    3skeng Pipe Modelling Plugin - Any Further Developments ???
    31 Posts 7 Posters 7.7k Views 7 Watching
    • FrederikF
      Frederik
      Howard,
      I assume that you've overlooked the 3skeng engineering 2.0...
      I've been using the 3skeng plug-in widely for more than a year now in various projects within the cooling industry...
      When I bought the plug-in, I was informed that they expected the next version to be available durring the spring 2010...
      I've had some correspondance with Sebastian and the next release has been post poned a couple of times... Hopefully they will manage to get it ready - as they state - in the first quarter of 2011...
      (so that should be before end of March, which is soon...)
      Cheers
      Kim Frederik
      • FrederikF
        Frederik
        Thanks for the update, Sebastian...! πŸ˜„
        From what I saw in the video, it sure looks really promissing...! πŸ‘
        Looking forward to receive the new plug-in...!
        Cheers
        Kim Frederik
          SHK
          Howard and Frederik,
          thank you for the positive feed-back. Yes we are working on a new release which will have a function to generate bill of materials and the pipe diameter is one of the properties shown in the list. The ability to change a pipe diameter is also on our internal whish list but not yet part of the upcomming release.
          The most important new function is the ability to use actual components with real dimensions. Here a short preview:
          3skeng 2.0 is now available.
          Regards Sebastian, SHK
            SHK
            If anyone had problems to synchronize the 3skeng database please download the latest setup which should fix the problem...
            • FrederikF
              Frederik
              Thanks for the update, Sebastian... πŸ‘
              Wonder why I didn't receive an e-mail notification with information that v2.0 is now available...
              Now that I've installed the new version, it's has changed from licensed version to an evaluation version, which will be active for 60 days...
              I suppose I need to take this via e-mail to get things sorted... πŸ˜‰
              Any way... Looking forward to test the new functionalities... πŸ˜„
              Cheers
              Kim Frederik
                SHK
                Frederik,
                We started to send out the email notifications. Further notifications will follow soon. If you activate 3skeng 2 with the same parameter you used for your first purchased 3skeng release. the 3skeng client will replace the evaluation status with the purchased status.
                Regards, Sebastian
                • FrederikF
                  Frederik
                  Thanks, Sebastian...
                  From my initial tests it looks really good... πŸ‘
                  Best thing is that the "3skeng Component List" and "3skeng Component Lable" tools are working with models build with previous version... πŸ˜„
                  A question...
                  Are we able to build our own component libraries, which will be a part of the 3skeng list?
                  I/we use various kinds of flanges, valves, components from Danfoss Socla, Belimo and other vendors a lot...
                  Cheers
                  Kim Frederik
                    SHK
                    Frederik,
                    thanks for the positive feedback. The label and list tool was also very high ranked on our internal whish list and we use these functions a lot in our actual engineering projects.
                    Further libraries will follow step by step. The 3skeng software architecture does currently not allow to upload own libraries in the database. The purchased libraries will be maintained automatically.
                    However, you can place 3skeng detail connectors in your own components to make them 3skeng compatible.
                    Regards, Sebastian
                    • FrederikF
                      Frederik
                      Looking forward to check out the libraries...
                      Cheers
                      Kim Frederik
                        SHK
                        Frederik,
                        FYI: 3skeng now including a tool to generate rectangular ductwork. New libaries are also available since today.
                        Regards, Sebastian
                        • FrederikF
                          Frederik
                          What happened to this plugin...?
                          The web-site seem to be down and I haven't seen any updates for a long time... 😐
                          Cheers
                          Kim Frederik
                            They presented at Basecamp. So it's still alive and well.
                            • FrederikF
                              Frederik
                              Cheers, Rich... πŸ‘
                              Good to know...
                              Cheers
                              Kim Frederik
                                Was working yesterday... ...and working now.
                                • FrederikF
                                  Frederik
                                  Hhmmm... Not from here... πŸ˜•
                                  Guess I'll try again tomorrow...
                                  Thanks for the heads up anyway... πŸ‘
                                  Cheers
                                  Kim Frederik
                                    raineysky
                                    Maybe Sebastian will stop by and give us an update. This plugin has huge potential.
                                    • FrederikF
                                      Frederik
                                      They still seem to have some issues with the web-site, which seem to be down from time to time... 😐
                                      I have an issue with the latest version (ver. 2.4.010)...
                                      Although I'm going to contact their support directly, I want to know if anyone else have issues with this version...?
                                      Cheers
                                      Kim Frederik
                                        SHK
                                        Frederik,
                                        the website 3skeng.com is up and running. I opened the website and everything is looking good. Can you please describe the difficulties you have?
                                        Regards, Sebastian
                                        • FrederikF
                                          Frederik
                                          Hi Sebastian,
                                          Please note that I've also sent an e-mail direct to your support as well as to Ralf Schiessl... πŸ˜„
                                          I don't have any issues when I enter this url: http://www.3skeng.com/en/index.htm
                                          However, if I only enter http://www.3skeng.com I get the message that there's a problem loading the web-site and it can be caused by a firewall or proxy...
                                          Cheers
                                          Kim Frederik
                                          • FrederikF
                                            Frederik
                                            Just a quick update...
                                            Got in contact with Ralf at the 3skeng support and things got sorted... πŸ˜„
                                            For me the issue was related with the Internet connection at my office... πŸ€“
                                            Don't know exactly what caused the issue, but when I tried with another Internet access, I was up running in no time... πŸ‘
                                            The 3Skeng support certainly is brilliant... πŸ‘
                                            Cheers
                                            Kim Frederik
