    [Plugin] 2D Tools
    791 Posts 178 Posters 564.4k Views 177 Watching
    • david_hD Offline
      david_h
      Yeah. .it's pretty weird. If I have a chance, I'll post a screen shot at least. I wonder if 2D tools is clashing with another plugin? ya think??? maybe? I only have 400. Should be no trouble checking to see which one. πŸ’š
      D
        MartinK
        I'm having a problem with the 2dLinestyle tool. When I choose <Custom Style>,I don't get the new dialog window where you can set up the Custom Style. The Linestyle just remains whatever it was before I picked <Custom Style>. I have the latest version installed and everything else works, at least the tools I've tried. Thanks in advance for any help.
          MartinK
          It works fine for me [and everyone else as far as I know]...
          To reiterate...
          Right-click in 'empty space' to get the options main-dialog.
          Select <Custom Style>, and then OK...
          Another dialog appears for you to name and also design your own custom-style, and then OK...
          The original main-dialog now reappears...
          Scroll through the style-list to find your newly made custom-style... select it and also set other options for the LineStyle and OK...
          Style the lines as desired...
          [Custom Styles should also be saved with the Model??]
          • I Offline
            ingeh
            Does this plugin work on Mac too ?
              Yes.
              Although some of the MAC modifier key options have different names than the guide...
              • I Offline
                ingeh
                @tig said:
                Yes.
                Great ! I'll try it asap... Looks like a wonderful tool.
                Many thanks,
                Inge
                  marziaf
                  if I press the <0> key in 2D Line tool the Z-plane resetting function starts, so I can't type all the lengths containing a "0".
                  I've noticed that in the 2DlineTool.rb, line 306, the key 48 is linked to the <TAB> function (" if key == 9 or key == 15 or key == 48### TAB sets Z, 9 for PC 15 for MAC ?"...).
                  I'm not a programmer but if I change this line and delete the string " or key == 48" the command works well.
                  Is it a needed change to the plugin or I'm doing something wrong?
                  (sorry for my English)
                    I think some linux versions have key 48 as tab ?
                    I hadn't realized that it was the main keyboard '0' !
                    Feel free to disable the key press test as
                    if key == 9 or key == 15 ###or key == 48
                    I'll issue an update shortly...
                      marziaf
                      Thanks for your reply and also for your plugin, very useful!
                        Here's v5.1 http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
                        It fixes the recently reported glitch whereby on a PC the 2dLine tool jumped into the Z-height tool IF you typed a '0' from the main keyboard while typing a dimension, this was because the 'key codes' for 'TAB' for PC/MAC were messy [pressing TAB activates the Z-height tool]... πŸ˜’
                        If the three and a half thousand or so of you who have previously downloaded would like to get the updated toolset then please form an orderly queue πŸ˜‰
                          justinhough77
                          Running a MacBook Pro...I cannot get this plugin to work. I have had success with other plugins but cannot get this one or the cline tool to work properly. Any help is appreciated.
                            You really haven't given us much to go on in order to help you. I can tell you that I have this plugin installed on my MacBook Pro and it works as expected. This would lead me to believe you've not installed it correctly. Why not throw us a bone and post a screen shot of your Plugins directory to show us how you have the plugin installed.
                              I recall some reports about 'modifier-keys' being flaky on MACs, or them being the wrong-way-round or somehthing weird ?
                              If an experienced MAC user could chip I ?
                              I have been waiting to get some advice/fixes back on this issue for ages...
                              However, if you just want to draw some 'clines' there are already several other tools available for this too... There was a recent topic on it and some links...
                              • E Offline
                                emjay125
                                I set a 2d line style and draw a series of dashed lines (drains under and alongside a house). The lines are dashed until I stop drawing them. A single left click at the end of a line makes all the earlier ones in the set appear dashed. Then moving the mouse makes the whole set continuous. Another left click turns the set into dashed lines. A double click to end the line-set makes the set solid lines.
                                What is going wrong, what edge settings or other factors do I have to set ?
                                  You right-click in empty space to get the line-style dialog ? Thereafter any lines you 'style' match that [width/color/pattern].
                                  Have you got view > hidden-geometry 'off' [should be]...
                                  Can you post an example SKP ?
                                  • E Offline
                                    emjay125
                                    Thanks TIG, for a quick response.
                                    Here is a sample SKP. DashedLines1. I am using the Sketchup v 8.0.11752 here. There are no 2d layers that I can see. Seems to be the same in v8.0.4811.
                                    What are the settings that could affect printing the dashed lines.
                                    Is the deletion process that I describe on the SKP usual.
                                    Emjay
                                    A very simple model of my incompetence.
                                      Your lines' dims are quite large - if you have a line 100m long it probably needs to be 1000mm wide to be visible in meaningful views!
                                      The 'dotted-ness' depends also on the line's width...
                                      I found that adjusting the width/style produced acceptable results πŸ˜•
                                      Your 'guide-lines' are not relevant to this as it only works on lines/edges...
                                      Also you example face is 'upside down', so the 'styled edges' appear below it...
                                      [correctly oriented to the face... but 'upside down' for what you hoped for - facing 'down' !] !
                                        davidterry
                                        Neither the line color or style is working for me. I am using SU version 8. Is there a line scale function somewhere? Didn't notice.
                                          How isn't it working ?
                                          Can you please be more specific...
                                          The styled-line's width affects the spacing of any pattern's dots/dashes - so on very large scale lines you need them to be wide to get a meaningful pattern, on very short lines there might be no room to fit in any pattern if the width is too great.
                                          The color is whatever you set it to in the dialog...
                                          You have been right-clicking in open-space to get the style-settings dialog ?
                                          This let's you set these values...
                                          The 'default' is a modest-width [this varies with model-units in "/mm], the pattern is 'continuous' and color is 'black'.
                                          Choose another width, pattern or color as desired...
                                          After you've styled a line, then later on you can select it and right-click to get the context-menu and 'Edit' the line-style: the dialog reappears and you can then change width/pattern/color as desired...
                                          • O Offline
                                            osage
                                            Hello TIG. Just downloaded and install your great plugin. But I have a problem. I read the help file, but I can't find where you edit the FILLET tool parameters. I pick both lines...but nothing happens...like, the radius must be zero or something. Where do you set the radius? BTW, I didn't have time to read this entire thread...but I will, soon.
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 39
                                            • 40
                                            • 19 / 40
