    Problem with rendering (rendering is not starting)
    renderpluginsextensions
    10 Posts 4 Posters 9.3k Views 4 Watching
      marcell86
      Hello,
      I have finished modeling my currently project and I was going to setup V-Ray options but I faced a serious problem I can't solve 😞
      When I start rendering my scene nothing happens. There's just an announcement that "V-Ray is currently processing your scene" and after few minutes it dissapears and rendering just don't start.
      I am new with V-ray and sketchup and I will be very thankful for any help.
      I am working on:
      core2duo T6500
      4GB of RAM
      GeForce 9600M GT with 1gb of RAM
      win 7 64bit
      vray 1,49,01
      Here's a link to sketchup file (54mb)
      http://www.speedyshare.com/files/30902909/1234.skp
      Best regards,
      Marcell
      • dkendigD Offline
        dkendig
        Please contact Chaos Group U.S.A. for support for any important issues.
        Devin Kendig
        Developer
        • chonC Offline
          chon
          Hello,
          Your SU file is quite big and i've sometimes that kind of problems with big files.
          Solutions :
          Restart your PC to make sure you have most RAM as possible.
          Try to render your scene with a lower output resolution.
          What are your GI and Irradiance Map configurations ?
            marcell86
            default settings. Sometimes rendering is starting but sometimes it doesn't.
            Unfortunately I need to render it in higher resolution.
              marcell86
              Hello guys, my problem with rendering is solved but now I have another problem.
              Here's what I got:
              imageshack.us/photo/my-images/694/testqfp.jpg/
              I have a problem with reflections on copper material and glass panels. The vray plane cast white reflections on those materials and it looks like its overburned. It looks just ugly!
              What I would like to achive is basically no reflections of this white plane but still I want those materials to look glossy.
              Another problem is that I want to render this views in parrarel projections but I have no idea how to make it.
              Any tips woule be appreicated.
              Best regards,
              marcell
              • jarynzlesaJ Offline
                jarynzlesa
                Bez názvu.jpg yes, this is a problem
                http://www.vizualizaceschodiste.mypage.cz/
                  marcell86
                  @jarynzlesa said:
                  [attachment=0:7xt7nx9f]<!-- ia0 -->Bez názvu.jpg<!-- ia0 -->[/attachment:7xt7nx9f] yes, this is a problem
                  Excuse me?
                    marcell86
                    Thank you for tips, I will try this out 😄
                    • chonC Offline
                      chon
                      Marcell86,
                      i think that your reflection is white because your ground is white and your concrete material has some reflection itself.
                      So, try to change your ground color and check the "Exclude all objects from reflection/reflection" option in your concrete VRay material.
                      For your second problem, VRay can't render parallel projections. Best solution i think is to render in perspective mode with the SU zoom tool set on 1°.
                        marcell86
                        hello guys,
                        it's me again. I have a small problem with v-ray glass material. I used material with settings described in this blog http://sketchupvrayresources.blogspot.com/2011/07/vray-sketchup-glass-material.html but there is my result. Glass doesn't have the green color.
                        Best regards,
                        Marcell
