    Help export DXF STL
    3 Posts 3 Posters 537 Views 3 Watching
    • N Offline
      nostromo2106
      please help with the plugin export to DXF or STL file is not saved plugin is installed and running the. DXF STL or stamped in the folder but nothing if you can explain step by step I can somewhere wrong when saving the file thank you and sorry for english I write through the translator
        Can you provide a link to the plugin you are using?
          d12dozr
          If you're asking about this plugin: http://www.guitar-list.com/download-software/convert-sketchup-skp-files-dxf-or-stl when you save the file, you need to type ".stl" at the end of the name. So "my stl export" --> "my stl export.stl"
          http://goo.gl/f7ooYh
