    A simple Cut plugin
    3 Posts 3 Posters 380 Views 3 Watching
      dudyone
      Who has a simple cut program for cutting angles in tubing and pipe? I am having a problem using the section plane. Something like draw a line across it and tell it to cut through.
        Zorro2 OR perhaps use WorkPlane+Intersect_with+erase_unwanted_stuff...
        OR you can just make a rectangle, group it and move/rotate it into place, then use intersect and erase unwanted stuff...
          TIG's suggestions are spot on, of course.
          You really don't need a plugin for a simple task such as this. Simply draw a face at the angle you want for the cut. Intersect it with the tubing and delete the waste. Think of it as drawing in the saw blade.
          http://farm7.static.flickr.com/6148/5964496863_fc05fc1ed2_z.jpg
          Knowing how to do this is useful because there are other applications for essentially the same process.
