    Getting a terrain
    19 Posts 4 Posters 1.2k Views 4 Watching
      In fact I can import that .3ds and save as .skp then export that to .3ds without errors. That is strange?
        suSteve
        Thanks Rich,
        I have repeated the process quite a few times (its pretty straightforward) with different GE terrain but always the same issue.
        Could it be a Lion issue ?
          So this occurs on any GE snapshot you make? Or is it just this particular file?
          Maybe another Mac user with the same OS and SU version could try the same to see if it's repeatable.
            suSteve
            Just checked and its any terrain. Same error each and every time.
            thank you
              suSteve
              Sorry Rich forgot to say thanks for the 3ds file
              • GaieusG
                Steve, after getting the location, press the "add manual location" button and copy the lat/long co-ordinates here. It seems to be Mac (maybe just Lion?) reported by two other users here:
                http://www.google.com/support/forum/p/sketchup/thread?tid=729a7311664d77a3&hl=en
                On my PC, I can export to 3ds without issues. So as a temporary workaround, if you give me the lat/long data, I can try to import that piece of terrain for you (will try to zoom in and select the same region you have in that other file).
                Then I can export it but would be curious if I give you the skp file, you can export normally, too.
                  suSteve
                  Thank you Gai,
                  so it does seem like a bug but with the help of you guys I got the terrain.
                  thank you very much πŸ˜„
                  • GaieusG
                    How did you get it eventually?
                      driven
                      Steve,
                      I've got the same problem and dialog on 10.5.8 so it's not only a 'Lion' problem.
                      what's your workaround?
                        suSteve
                        sorry I did not have a workaround. See earlier in the thread as Rich kindly posted the .3ds file which worked perfectly.
