding or editing elements and have automatic model updates.
            4. Schedules for rooms, doors, windows,and equipment. Hot linked details. Automated notation systems.
            5. Generation of structural elements inside model based on designated assemblies.
            I am less concerned with the high-end details for "real" buildings (skyscrapers, museums etc.) than some features close to Chief Architect, for example. I don't need to make take-offs or maintenance schedules, or show all piping and wiring for the types of projects I do. I know this is important in large projects and in some cases the architect or designer must do more of this. I think it is true of most of the US, architects don't provide a bill of materials. That's the contractors' job. And few contractors in our milieu even use CAD. I understand it is different in Europe.
            I think this is probably true for a lot of users, but BIM will be driven by the needs of high-end users, and we all can benefit.
            • bigstickB
              bigstick
              Translating data in theory is easy enough. It depends on the amount of the data, how well the standards are documented, and how easy it is to format the data. The more complex it is the more likely it is to create problems.
              Even translating dwg data between different packages is not always 100% consistent. Sure the lines work, but things like viewports, dimensions, symbols and attributes (particularly when these two are linked) are more complex and don't always translate neatly.
              The point about BIM is that you need confidence in the validity/consistency of your data after translation. The true benefits of BIM can only be realised if the whole design team make use of it. If one wants to use this type software in a meaningful and flexible way, it needs compatibility with as many other apps as possible.
              Only IFC will do this with 3d data. What other open BIM formats are there?
              • PixeroP
                Pixero
                I'm very exited about the possibility to "sketch" BIM in SU and export it to Revit (which is our companys software of choice for the future).
                For me the most important feature is a working exporter so we can start using what's been done already and find what features we "really" need.
                Haven't seen any exporter yet though...
                • bigstickB
                  bigstick
                  Agree with this. I don't need parametric components, push/pulling will do for me, as long as the modified objects retain their 'intelligent' properties.
                  @pbacot said:
                  1. Ability to work in plan view, adding or editing elements and have automatic model updates.
                  2. Schedules for rooms, doors, windows,and equipment. Hot linked details. Automated notation systems.
                  3. Generation of structural elements inside model based on designated assemblies.
                  I wouldn't personally do schedules in SU. It's not good enough for 2d documentation. Your CAD application is better for this, and should already have competent scheduling and reporting tools. Also - why would you want to work in 2d views in SketchUp? It kinds of defeats the object πŸ˜„
                  Actually SU is currently fundamentally unsuited to being a fully developed BIM app. It simply can't handle a massive polygon count. It's essentially a design & modelling application and that's where its real strengths lie. The main BIM apps just don't have SketchUp's ease of use and flexibility for 3d modelling, but are good at 2d drawing, scheduling and reporting.
                  Making it a high end BIM app is misguided in my opinion. I would just settle for the ability to model the basic structure/layout in SketchUp, and transfer it to a true BIM app for 2d drawings and reporting once the basic design is done.
                  In the UK at least architects produce schedules, but don't do take-offs. We have a whole profession devoted to cost management in construction. Quantity Surveyors are responsible of Bills of Quantities and Cost-planning. During construction they are responsible for financial management of the contract.
                  Contractors and subcontractors are starting to use BIM more and more for larger or more complex projects. This is certainly the case with my Β£20m school.
                  • pbacotP
                    IDK. Seems obvious to me. If I am working on a model for a house, for example, I would rather plug in windows in plan where the horizontal dimension and relationships are critical. The default is already set for window height, the types of windows are easily chosen etc. Why fiddle with this in 3d? I've seen others do this in Chief Architect. They also just pick parameters for a roof, siding etc. It's all there when they go 3d.
                    I wouldn't expect schedules to be created inside the SU drawing. That would have to be Excel or some other program linked to reports from SU.
                    As for my CAD, it sounds like you are saying that should be my BIM. I don't have Revit and probably never will. I am just discussing the interest here in BIM for SU, not other programs. I have a pretty good working setup otherwise, between 2d CAD and SU. I am addressing the previous question, and saying that I think for many people the ease in creating "smart" building models is the first desire, but it will probably be more complex than that.
                    I agree. Different tools for different tasks. But something is happening in the plugin level and it could lead to third party integration. I wouldn't anticipate the basic program changing, except higher poly count. (I hope!)
