    1.3k Posts 300 Posters 3.1m Views 298 Watching
      lapx
      I'm still not able to get the UV tool to work after lofting the curves. Maybe these questions should be posted at the UVtoolkit plugin forum 😞
        redlerred7
        This some how happened in a random instance. I need to know how to stop it from happening again
          UV Toolkit? Not QuadFace Tools? (but yea - better post in the thread related to the plugin in question.)
            sepo
            @dave r said:
            Was that the problem?
            Yes... I did not read the footprint...I presumed it was the content of the zipped folder which usually is.
            Thanks again.
            • fredo6F Offline
              Do not Double click when you select an edge (otherwise, it extends to all). Also check if the 'Extend to all' option is not set in the button palette.
                redlerred7
                I left click once.
                Perhaps it was mouse lag or something. It's not happening now anyway
                • irwanwrI Offline
                  irwanwr
                  this is what i've been looking for.
                  thank you very much for your efforts.
                  drawing tent wont be impossible anymore.
                  for newbie like me, this is a miracle.
                  πŸ˜„
                    cupke79
                    πŸ‘ πŸ‘ πŸ‘ thanx,,, its work i love u all
                      benha
                      First off, THANK YOU. This is my favorite plugin ever. Awesome stuff.
                      I have a question though. I have skinned a surface, creating a compound curve.
                      I decided I wanted to "trim" the edge of the curve without starting over. To do this I moved away from the surface, used curviloft to create a second curved surface perpendicular to the original surface, and then moved it to intersect the original surface where I wanted to clip it.
                      I then highlighted both surfaces and performed an "intersect with selected."
                      A line showed up indicating that the intersection made sense to SU, but when I started trying to delete the portion I didn't want anymore the the surface clearly hadn't been parted at the intersection. The skin was being deleted on both sides of the line.
                      I've tried this several different ways, always with the same result.
                      Thoughts? Help?
                      Because this may be hard to visualize, I've attached a demo file. Basically I want to cut the layer called "target" using the layer called "knife."
                      I haven't done the intersections or anything yet because I wanted to give a pristine look at where I'm starting.
                      -Ben
                      DemoFile.skp
                        Youi need to put your knife inside that component. The intersection lines are always created in the editing context you are in so if you do the intersection outside, it won't affect geometry inside.
                        Triple click on your knife and press Ctl+X to cut it onto the clipboard. The edit the component and under the Edit menu, find an item called "Paste in place". Now intersect.
                          benha
                          AWESOME.
                          Thanks.
                            ColinMcCole
                            Hi...Can someone PLEASE help me?!?!?! I can't get a large number of plugins to work on my work PC for some reason. I've installed them all on my home PC without any problems, but i just can't install anything smoothly on my work PC. If they do manage to install, the icons are invisible in SKB (which isn't a major problem). I really just want to get the Curviloft tools on my PC at this stage. I've tried installing the plugins on SKB 6, 7, 7 pro and 8 and not one of them was successful?!?!?! I have Fredo 4.2 and all of the latest (as well as the old) plugins, but none of them work...and I've uninstalled and re installed SKB several times, i've turned on all extensions in the preferences dialog box, i've installed everything into the tools folder as well just in case...i have actually tried everything to my knowledge. Has someone had the same problems and figured it out?! Any help will be greatly appreciated.
                            Thanks,
                            Cole
                              Well, first You should clean up the Tools folder by removing the files you installed there. Next, make and post a screenshot of the Plugins folder so we can see how your plugins are installed.
                                ColinMcCole
                                Hi Gaieus. I was wondering if you had any tips on my problem posted below. I'm desperate to get this plugin loaded at the moment and can't get anything to work?!?!
                                  Well, if you really messed up your SU install that much, I would suggest uninstalling, deleting the whole directory (you can keep the materials and components folders if you have extra stuff there) and installing again.
                                  Then do something with your permissions (I am not on Vista so do not exactly know) but unless you somehow figure it out how not to do that, Vista won't put the plugin files to where you want but in some compatibility folder.
                                    ColinMcCole
                                    Hi Dave.
                                    Thanks for your feedback. I hadn't installed anything into my tools in this version of SKB, i just tried the plugins this time around. How do i attach an image to this post? My folder literally just has the standard plugin folders and rb's, as well as the folders named "Curviloft_DIR_12" and "LIBFREDO06_DIR_42", and the LIBFREDO6.rb script. The Fredo rb loads and i get the image on start up about updates, but nothing else shows. When i extract the rb scripts and place them in the actual plugins folder then SKB tells me there's errors loading all the files. I assume i'm doing something wrong here...
                                    I really want this plugin...i've been waiting ages for something like this and now i can't use the tools?! It looks awesome and will make life so much easier if i can get everything working.
                                      Did you unzip those zip files into the plugins folder?
                                      Under the text area you are posting, there is an attachment tab.
                                        ColinMcCole
                                        OK, so i got it to work on Sketchup 8...still can't get it on 7 pro (maybe it's not compatible?!). I unzipped them and did everything i usually do (i did with my home PC with no problems at all). I think i'll just bounce between the two Sketchup versions as i've spent enough time getting it to work. Thanks for the speedy responses, this site really is awesome.
                                          Sorry, I was in transit to work. Glad Csaba got you sorted. The plugin is compatible with V7 so it should work. Since it isn't, I would suggest you look again at the install. Or, since it works now on V8, rename the V7 Plugins folder to something like Original Plugins so SU won't look at it when it starts. Then copy your V8 plugins folder and paste it into the V7 location. See what happens when you restart SU7.
                                            benha
                                            Howdy.
                                            I'm having a bit of trouble and would appreciate suggestions. I'm trying to skin a pair of surfaces and the curviloft tool isn't working.
                                            I haven't had that problem before - anyone care to suggest why the two wireframes in the attached file won't skin?
                                            To clarify: This is supposed to be two parallel surfaces, offset by a small gap. The two closed hoops are what I'm trying to skin.
                                            Back Contour.skp
                                            -Ben
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 65
                                            • 66
                                            • 30 / 66
