    A Welcome Message to New SketchUcation Members
    1.4k Posts 667 Posters 1.2m Views 667 Watching
    • GaieusG
      Hi Milky and welcome!
      • irwanwrI
        irwanwr
        hello,
        my name is irwan. i've been using sketchup since early SketchUp 6. primarily just because i like drawing. didn't use SketchUp for a while. thus, i jumped from SketchUp 6 to 8.
        it's nice to know that there is a forum like this SketchUcation after a while looking.
        • C
          chevy
          Being a newbe to Sketchup, I did a little playing around with it and watched quite a few of the MANY tutorials as I learned (and continue to learn) about the basic tool functions. Now that I have familiarized myself with the basic toolbar functions, I thought that I would join a forum in order learn a little more "in depth" as I create new designs and projects (my first was a simple Gazebo).
          Now with that having been said, forgive me for asking stupid, dumb and/or silly questions AND forgive me for asking this following question in this forum ... Direct me to the right forum location in order to get the question answered.
          Now for the question ... I have a flat surface that I want to create a raised or possibly a recessed image on from a jpeg picture that I have (using the jpeg as a guide). To get a little more specific, the flat surface is a kitchen cabinet door and the jpeg that I want to get on the face is of a drawn image of a bundle of wheat. The question that I have is what suggestions and/or directions are out there as to the best way of achieving this task.
          Thanks in advance and I look forward to participation in this forum in the future. Maybe one day I can be one that helps answer others questions rather than always being the "Question asker" ... LOL
          Chevy
          Don’t argue with fool. They drag you down to their level and beat you with experience.
          • GaieusG
            Go to File > Import and select the image type as the file. Then you have two choices on the right: import as image or import as texture. Both can be used but best would be if you could post the image as well the door so when I show you both methods, you can see it with your own example. Attach the file under the text area you are typing.
            • C
              chevy
              Thanks for the reply. Here are the two items that I am attempting to merge (per wifey's deman ... oops ... request)
              • GaieusG
                Try again, Chevy, they did not attach. Don't use the multiple attachment feature as it is broken. Attach one file (add file) and then add another one.
                • C
                  chevy
                  Let's try this again ... hope it works this time
                  Cabinet Door 3.skp
                  • GaieusG
                    Do you only want the wheat or also the grey background on the door?
                    If yes, the image needs to first of all be converted to png with a transparent background instead of the grey now. Then we can move on. Can you do that? Do you have a proper image editor?
                    • GaieusG
                      This would be without any recessing or raising - just placed on the kitchen door as an image entity (I made a not too good quality, transparent png image of it and added some wood texture to show how it would look like when you paint the door). To raise or recess, we need to explode the image and process it with a plugin that will create real geometry around the edges. Warning: it may become quite a heavy model that way.
                      Cabinet Door 3.skp
                      • C
                        chevy
                        What I was hoping to do is to just transfer the wheat image onto the door facing and somehow raise or recess the image it as if the wood facing has the wheat image carved or routered into the wood. Once I get all of the doors taken care of, I have drawer facings that need to be embellished to match the doors. Just so that you will know, these items are for a kitchen island with cooktop that I am designing for the wifes upcoming MAJOR kitchen remodel. The wheat jpg is actually a pattern for etching glass that was used on a couple of glass panels in her China Cabinet. Obviously, she wants the island to mimic and match the cabinet.
                        As for the image editor, I have Photo Shop and Paint Shop Pro. Both of which should come in as useful tools to use with SketchUp. All I have to do is to learn how to integrate either one or both with SketchUp. AS I stated in my first post, I am a newbe to SketchUp (only a few weeks of use) and have a lot to learn. I have a lot of hand drawn renderings collected over the years that I have drawn and hope to recreate them in the program rather than having a 3 ring notebook filled with paper, dividers and tabs.
                        • GaieusG
                          Okay, so I made the image into a png with transparent background. You will also need to develop this technique.
                          Another completely different issue is that it is still an image "floating" in front of your cabinet door. Just like a painted pattern over the wood texture.
                          In order to raise (or recess) it, you will need to
                          1. turn it into a face with the image applied as a texture on
                          2. somehow trim the texture so that there are edges around the visible parts.
                          1 is easy: select the image, right lick > explode...
                          2 can be done with this tool (a plugin): http://forums.sketchucation.com/viewtopic.php?t=33445
                          (I have never used it so I have no experience with it)
                          • C
                            chevy
                            Thanks for the tips! I have been "tinkering" with this off and on for most of the afternoon. I appreciate the advice that you have given, it was/is very helpful! With the use of Paint Shop I have started the process of "cleaning up" the wheat image and removing the gray background. My workweek begins tomorrow so I guess that I will pick back up on this sometime Monday or Tuesday. Again ... Thanks for the help!
                            Chevy
                            quote="Gaieus"]Okay, so I made the image into a png with transparent background. You will also need to develop this technique.