                    • bigstickB
                      bigstick
                      Surely not? You have to switch to whatever storey you need to modify, hide the rest and switch to a plan view. It's got to be faster to position in 3d with the right inferencing. The 2d multiple view way of working is old-fashioned to me. It's one of the reasons a lot of us love SU, everything is 3d, you seldom use the 2d views.
                      Yup, that's exactly what I'm saying. I think that making SU the BIM tool (as opposed to adding BIM-friendly features to enable it to work effectively with the existing BIM apps) would be extraordinarily complicated, time-consuming and expensive. Way too much for one or two guys. This would be a Linux-like community coding effort!
                      • brewskyB
                        brewsky
                        I think SketchUp is at its most powerful in the design process when the building is still simply a hollow shell. No thickness in walls and all openings as self-cutting-components.
                        The best addition to basic SketchUp for me I think, would be "thick-faces". This would make parametric elements a whole lot easier to make, and in the process exporting to meaningful building parts. The greatest difficulty lies in how these faces connect...
                        Making building parts in that way could be
                        • draw a building as a hollow shell.
                        • Select faces that need thickness, and start the "thick-faces" function.
                        • Label the thick elements "wall" or "floor"(and holes as window/door).
                        • Export to IFC(or maybe even better, sync with bimserver.org)
                        Wouldn't this workflow be really SketchUp like?
                        This is how I'm trying to build the next version of my bim-tools plugin. I've got something basic working, but it will still be a hell-of-a-lot-of-work to make it fully functional πŸ˜‰
                        Topic: http://forums.sketchucation.com/viewtopic.php?t=34007
                        I also think IFC really is the key! Although it does have it's weaknesses, I think it's the only really open and interchangeable solution we've got.
                        Cheers!
                        Jan
                        Sketchup BIM-Tools - http://sketchucation.com/forums/viewtopic.php?p=299107
                        • brewskyB
                          brewsky
                          @bigstick said:
                          Recently I have experienced an interesting situation which gives me reason to hope (again) that someone will implement a BIM framework for SketchUp using IFC.
                          I've been thinking on this BIM-framework.
                          The most simple(simple to implement, simple to agree on to get to a sketchup wide standard) way for cross-plugin usage of BIM data would just be to use Attributes to label SketchUp-objects in a uniform way. This uniform way should lie as close as possible to the official IFC notation.
                          By example:
                          you could give every BIM object an AttributeLibrary called "ifc". And then fill it with IFC properties.
                          The AttributeLibrary for the bim-project(Sketchup.active_model) could get all properties as officially available in the IFC specs http://buildingsmart-tech.org/ifc/IFC2x4/alpha/html/ifckernel/lexical/ifcproject.htm
                          AttributeLibrary "ifc" for Sketchup.active_model could contain:
                          • IfcProject_GlobalId = Globally unique id number for the project(even after exporting en importing)
                          • IfcProject_Name = Test Project name
                          • IfcProject_Description = Test Project description
                          http://buildingsmart-tech.org/ifc/IFC2x4/beta1/html/ifcsharedbldgelements/lexical/ifcwallstandardcase.htm
                          AttributeLibrary "ifc" for a wall group(or component) could contain something like:
                          • IfcWallStandardCase_Name = Wall name
                          • IfcWallStandardCase_Description = Wall description
                          • IfcWallStandardCase_IfcQuantityLength_width = 300.mm
                          Every BIM-plugin can then add and read possible labels according to the agreed standard.
                          Please comment....
                          • bigstickB
                            bigstick
                            I think the 'thick faces' approach sounds great!
                            There are a number of ways you could create them though. Tools which specifically create the wall and slab objects would automatically set up the relevant tags/labels sound to me to be the most efficient solution.
                            However - ultimately there may be more complex wall types to build though. Angled, curved, stepped, tapering walls are all not that unusual. It may be that the 'thick faces' approach won't quite work with stepped, angled or tapering walls. If you could maybe allow each wall to be created in native SU geometry, and made into a group and tagged with an attribute, it gives you the benefit of modelling however you want, with flexibility to do pretty much what you want.
                            If you extended the attribute tagging principle and defined an open schema, any of the plugin authors here could build an integrated set of tools for all sorts of BIM elements, based on some of the plugins that they already have. A true community approach!
