    1.3k Posts 299 Posters 2.5m Views 297 Watching
      lapx
      I'm trying to map a texture on this shape. I must admit I'm totally at a loss understanding the uv and quad rubies.
      I'm sure I'm missing out on some powerful tools if i fail to understand these.
      Need some help in explaining how these would work in this application.
      UVTEST.skp
        If you want to map that with QuadFace Tools you need to generate the mesh as a set of quads.
        I assume you use Curviloft to create the mesh, you need to explicitly tell it to generate quads.
          aea
          hello
          I tried to install Curviloft but does not work. When you install the 4.2 LibFredo6 disappear Hoverselect and Roundcorner that can not be used.
          I attached ... please
            lapx
            Thanks Tom,
            Yes I did use curviloft and joint pushpull after skinning to get thickness. Will the joint pushpull operation destroy the quadfaces?
            I'll try it.
            Thanks again Tom! You are amazing!
              I believe so...
                lapx
                Tom,
                I just tried it with your instruction and still could not get it to work. I got it to work on a flat surface.
                Can you try it from the model that I uploaded? The rails are still in the model. It ask for U direction and I get nothing when I try and define U V direction. There is no highlight.
                Thanks,
                  @lapx said:
                  Tom,
                  Thanks,
                  I made a mesh with Curviloft using the rails - made it generate quads and I had no problem mapping it. ( Note that is you have anything selected, the UV mapping tool will limit the mapping to the selected entities. So make sure to deselect unless you can't to map a local region. )
                  As for the extruded surface, I ran Convert Triangulated Mesh to Quads on it, turned out it converted it quite well. (surprisingly as it has issues)
                  But I had to select a local region in order to map it, because the sides of the mesh could not be mapped to a 2D grid.
                  See the screenshot for what selection I made:
                  I picked a center-ish edge and used the Grow Edge Loop so the selection ran the length of the mesh - before it folds around the sides. Then I used Edge Ring to ring loop around the whole mesh. Then I use Select Quads from Edges.
                  UVTEST.skp
                    lapx
                    Like I said, You are amazing! I'll try it an let you know the results when i get to the office.
                    Thanks once more and many thanks to come.
                      aea
                      my instal new sketchup 8 and works β˜€
                        lapx
                        One step at a time. Here's my curvi loft skin with quads activated. I select the quads by triple clicking in SU. I hit UV map selected quads and nothing happens when I try to pick UV direction. 😞
                        BTW, my pick button on your quad tools is not working. Might that be the problem?
                        Is there a problem using Su native picking tools?
                        Thanks Tom for your help,
                        Lapx
                          You do not need to select anything in this case. Since you map everything.
                          Do you get any error messages in the Ruby Console?
                            lapx
                            No errors to report. I just get the dialog at the bottom to pick the u direction. πŸ˜•
                            Do hidden lines need to be on?
                              sepo
                              Installed in on mac book pro mac os 10.6.8 and have this error.
                              Error Loading File __loader.rb
                              uninitialized constant TraductorError Loading File bootstrap_Curviloft.rb
                              uninitialized constant Curviloft::T6Error Loading File CurviloftAlgo.rb
                              uninitialized constant Curviloft::T6Error Loading File CurviloftCurveMover.rb
                              uninitialized constant Curviloft::T6Error Loading File CurviloftPalette.rb
                              uninitialized constant Curviloft::T6Error Loading File CurviloftTool.rb
                                Sepo, is it possible that when you installed the plugin that you put the contents of the folder loose into the Plugins folder? The files listed in your error message should be in a folder called CURVILOFT_Dir_12 inside the Plugins folder.
                                  That might be in order for the tool to be able to pick the edges...
                                    sepo
                                    😳 thanks...
                                      Was that the problem?
                                        lapx
                                        I'm still not able to get the UV tool to work after lofting the curves. Maybe these questions should be posted at the UVtoolkit plugin forum 😞
                                          redlerred7
                                          This some how happened in a random instance. I need to know how to stop it from happening again
                                            UV Toolkit? Not QuadFace Tools? (but yea - better post in the thread related to the plugin in question.)
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 65
                                            • 66
                                            • 12 / 66
