    [Plugin] Dxf_In v2.2 20110517 Dxf2Skp
    200 Posts 41 Posters 323.1k Views 41 Watching
      Marc_Vierboom
      LS,
      I have installed (and working) the Sketchup 8 Dutch version. I have pasted the plugin ( Dxf_In_v2.2.rb ) to the directory: C:\Program Files\Google\Google SketchUp 8\Plugins
      Unfortunately I have no additonal dxf or dwg import line in my pull down menu File - Import (not even in the bottom of the list)
      Any idea what's up?
      Screendump from file - import
      • BepB
        Bep
        @marc_vierboom said:
        LS,
        Any idea what's up?
        [attachment=1:3bngwx91]<!-- ia1 -->Screendump.jpg<!-- ia1 -->[/attachment:3bngwx91]
        Hallo Marc,
        Look here [attachment=0:3bngwx91]<!-- ia0 -->dxf import.jpg<!-- ia0 -->[/attachment:3bngwx91]
        "History is written by the winners"
          Jim
          The file has Mac line endings - DxfIn (as well as my own .dxf importer) is not handling them correctly.
          You'll need to convert them file to use Unix or DOS line endings in the meantime.
          • B
            Bárbara Lopes
            Hi, I placed the plugin into the SketchUp Plugins folder, but it does not show on the file menu. I closed and re-opened my sketch up and nothing appeared yet. Please, can anybody help me? Tnks
              Are you looking in the correct menu ? UI.menu("File").add_item("Import DXF") 😕
              • F
                freeWilly
                I installed the plugin on my Mac.
                I see it in the file menu, and can start an import.
                But after a certain time it aborts an I get an error window "<error> or empty File".
                I have tried different DXF-Files.
                What do I do wrong?
                Rolf
                  Can you post one of the files so some other users can test and report back, it's almost impossible to say from your info so far...
                  • F
                    freeWilly
                    I took the file posted on page one of this thread (ALBA.zip), because I wanted to be sure that it's not a problem of my data.
                    It starts to count up in the status line until 5 and aborts then.
                      I'm on PC.
                      I've just [re]tried Alba.dxf.
                      Used 'centimeters' as the units - did you ?
                      It works; but did take a while to complete ['whiting-out' in the process... BUT still processing away nevertheless] AND also it does appear ~66.6m from the origin [but's that's where it is stupidly located in the DXF!].
                      Comparing the result from the equivalent Pro DXF import... it is missing a few of small lines around a lip and it takes 100x longer! BUT it works and the result is readily usable/fixupable...
                      • F
                        freeWilly
                        yes, I tried various options (including centimeter). And it run for quite a while, but with all tries it finally aborted.
                        I have SketchUp 8.0.11751 for Mac (Intel).
                        Rolf
                          Strange - as I say the PC version is slow but works eventually...
                          Are there any MAC users out there who have this working OK ?
                          • F
                            freeWilly
                            is there a kind of a debug mode?
                            To see when, what, why?
                              Running it with the Ruby Console open is the best there is - there's not coded-in debugging that I can see...
                                shrubman
                                What do I do wrong?
                                Rolf
                                I'm having the same problem. No matter what I do to prepare the file in illustrator, the import dxf dialog in sketchup gives me that error window and quits the import.
                                • C
                                  Chrisn2011
                                  This may be too late for you but I had used earlier versions of this on an iMac and found that there were sometimes problems which seem to relate to how the file is saved, some operating systems use carriage return -linefeed to denote the end of a line others just used one. I made a mod which allowed it to work on the iMac (see my post of Thu Feb 17, 2011 12:29 am), it may be worth trying it on the new version
                                  I edited the files using Textedit on the mac, just be careful that it doesn't add a .txt extension
                                  To help I have listed the suggested change below
                                  Find the following bit of code in the.rb file
                                  #get all block names, save them along with their location
                                  begin
                                  	aFile=File.open(chosen_file, "r")
                                  rescue
                                  	result=UI.messagebox "<Error> The DriveName\\Path\\FileName.dxf may not\nbe standard ASCII characters. If so, place the Dxf file\nin a ASCII named folder before accessing that file.", MB_OK
                                  aFile.each_line do |line|
                                  	count=count +1
                                  	if count==odd_number					#strip dxf tags thanks to TIG
                                  		odd_number=odd_number + 2
                                  		line=line.strip
                                  	last_line=this_line							#save last line data
                                  	this_line=line
                                  and insert the line
                                  line=line.chomp+"\n"
                                  after
                                  it should ensure that all the data read in is terminated in a way that ruby scripts accept, and it shouldn't affect the way they run under windows either.
                                  • L
                                    ltorresgdcllc
                                    Thank you!!!
                                      ANewBeat
                                      What do I do wrong?
                                      Rolf
                                      Same here: "<Error> or Empty File"
                                      Mac OS X 10.6.8
                                      Sketchup 8.0.16845
                                        Did you read the next post? Maybe it will help since it seems to answer the question.
                                        The best option would be to use the Pro version of SketchUp. 😒
                                          ANewBeat
                                          OK, so I added the line=line.chomp+"\n" as described. What does the error message "Database contains Unsupported Entitys: SPLINE" mean? After receiving the message the file continued to import properly.
                                            ANewBeat
                                            Upon further inspection my file did not import correctly. It seams to be having trouble with the curves. I've attached the DXF file, a screenshot of the original artwork in Illustrator CS4
                                            Screenshot of paths in Illustrator CS4
                                            and a screenshot of the resulting import into Sketchup 8.
                                            Screen shot of resulting import in Sketchup8
                                            DXF exported from Illustrator CS4
                                            • 9 / 10