                            Someone would need to create an IFC export script though.
                            I have just checked out bimserver, sounds great! Would it work with large/complex models?
                            • brewskyB
                              brewsky
                              You are right, for new geometry a button "create wall" would be best, that could create the geometry AND add the labels. But the reason I think the approach of selecting faces would also be great is with complex shapes and for upgrading an existing design to BIM. Check the example image(made with my demo plugin, still need to solve corners)geometry.jpg
                              I would like that very much! Some opinions from other plugin developers or IFC experts would come in handy!
                              I'm also working on that, the previous version of my plugin DOES IFC export, but it only makes walls and windows.
                              For the future version I would like to work together with http://ifcopenshell.org/, if that works we don't have to build the full IFC framework in sketchup/ruby but just the translation to SketchUp! And even better, all contributions to that project would also be usable in blender and the like!
                              bimserver.org is a great project! I think it does work on large models because the principle is simple, as far as I understand it.
                                To make separate 'solid' 3d sides look at the shell tools by Jim and Thomthom [also Fredo's JointPP].
                                You'll get the two 'shells'.
                                Then you find all of the vertices of one and find the nearest corresponding vertex of the other Draw edges between them and add faces to the internal partitions.
                                [JointPP can do this for you with appropriate settings].
                                Then separate out each pair of faces and their edges as '3d facet - distorted cuboids' - each in their own groups/instances...
                                Erase the original geometry.
                                • brewskyB
                                  brewsky
                                  Thanks! I'll check them out.
                                  The way I'm building it right now(even the parts in the image are no push-pulls)is:
                                  Get the plane of the "base"-face, offset this to bottom and top, calculate a perpendicular plane for every edge(and I need to improve this to "half the angle" between this and the connecting face). Then intersect the planes and create vertices(and faces) on the intersection points. That way I think I can generate the entire geometry in one go.
                                  What do you think? (I hope my ramblings make sense πŸ˜„ )
                                    JointPushPull copes with adding thickness to a 'shell'. It can also copes with adding internal partitions ['sides'].
                                    You just need a way to extract the 'parts'...
                                    Good luck πŸ˜‰
                                    • P
                                      Pout
                                      brewsky and others
                                      Based on your comments, there are two possible pathways:
                                      BIM as in: be able to attach BIM properties and parameters to an entity. That's it, these parameters do not influence the entity when changed.
                                      BIM as in: when changing IFC parameters/properties teh entity is changed accordingly, even more, when adjectent entities are influenced they also change if needed (bit like Revit)
                                      As you can see, the first option is easy, but what is the added value?
                                      brewsky, can you pm me your contact info, I'm located in Belgium, maybe we can have a chat.
                                      • brewskyB
                                        brewsky
                                        I agree, the more information you've got, the more usable it becomes...
                                        This goes for every bim-plugin, but also for a basic common framework...
                                        But even if you just have 4 labels; "width=100", "length=6000", "height=3000", ifctype="IfcWallStandardcase" AND the default sketchup information of a group/component; "placement point" and "placement vector", can tell you a whole lot about the wall!
                                        The more "standard definitions" we as plugin builders can agree on, the better it gets. You could even agree on a basic Sketchup::Ifc module that contains a few classes for maybe ifc-export/import, generating globally unique id's(guid) and managing ifc-units...
                                        • bigstickB
                                          bigstick
                                          The added value of the first approach, is that SU can be integrated into an existing (or new) BIM workflow.
                                          So users can use SU in conjunction with Revit, Microstation, Archicad, Vectorworks etc.
                                            On the question of 'GUID'... like
                                            af8f4bfc-2604-43ec-acf1-489b153db0d6
                                            To make a unique GUIDs I'd use a method that does something like this:
                                            def new_guid()
                                              guid=''
                                              (0..35).to_a.map{|a|
                                                rand(16).to_s(16)
                                              }.each_with_index{|e,i|
                                                  e='-' if[8,13,18,23].include?(i)
                                                  guid << e
                                              return guid
                                            The reference you get from guid=new_guid() is now a unique GUID following recognized standards for any GUID...
                                            You should never get two the same!
                                            • 2 / 3
