    SketchyPhysics3.1
    85 Posts 37 Posters 82.2k Views 37 Watching
      Error Loading File sketchyphysics.rb
      undefined method `file_loaded?' for main:Object
      Suggests that 'sketchup.rb' isn't loaded at that point.
      At the very start of 'sketchyphysics.rb' add the line
      require 'sketchup.rb'
      that should fix at least that one error - then hopefully the consequential ones too...
        andy1347
        TIG nailed the first part of the problem with his suggested fix.
        After rebuilding my plug-ins folder, I have determined the culprit causing the conflict is a ruby called 'singleton' in a folder called 'ruby'. As near as I can tell, it is used with Jim Foltz's 'autocenterpoint'.
        With that one file removed, SketchyPhysics seems to load and run just fine. I hope this helps and look forward to a fix.
        Thanks to both of you for your help with this.
        Andy
          daniele_rossi
          I have the same problem running SketchyPhysics3.2 on sketchup 7 and Mac OSX 10.5.8 on Intel Core 2 Duo:
          dlopen(/Users/dr/Library/Application Support/Google SketchUp 7/SketchUp/plugins/SketchyPhysics3/sdl/SDL_Special.dylib, 9): no suitable image found. Did find:
          /Users/dr/Library/Application Support/Google SketchUp 7/SketchUp/plugins/SketchyPhysics3/sdl/SDL_Special.dylib: unknown required load command 0x80000022
          • jgbJ Offline
            jgb
            I can't tell you how happy I am to see SP upgraded.
            I've avoided SP for some time because I simply could not climb the learning curve (that's ME, not SP!) then got too busy with too many other things to get back. Still too busy, but in a few weeks I WILL load SP 3.1 and get back to it.
            Now a cupla questions based on ...... what Andy1347 said (in part)
            *After rebuilding my plug-ins folder, I have determined the culprit causing the conflict is a ruby called 'singleton' in a folder called 'ruby'. As near as I can tell, it is used with Jim Foltz's 'autocenterpoint'.
            With that one file removed, SketchyPhysics seems to load and run just fine.*
            ❓ Is there any logic to the ORDER in which SU loads RUBY scripts?
            ❓ Does it matter (and in the case above, it seems too)?
            ❓ Is there any practical way to control loading order, if required?
            jgb
              mickeyao
              I get a message: Error Loading File sketchyphysics.rb
              undefined method extend_object' for Singleton'
              Am I missing any files? Thanks!
                That error [undefined methodextend_object' for Singleton'] is from a standard RUBY installation [ singleton.rb] - where it might be called by several other standard modules/classes/methods - BUT as far as I know it has nothing to do with the SketchUp version if Ruby OR SketchyPhysics itself. Do you have other 'Ruby files' loading, that aren't standard Plugin scripts ??
                  munkey
                  I get the same error. πŸ˜•
                    I suggest you PM CPhillips about it... he's the author πŸ˜•
                      ROBIND
                      hello,
                      I want a free software that would allow me to record my video made ​​after SketchyPhysics in order to watch them out of sketchup.
                      Thank you.
                        BBFlashback express ?
                          ROBIND
                          Ok but for MacOSX. I'm sorry...
                            d.o. durant
                            Chris, great work on SP. Love it! I hope I am not missing anything prior to writing this. When I click the Win3.2 version, I get the save file dialog with a 3.1 title. After running the installation, my animation tells me, upper left corner, SP 3.2 required. I guess the install isn't taking well, or....? TIA
                            DOD
                            • O Offline
                              ocoromon
                              Any developers working on the SketchyPhysics Project should either update it's status, or mark it as Dead.
                              The current update rate is not a proffesional way to leave such things.
                                Squelch_
                                Does anyone know the current status of SP?
                                According to Google Code, the source repository no longer exists, so it leaves it nigh on impossible to pick up where Chris left off - if it has indeed been abandoned - Does anyone have a link to an alternative location of the source (preferably a repository) please?
                                Is there anyone else interested in continuing development of this excellent addition to Sketchup?
                                  http://code.google.com/p/sketchyphysics/ ?
                                    Squelch_
                                    Thanks, but that repository only contains documentation, not code. Was the code ever published?
                                      I read that on the page above on the last line
                                      Source code for the plugin is in the install.
                                      πŸ˜‰
                                        Squelch_
                                        I see that now, thank you.
                                        I'd rather hoped to see a history of revisions to understand the rationale behind some of the changes and inclusions, but I'll continue to trawl through the scripts making notes given the lack of inline comments.
                                        Thanks for the sanity check.
                                        • ashscottA Offline
                                          ashscott
                                          I'd love to help in some way with the furtherance of SP but I have only just begun to learn Ruby let alone everything else that is required.
                                          If I can help in any way I will. Personally I think SP could be a commercially viable product with a good polishing - anyone ever see any code for SP4? If its as good as it sounded I would pay for it.
                                          Has Chris totally dropped the SP project now? The whole thing is a testament to Chris' brilliance and I feel I have missed out to have not got seriously involved until now.
                                          Just some stuff I do with Sketchup.
                                            kmlkarablt
                                            @cphillips said:
                                            Here is the long awaited new version of SP. Hopefully this version will be much more stable under SU8.
                                            Google Code Archive - Long-term storage for Google Code Project Hosting.
                                            (code.google.com)
                                            Check out the Release Notes for changes:
                                            http://code.google.com/p/sketchyphysics/wiki/ReleaseNotes3_1
                                            All the scripted events and commands. This list will get fleshed out over time.
                                            http://code.google.com/p/sketchyphysics/wiki/ScriptFunctions
                                            Mac version, more docs and examples to follow....
                                            Updated Oct 7 2010
                                            Changes:
                                            http://code.google.com/p/sketchyphysics/wiki/SP31Oct7
                                            i am a beginner and i don't know where to put event codes in sketchup. By the way are they for win or mac? Thank you
                                            • 4 / 5