                            (I have never used it so I have no experience with it)[/quote]
                            • C
                              Chistabo
                              Hello to SU community!
                              My name is Simon, from Slovenia.
                              Using SU7.
                              I have drawn simple Astrology SU file, and am currently manually moving the Planets around the chart. With Component Attributes / RotZ, to simulate moving of Planets in Degrees.
                              There is a Swiss Ephemeris (SE or sweph) from Astro.com, that has Planets positions calculated from x BC to x AD. It is written in C language. All major astrology software uses this SE file for calculations.
                              There is also sweph4ruby wrap-up.
                              Currently I am trying to find the way for Planets to be moved in real-time, using some Ruby programming and SE or sweph4ruby.
                              That is, program some script to read sweph4ruby (or original sweph or sweph.dll) and apply Planets coordinates to SU components.
                              Absolute beginner with Ruby.
                              Can you please point me to someone with similar interest or who is willing to give some advice to newbie like me? Will learn on the go, have done it before.
                              I know majority of you guys and gals do not believe in Astrology, but that is not the matter of discussion now.
                              Thank you for your help,
                              Best regards,
                              Simon
                              • C
                                chevy
                                I want to thank the SketchUcation Forums along with the people involved for such an expansive knowledge base. In particular Gaieus and Muriel (whose post I no longer see in the thread) for helping me with the "issue" that I had with my FIRST real project. Thanks to these two, I finished my blue prints and delivered them to the cabinet maker for construction to begin. Although I was about a week behind schedule which in turn put me lower on their completed waiting list, it was worth it in this instance. He was so impressed with the detail and clarity of what was designed utilizing SketchUp that he said that he was going to check out the program himself.
                                I have been coming to the forums pretty much every day since signing up here, reading the various subject posts and continuing to learn more about the program. I found a few plug-ins that sure would have come in handy during my designing phase that would have cut the "aggravation factor" along with the "time factor" way down. I have now downloaded and installed with the first one being BZRoundEdge(Being a "Newbie" ... I had no clue about them at the time).
                                My message and/or suggestion to the new users and new members ... read the forums! Use the tutorials! Watch the videos ... pause the video and practice with the new information as you watch it! IF by some chance an answer is not found ... Post your question(s)! Speaking from experience, reading the various post(s) will (more than likely) answer your question(s).
                                Now a message for Gaieus ... thank you for the "welcome" and a personal THANK YOU for the assistance!
                                Chevy
                                • GaieusG
                                  He. Welcome...
                                  @chevy said:
                                  ...He was so impressed with the detail and clarity of what was designed utilizing SketchUp that he said that he was going to check out the program himself...
                                  Tell him that if he does not find enough time to explore the software himself, we are now an official SU training center, too! 😉
                                  We even have expert woodworkers like Dave Richards on board!
                                    ArrowSM64
                                    Thank you for the welcome. We're looking to find a obj exporter plugin to work with basic Sketchup8. In a Sketchup forum post, someone said to look here, but we can't find it in the plugin list. Thanks
                                      The 'OBJexporter' is readily available on the page linked by the big red "Plugins Index" button.
                                      Learn to use your Browser's "find" tool [Ctrl+F osa] - it was the second match I think...Capture.PNG
                                      • C
                                        ccbiggs
                                        Hello all just thought I would quit lurking and introduce myself. My name is Cory I am from northwest Pennsylvania. I work for my father at Barens Inc we sell pressure washers, parts & accessories all wholesale, all over world.
                                        I have been here since I turned 16 and am now 31, I started at the bottom scrubbing toilets and sweeping floors, pulling orders packing orders, manufacturing, accnts payable accnts receiving.
                                        We have a few in house brands that we have manufactured in china. I am now learning SketchUP to design some of our parts & accessories. Pressure Washer Frames, Hose Reels, High Pressure fittings & swivels. And whatever else the boss wants designed.
                                        The ultimate goal is to be able to send a technical drawing/blueprint to our manufacturer in china and them be able to build from it.
                                        I would say I am making good progress learning this cool little program, I have been playing with it for only 6-7 weeks so far and have learned a bunch from this great site you all have here. And would like to thank you all for the info you have all provided so far and for the help I am sure will be needed in the future.
                                        It amazes me how much better you all have made the vanilla sketchup with your plugins and ruby scripts.
                                        I am also going to be learning autocad in time because I am not sure which will be better for our needs. But I will be focusing on sketchup for now.
                                        Thanks again & nice to meet you all.
                                        • V
                                          vedran1983
                                          hi my name is Vedran, i cam here before but now i am looking for some plugins
                                          • GaieusG
                                            Hi Vedran,
                                            Do you have any specific ideas what you need or just looking around?
                                            • 53
                                            • 54
                                            • 55
                                            • 56
                                            • 57
                                            • 72
                                            • 73
                                            • 55 / 73
