    1.3k Posts 299 Posters 2.5m Views 297 Watching
      lapx
      Tom,
      I just tried it with your instruction and still could not get it to work. I got it to work on a flat surface.
      Can you try it from the model that I uploaded? The rails are still in the model. It ask for U direction and I get nothing when I try and define U V direction. There is no highlight.
      Thanks,
        @lapx said:
        Tom,
        Thanks,
        I made a mesh with Curviloft using the rails - made it generate quads and I had no problem mapping it. ( Note that is you have anything selected, the UV mapping tool will limit the mapping to the selected entities. So make sure to deselect unless you can't to map a local region. )
        As for the extruded surface, I ran Convert Triangulated Mesh to Quads on it, turned out it converted it quite well. (surprisingly as it has issues)
        But I had to select a local region in order to map it, because the sides of the mesh could not be mapped to a 2D grid.
        See the screenshot for what selection I made:
        I picked a center-ish edge and used the Grow Edge Loop so the selection ran the length of the mesh - before it folds around the sides. Then I used Edge Ring to ring loop around the whole mesh. Then I use Select Quads from Edges.
        UVTEST.skp
          lapx
          Like I said, You are amazing! I'll try it an let you know the results when i get to the office.
          Thanks once more and many thanks to come.
            aea
            my instal new sketchup 8 and works β˜€
              lapx
              One step at a time. Here's my curvi loft skin with quads activated. I select the quads by triple clicking in SU. I hit UV map selected quads and nothing happens when I try to pick UV direction. 😞
              BTW, my pick button on your quad tools is not working. Might that be the problem?
              Is there a problem using Su native picking tools?
              Thanks Tom for your help,
              Lapx
                You do not need to select anything in this case. Since you map everything.
                Do you get any error messages in the Ruby Console?
                  lapx
                  No errors to report. I just get the dialog at the bottom to pick the u direction. πŸ˜•
                  Do hidden lines need to be on?
                    sepo
                    Installed in on mac book pro mac os 10.6.8 and have this error.
                    Error Loading File __loader.rb
                    uninitialized constant TraductorError Loading File bootstrap_Curviloft.rb
                    uninitialized constant Curviloft::T6Error Loading File CurviloftAlgo.rb
                    uninitialized constant Curviloft::T6Error Loading File CurviloftCurveMover.rb
                    uninitialized constant Curviloft::T6Error Loading File CurviloftPalette.rb
                    uninitialized constant Curviloft::T6Error Loading File CurviloftTool.rb
                      Sepo, is it possible that when you installed the plugin that you put the contents of the folder loose into the Plugins folder? The files listed in your error message should be in a folder called CURVILOFT_Dir_12 inside the Plugins folder.
                        That might be in order for the tool to be able to pick the edges...
                          sepo
                          😳 thanks...
                            Was that the problem?
                              lapx
                              I'm still not able to get the UV tool to work after lofting the curves. Maybe these questions should be posted at the UVtoolkit plugin forum 😞
                                redlerred7
                                This some how happened in a random instance. I need to know how to stop it from happening again
                                  UV Toolkit? Not QuadFace Tools? (but yea - better post in the thread related to the plugin in question.)
                                    sepo
                                    Yes... I did not read the footprint...I presumed it was the content of the zipped folder which usually is.
                                    Thanks again.
                                    • fredo6F Offline
                                      Do not Double click when you select an edge (otherwise, it extends to all). Also check if the 'Extend to all' option is not set in the button palette.
                                        redlerred7
                                        I left click once.
                                        Perhaps it was mouse lag or something. It's not happening now anyway
                                        • irwanwrI Offline
                                          irwanwr
                                          this is what i've been looking for.
                                          thank you very much for your efforts.
                                          drawing tent wont be impossible anymore.
                                          for newbie like me, this is a miracle.
                                          πŸ˜„
                                            cupke79
                                            πŸ‘ πŸ‘ πŸ‘ thanx,,, its work i love u all
                                            • 41
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 65
                                            • 66
                                            • 43 / 66
