    COUNTRY HOUSE
    36 Posts 14 Posters 3.2k Views 14 Watching
      davidh
      a lakeside version,playing with soft texture effect
        davidh
        and a moonlit version of the same image
        • C
          cadmunkey
          Personally I'd be worried about flooding on that site 😉
          Great render, you're making everyone look bad now... 👍
          • tademaT
            tadema
            That's class
            • soloS
              Hell yeah, that last one is brilliant. So is this all Photoshop?
              • hellnbakH
                hellnbak
                Wow! You build it, I'll buy it.
                  davidh
                  This was the original raw render before photoshopping.
                  Pete,all entourage and sky and effects are photoshop.Often I would take an image through fotosketcher but in these images everything is done in photoshop.Its really all about layering and layering elements in order to build up a sense of depth.
                    davidh
                    A second lakeside image.The building is the same raw render from the first image I uploaded in this set and the sky and trees are the same from the last lakeside image,with a few additional tweaks.The reflection was done by flipping a copy of the lake side and using motion blur to create the streaky reflection, and then darkening the bottom of the image.There are a few areas where elements seem to bleed into each other but I wanted quite a loose feel to this image so I wasn't that concerned
                    • pbacotP
                      David,
                      All this belongs on "Most impressive RENDERED SU" if there were such a thread.
                      Getting into the mood of Winter are we? With the sun shining outside here, highs in the upper 70's, these are deliciously, and vicariously, chilly pictures. Just great work.
                      Peter
                        davidh
                        Peter
                        Its getting quite cold in this neck of the woods at the moment so heres a colder version of the last image with the lake frozen and a couple of small tweaks.
                          davidh
                          and a warmer,soft evening version
                          • mitcorbM
                            mitcorb
                            Hi, davidh:
                            These last views are excellent. You are a visual symphonic composer. 😄
                              davidh
                              24 hours late with this one,maybe it needs some gravestones to add to the atmosphere.Similar to the other images,this is based from the same raw render previously uploaded.
                              • Bryan KB
                                @pbacot said:
                                David,
                                Yep. There is and yep, it does.
                                • srxS
                                  srx
                                  👍 👍 How much time for cooking in PS? 😄
                                  www.saurus.rs
                                    davidh
                                    Ive added the gravestones to the foreground.Normally the photoshop post processing would take anywhere from 20 mins to a few hours.These were about an hour each.
                                    • urgenU
                                      urgen
                                      ...O-o-o nice! 👍 thanks!
                                      --pupil forever...------
                                        davidh
                                        And the final tweak to this image,some clouds across the moon and a spectral figure at bottom left.I think I'll leave this image as is now.
                                          davidh
                                          lots of colour in this one
                                          • C
                                            cadmunkey
                                            Love the colour in that one, real nice.
                                            • 2 / 2
