    Plugins that use CPU when idle?
    28 Posts 7 Posters 1.7k Views 7 Watching
      bjornkn
      After having spent the last 3 weeks fixing my PC, which ended up with replacing almost all of it, except the cabinet with fans and a couple of HDDs, I have started cleaning up on the old main HDD as well.
      One thing that has been bothering me for a while is that when SU is running it constantly uses at least 10-15% of CPU, even when doing nothing, and with an empty scene.
      This does not happen when removing all the plugins (I have far too many installed currently).
      One (or more) plugin(s) are maybe running in some infinite loops?
      I'd like to get rid of this/these plugins, but finding the guilty one(s) could be a bit tedious/difficult
      The question is:
      Are there any plugins that are known to use the CPU while it really shouldn't?
      BTW, the workaround is to open the Preferences dialog before switching to another app..
        mac1
        Intersting. You can do what is called a maximum entropy search and find the problem relative quickly. Just keep splitting the # of plugins in 1/2 each time. If the first 1/2 does not fail then it must be in the 1/2 you did not load etc. If you have more than one causing the problem then it gets more dicey
        • CadFatherC Offline
          CadFather
          on my machine, i noticed libfredo6.rb seems to raise the cpu about 6%
            bjornkn
            Ouch - Libfredo is such a useful and necessary plugin support file that I'd hate to remove it 😞
            I guess I should follow mac1's advice and do a "binary search". And probably check if there are any redundant/unused files there? And then just remove those that I never use..
            There's now 131 .rb files in the Plugins folder, and lots more inside subfolders..
              I got Fredo's plugins, and SketchUp.exe uses 0% CPU when idle.
                CadFather
                i should have been more clear - the 6% rises only when i move the mouse over the screen
                  And you're saying this does not happen with any plugins installed?
                  I'd put that 6% to SketchUp - doing calculations to what entity the mouse is over etc.
                  • dereiD Offline
                    derei
                    It happened to me once with a model, that SU was using a entire core at maximum 😲 I wasn't doing anything, only opened the model. It was a model that had to be cleaned. After I reworked the geometry it went back to normal.
                    The model was a dwg import... so, strange things happen. But 6% of CPU is not something to worry about. As thomthom said, is normal. The only way your CPU to not work at all is to unplug the PC from power line πŸ’š (because turning it off might not work every time, as there is LAN wake up and other stuff that trigger BIOS to send signals to CPU)
                      CadFather
                      toggle units increases as well about 7%
                      Thom, yes it does not happen without plugins - what i did is eliminate plugins by halves and found lib, now found Matt's toggle units as well. there must be others.
                      in fact when all my plugins are in, the cpu shoots at 25% just by moving the mouse across..
                      EDIT: i'm more inclined to think that it is a combination of them... interesting..
                      my scf toolbars also raise the cycles.. (perhaps something to do with observers)
                        I once has a texture in a model that caused massive lags. It was a texture with a non-existing network path.
                        • dereiD Offline
                          derei
                          I was writing a response having this thought, but I deleted it, when you posted yours πŸ˜„ . I'm inclined to think the same... maybe there are plugins that have observers active for watching the cursor position, or chanve view, edit/create/delete geometry... and maybe that ones are using so much CPU
                            CadFather
                            funny stuff, i know what i'm going to do as soon as i have some free time... observe! πŸ€“
                              bjornkn
                              It turns out that it is Twilight that keeps on working in the background all the time, even when SU is minimized.
                              I can't see why that should be necessary?
                              Removing Twilight brings SU back to 0% when idle (except of course when moving the mouse across its window or doing something else inside SU).
                              Anyone else seen this with Twilight?
                              • dereiD Offline
                                derei
                                Were you rendering something? Be aware that the rendering engine still works if you close the render window. You have to stop the render (either stop button, or right click on image and choose to stop after next pass), if you want to end it.
                                  bjornkn
                                  No, I'm not rendering anything. If I do the CPU uses 99%. Just an empty scene, in the background or even when minimized.
                                    CadFather
                                    just to clear things up - twilight is %0 on mine...
                                    wonder how many people have the same plugins settings in the entire planet..
                                      There are no observers for cursor positions.
                                        CadFather
                                        ..maybe it isn't cursor position but it still affects the mouse movement?
                                          Could be validation procs for menus and toolbars ... they seem to trigger very often.
                                            CadFather
                                            sounds like a good lead, it's a bit like they greying context menus..
