    [Plugin] Parametric Copy v1.01 20111030
    22 Posts 13 Posters 29.4k Views 13 Watching
      Mikenon
      There are only a few differences between PCs and MACs: for example with different names/codes for 'modifier' keys and so on.
      I suspect something is adrift in your code about picking a point - it needs to reset a flag so it then continues... or the dialog values are not all trapped for errors/emptiness πŸ˜•
      Get the users' Ruby Console errors...
        danbig
        This is very cool. SketchUp has needed something like this for a long time.
        For me, SketchUp crashes every time, when the rotation is applied. I've tried different components, rotation axes, and parametric values. Each time, when the rotation is applied, I get a crash.
          mikenon
          Danbig: what version of Sketchup and Windows/OS X are you running? Could you send me a private message with details of what paramater values you used? If you select "None" (you may have to use the pull-down menu to find "None") for all of the rotation and scale operations, but just choose Constant-Step for the translation options, do you get the same problem?
          Everyone: Im in the process of fixing these bugs. It works perfectly on my OS-X box under extensive testing -- so I cannot debug on my own machine.
          Therefore I am debugging by email, which is very slow. But it will get fixed. So far mirale999 has helped by allowing me to send him versions of the plugin with debug statements, running it on his Windows box, then sending me back the debugging output. We have discovered at least one difference between windows and OS X Sketchup: on OS X, if you leave the default values blank in inputbox dialog, the value of a pulldown menu will default to the first item. On windows, it will default to empty-string.
          If anyone else is willing to help, please send me a message.
            mirale999
            β˜€
            Mybe the last version I have tested, had fixed the bug successfully!
            paranoia is a higher form of awareness...
              mikenon
              Ok here is version 1.01: http://forums.sketchucation.com/viewtopic.php?p=361858#p361858
              In addition to fixing the error in Windows-compatibility, there is now better error-handling in general for the input boxes, and there are new parameters for some of the functions.
              Extra thanks to mirale999 for patiently running code updates and sending me the bug reports.
              Mike
              • jeff hammondJ Offline
                wow! β˜€
                this plus a GUI and some sort of preview/incremental undos would be insane.
                πŸ˜„
                  Here's an Analog Clock I wrote in GDL years ago http://www.scribd.com/doc/66416515/110/Analog-Clock ... it was in an earlier version of the Cookbook...
                    Remember this I have made 8 years ago πŸ˜‰
                    GDL Language : Normally for ArchiCad or d'AutoCad but you can use it for Sketchup πŸ€“
                    GDL book, free 😎
                    need
                    GDL Scripter free πŸ˜‰
                    Just put some lines from the tutorial above in the window "Script 3D"
                    GDL Web Control/Plug-in Free for see Objects rotate in 3D window πŸ‘
                    GDL Object Explorer Free for see all the GDL of objects the univers! 😎
                    and you can save as many formats! Not sure the this explorer is always available! here πŸ€“ πŸ˜‰
                    Example ! Copy this following inside the 3D Script Editor πŸ˜„ Click on the Rubik-Cub πŸ˜„
                    for i = 1 to 20
                    addx i*2
                    CYLIND i*6, i*4
                    next i
                    http://forums.polyloop.net/attachment.php?attachmentid=2903&d=1098087739
                    http://forums.polyloop.net/attachment.php?attachmentid=2904&d=1098087681
                      Polythene
                      Very nice plugin, exactly what i'm looking for.
                      However, can i suggest the addition of a 'back' button when entering values? It would be great to try a number, look at the outcome, but then quickly go back and change the number to see what the difference is.
                        Lobster
                        Hi mikenon,
                        Looks very interesting and no problems so far.
                        Thanks so much.
                          stoneuge
                          Hi, witch matematical language do it use?
                          i mean: there is a reference for translating operations in simbology?
                          (i know * is x, and - is "less"...but i'd like to get some more...).
                          thanks
                          • 2 / 2
