    Edge length question
    3 Posts 2 Posters 188 Views 2 Watching
      ktkoh
      cface=codef.entities.add_face(@pt)
      							orig_ents = codef.entities.to_a
      							cface.pushpull(-1*@c2depth)
      							if @edge == "Round"
      								fin_ents = codef.entities.to_a
      								added_ents = fin_ents - orig_ents
      								added_ents.each {|e| e.smooth="true" if e.is_a?(Sketchup;;Edge) }
      								added_ents.each {|e| e.soft="true" if e.is_a?(Sketchup;;Edge) }
      							end #if Round
      I am using the code to smooth the edges of a Mortise however I don't want to smooth the bottom edges. I have tried several ways to add the test "e.length == @c2depth" but have been unsucessful. Any ideas how to do this??
      Keith
        When you make the new face immediately set
        normal=cface.normal
        then after you pushpull it to make the hole [and it's 'gone'] and you've checked it's 'round' and you've got the new geoemtry, you can smooth only those new edges that are parallel to the 'normal' thus:
        added_ents.each{|e|(e.smooth=true;e.soft=true) if e.is_a?(Sketchup::Edge) and e.line[1].parallel?(normal)}
        Note how you can combine the smooth/soft setting into the one test, which halves the processing time.
        Note too that it's =true/ =false boolean NOT strings ="true"/ ="false" [which would both return true because they have a value]
          ktkoh
          Thanks TIG That was exactly what I needed!!!
          Keith
          11
