    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [Plugin] extrudeEdgesByEdges.rb
    190 Posts 76 Posters 215.1k Views 76 Watching
      adskad
      I installed it on a 32 bit computer, and it works perfectly. I appreciate the help - I will re-install on my current computer and try again.
      It is fantastic BTW - thank you TIG!
        rv1974
        Thank you TIG as always.
        Some humble sugestion if I may:
        Your scripts would gain even more popularity if you'd put concentrated set of gif's (like this for example http://www.polyboost.com/)
          There are several movie tut's 'in progress' - meanwhile there are quite a lot of static step-by-step tut's...
            deanlegg
            Hi all
            Love the plugin really good
            2 things, I can't get the toolbar to show up, I have the outer box where about 6 icons would be but no icons
            And could you direct me to some good tutorials
            Cheers
              @deanlegg said:
              Hi all
              Cheers
              Have you kept all of the icon image/lingvo files [~51 of them] etc in the TIGtools subfolder inside Plugins - not having done so is the usual cause of this issue... Do a new install, extract the zip file's contents into a temporary folder - perhaps on your Desktop - keeping all the files in the appropriate subfolder. Then move or copy that subfolder and the other rb files into Plugins folder... If this fixes it then I suggest you look through the Plugins folder and tidy up any files that are in TIGtools and also incorrectly installed in there ๐Ÿค“
                khashayar
                hi
                thank you for the great great plugin. i was trying to make a tent structure with it but i couldn't do it.
                here i attached the sketchup file. i'd be really glad if you could check it out and tell me if it's possible to make a tent out of it or ....not.
                thanks
                tent.skp
                  Kahashayar
                  EEbyEdges is not the right tool to make that form.
                  Try its cousin - EEbyRails - and make each side one of four meshes, as this example Capture.PNG
                    khashayar
                    thank you TIG. that was a big help .
                    @tig said:
                    Kahashayar
                    • 66searcher6 Offline
                      66searcher
                      thanks TIG
                      ๐Ÿ‘
                      http://hamidtoliat.deviantart.com/
                      • mitcorbM Offline
                        mitcorb
                        Hi, irwanwr:
                        In answer to your question and based on the image by TIG above, this plugin "Extrude Edges by Edges" is not the one. As TIG showed in that image, you would need "Extrude Edges by Rails" and assemble the form.
                        I also replied in your Carnival Tent posting.
                        • I Offline
                          Iho
                          why it doesn't work?
                          http://i.imgur.com/3aZXU.jpg
                          In pictures line are two simple lines regruped in two different group.
                            It works fine for me ?
                            How large are your grouped arcs ?
                              kieran28
                              hope this doesn't sound stupid but does this plugin work on mac OS?
                                Yes. ๐Ÿ˜’
                                Most scripts as cross platform, they clearly say if they aren't...
                                Make sure you are putting things into the MAC's HD path 'plugins' folder NOT the 'user' one, and extracting files preserving subfolders etc as clearly spelled out in the instructions...
                                ๐Ÿค“
                                • I Offline
                                  isir1313
                                  hello:D im new at this and i would really like to use this pluggin! can anybody help me install it? THANNNKS in advanced:P
                                    This link gets you the ZIP file http://forums.sketchucation.com/viewtopic.php?p=217663#p217663 that includes ALL of my 'Extrusion' tools...
                                    If you are brave you can follow the link's instructions... and move the extracted files/subfolder_of_files into your 'Plugins' folder and restart Sketchup...
                                    If you are complete novice then may I suggest that you go here http://forums.sketchucation.com/viewtopic.php?p=375454#p375454 and firstly install the 'simple-installer' - its installation/use is very clearly explained in that thread - to install it use the Window > Preferences > Extensions > Install_Archive... button - selecting the tool's RBZ file...
                                    Once that's installed it and restarted Sketchup you can use it to install any scripts/zip/rbz/etc you might download... it beats using any brain cells... ๐Ÿ˜’
                                      sryu006
                                      Hi Thank you for your nice plugins..
                                      Don't know what's wrong with it but when I try to use 'ExtrudeEdgesByEdge' I'm keep getting 'Select 2 Groups of Edges ! ....' even I already have two grouped edges selected...
                                        Please post a simple example SKP that you can't get to work...
                                        We can then test it and see where you are going wrong...
                                        Remember that you must have two groups-of-edges.
                                        Those groups must both contain edges - they cannot be inside a subgroup or component-instance.
                                        The groups must be in the same 'context'.
                                        Only select the two groups, nothing else.
                                        They must be able to be extruded into a 3d form.
                                        So two 'flat' sets won't achieve much...
                                          Bua
                                          It is great, Thanks ๐Ÿ˜„ ๐Ÿ‘
                                            chaleampol
                                            thank you TIG
                                            • 2 / 10
