    Drawing arc on a cylinder
    3 Posts 3 Posters 1.2k Views 3 Watching
      redsox985
      So, I'm attempting to draw an arc on the outside of a cylinder, but since SU makes both the arcs and cylinder out of lines, the two do not match up and some of the arc is outside, some inside, of the body of my cylinder. Is there a fix for this or just some way with which I am not familiar?
      • KrisidiousK Offline
        Krisidious
        tools on surface
        http://forums.sketchucation.com/viewtopic.php?t=11212
        and don't forget the wonderful people who write these lil life savers this holiday season.
        By: Kristoff Rand
          Tools on Surfaces is a good choice. You could do it with native tools by drawing an arc as a 'D' shape and extruding that through the cylinder. Then delete the flat side and use Intersect Faces to create the intersection. Delete the rest of the extrusion and you'll be left with the arc on the cylinder.
