    COUNTRY HOUSE
    36 Posts 14 Posters 2.4k Views 14 Watching
      davidh
      and a moonlit version of the same image
        cadmunkey
        Personally I'd be worried about flooding on that site ๐Ÿ˜‰
        Great render, you're making everyone look bad now... ๐Ÿ‘
        • tademaT Offline
          tadema
          That's class
          • soloS Offline
            Hell yeah, that last one is brilliant. So is this all Photoshop?
            • hellnbakH Offline
              hellnbak
              Wow! You build it, I'll buy it.
                davidh
                This was the original raw render before photoshopping.
                Pete,all entourage and sky and effects are photoshop.Often I would take an image through fotosketcher but in these images everything is done in photoshop.Its really all about layering and layering elements in order to build up a sense of depth.
                  davidh
                  A second lakeside image.The building is the same raw render from the first image I uploaded in this set and the sky and trees are the same from the last lakeside image,with a few additional tweaks.The reflection was done by flipping a copy of the lake side and using motion blur to create the streaky reflection, and then darkening the bottom of the image.There are a few areas where elements seem to bleed into each other but I wanted quite a loose feel to this image so I wasn't that concerned
                  • pbacotP Offline
                    David,
                    All this belongs on "Most impressive RENDERED SU" if there were such a thread.
                    Getting into the mood of Winter are we? With the sun shining outside here, highs in the upper 70's, these are deliciously, and vicariously, chilly pictures. Just great work.
                    Peter
                      davidh
                      Peter
                      Its getting quite cold in this neck of the woods at the moment so heres a colder version of the last image with the lake frozen and a couple of small tweaks.
                        davidh
                        and a warmer,soft evening version
                        • mitcorbM Offline
                          mitcorb
                          Hi, davidh:
                          These last views are excellent. You are a visual symphonic composer. ๐Ÿ˜„
                            davidh
                            24 hours late with this one,maybe it needs some gravestones to add to the atmosphere.Similar to the other images,this is based from the same raw render previously uploaded.
                            • Bryan KB Offline
                              @pbacot said:
                              David,
                              Yep. There is and yep, it does.
                              • srxS Offline
                                srx
                                ๐Ÿ‘ ๐Ÿ‘ How much time for cooking in PS? ๐Ÿ˜„
                                www.saurus.rs
                                  davidh
                                  Ive added the gravestones to the foreground.Normally the photoshop post processing would take anywhere from 20 mins to a few hours.These were about an hour each.
                                  • urgenU Offline
                                    urgen
                                    ...O-o-o nice! ๐Ÿ‘ thanks!
                                    --pupil forever...------
                                      davidh
                                      And the final tweak to this image,some clouds across the moon and a spectral figure at bottom left.I think I'll leave this image as is now.
                                        davidh
                                        lots of colour in this one
                                          cadmunkey
                                          Love the colour in that one, real nice.
                                            davidh
                                            A compendium of some of these images
                                            • 2 / 2
