    V-Ray render makes "smokes"
    renderpluginsextensions
    10 Posts 4 Posters 1.3k Views 4 Watching
    • E Offline
      edison
      Hello!
      I have a problem, which is really annoying me, tried to find on internet, in this site also, tried a lot of different options, but unlucky. I hope, somebody will help me.
      So the problem is, you can see on my attachment, that in render are a lot of circles looking like smokes, just looks dirty. I found only, what I have to change GI pre-set to medium, but I'm using sketchup 8 pro v-ray 1.4 for it, and there is now field to change it. Those circles usually appear on white walls, or ceilings, but in this example those are on furniture.
      Thanks for any help!
      • andybotA Offline
        andybot
        two things you can do:
        • under your irradiance map settings, change your Hsph. Subdivisions to something line 150
        • increase your overall lighting level, add some rectangular lights off camera if possible. There's not enough lighting in those areas.
        • E Offline
          edison
          Many thanks mate!!
          • StinkieS Offline
            Stinkie
            @andybot said:
            (...) change your Hsph. Subdivisions to something line 150
            150? 😲
            That's way too high. Try 50 instead.
              @edison said:
              v-ray 1.4
              There is no such version of V-Ray for SketchUp. Do you refer to the V-Ray core version (the one that the render window gives you?) Or did you shorten the version number of 1.48.xx or 1.49.xx ? Can you post exactly the full version number? (It is important as there are some very important fixes inbetween the versions.)
              • andybotA Offline
                andybot
                150? 😲
                60 is default. I typically go to 90 or more to get a smoother image. It doesn't add a whole lot of time for me, but definitely helps with the splotchiness.
                • StinkieS Offline
                  Stinkie
                  That's odd. I hardly ever go over 60. In some cases I'll go up to 80, but that only rarely happens.
                  • E Offline
                    edison
                    My V-ray is 1.48.96, windows. Default number is 50, and I made 150, now renders looks great, but takes more time.. πŸ˜„
                      Update to the latest, 1.49.01 - there's all kinds of bugs in the older versions.
                      • andybotA Offline
                        andybot
                        Glad it worked for you πŸ‘
                        Do you want to post an updated image?
