    Gothic Cathedral completed
    48 Posts 22 Posters 9.6k Views 22 Watching
    • FletchF Offline
      Fletch
      Thanks for sharing the model, Klog,
      A couple quick renders with Twilight Render.
      The old cathedrals always felt to me to have high contrast dark and light areas something like this.
      Fletch
        Klog
        Very nice Fletch. I would have fone more of this myself, but I have trouble knowing i9f my (digitasl) computer screen is "telling me the truth" because if I move out of NORMAL to the screen it changes the contrasts. Some earlier ones came out too dark ...
        Is it the thin glass that gets so much more light into the building or is it the Gamma?
        Thanks and do a lot more
        Klog http://www.tetontimberframe.com
        Win 7 Pro Dell Precision M4500 4Gig 4 threads @ 2.9 GB/S
        Skp 7 Pro & 8
        • FletchF Offline
          Fletch
          I almost always adjust Exposure/Gamma on interior images. (or exteriors for that matter) It's as natural as a normal camera adjusting exposure when inside a building.
          In this case, I did some post-pro only to get the lights and darks looking how I wanted them. I have no idea how successful it is (with the image of the choir looking up) on your screen, or anyone's screen for that matter. I'm sure it looks completely different on every screen. ๐Ÿ˜• I only know it looks "good" to me on mine.
          If you are interested, here's something about how to calibrate your monitor or screen. See also the basics of screen calibration here.
          Fletch
          • FletchF Offline
            Fletch
            A couple more.
            Fletch
              ๐Ÿ‘
              Tรก sรฉ go hรกlainn mo chara ๐Ÿ˜‰
              • artysmediaA Offline
                artysmedia
                @fletch said:
                A couple more.
                I like a lot the first one! ๐Ÿ˜ฒ
                Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
                Blog: Artysmedia
                • unigamiU Offline
                  unigami
                  @fletch said:
                  A couple more.
                  Just beautiful...and so real I can almost hear echoes!
                    Klog
                    I have just created my first video of the Interior of this cathedral and it very clearly shows that is is the first. Created from Kerkythea in 600x800 format (thanks ) and is posted at Yutube site: http://www.youtube.com/watch?v=O8COiJmGZCk . I have a lot to learn about movie making so any comments for improvement to that end are very welcome. View the Youtube video in FULL screen format or you miss half of it ...
                    Skp 7 Pro & 8
                      Roger
                      The camera can't show the full range of color that our eyes see in a stained glass window. When I shoot stained glass windows I shoot a 3 to five stop bracket and layer the images in PhotoShop. Then going pane by pane, I use only the exposure that gives the most representative detail. I the case of this cathedral it would probably take as much time as building the original. So don't feel bad about having to go to extra lengths to handle the dynamics of th exposure range.
                      http://www.azcreative.com
                      • massimoM Offline
                        massimo Moderator
                        Thanks klog. However the new file says "7" in the name but is still saved in "8" version. ๐Ÿ˜‰
                        • N Offline
                          nomeradona
                          we are using this model in our Facebook challenge. Thanks again Klog for this excellent model.
                            tomislavm
                            My God,how long did You need to render this movie?
                            Is there any suggestion for that render?
                              Klog
                              Recently I realized that not everyone uses version 8 Sketchup and could not use the available downloading option. I have corrected the omission and here is the link to download a version 7 .skp file of the complete cathedral. http://dl.dropbox.com/u/40864073/v7%20Gothic%20Cathedral%20clean.skp Also Nomeradona informs me he is using this model for the October Challenge of his Sketchup-Vray Facebook group and we shall post the "winners and runners-up" here as well.
                              EDIT:10/20/11
                              the above link IS NOW version 7.skp
                              Skp 7 Pro & 8
                                Klog
                                Massimo
                                Thanks for the heads-up. The URL has been corrected as has the version (I checked this time in the "Model info" dialog). Good rendering to you ...
                                Skp 7 Pro & 8
                                • massimoM Offline
                                  massimo Moderator
                                  Nice model. Thanks for sharing. ๐Ÿ‘
                                    Klog
                                    First answer: set it up and go on vacation while it renders. Actually took about 2-1/2 days because it hung about 2/3 of the way through and I had to start and splice from there to finish.
                                    Second answer: I deffinitely suggest not using approximation of "tween" frames, which is one of the options of Kerky animation - while it probably saves time, you get that blinking of transmitted light on and off seen in the video. I used PM medium AA for the renderings which seems good enough for the video mode. Used Virtual Dub (free) for the assembly and recommend you study the "frame ripping" info to avoid the horizontal tearing of image frames I sometimes got. It is a conflict between the different scan rates (I think) of the movie and crt/computer/other devices).There are also plug-ins you can activate as filters on the raw images and advise figuring out how to activate them as one of them allows contrast/brightness adjustment and many others I know nothing about.
                                    I know this sure as hell beats Sketchup's native animation feature for smoothness and AA function. And lastly the use of key-frames is useful for editing out stuff. I didn't use it and got the frame jumps twice when I removed unwanted frames and spliced.
                                    Like I said before, this is my first real attempt at movie making and may we all learn from it.
                                    Thanks for the input.
                                    Skp 7 Pro & 8
                                    • N Offline
                                      nomeradona
                                      TOP 12 for our Sketchup Vray artists October Challenge using this GOthic Cathedral
                                      SVA October Challenge Top 12
                                      Last October SketchUp Vray Artists Facebook Group had organized a challenge using Al Klagge's Gothic Cathedral. Here are the top 12 selected...
                                      (sketchupvrayresources.blogspot.com)
                                        Klog
                                        http://sketchupvrayresources.blogspot.com/2011/11/sva-october-challenge-top-12. html
                                        Nomer these are just fantastic and I would like to ask permission to upload all 50 to the Picassa web site I used for my renderings in a folder "Renderings by Others" and give credit to each (and the link as well). Is this OK?
                                        Good work everyone.
                                        Skp 7 Pro & 8
                                        • N Offline
                                          nomeradona
                                          Good work everyone.
                                          sure do it. we owe also these thing from you.
                                          • N Offline
                                            nomeradona
                                            Good work everyone.
                                            in honor of you. can you please make one choice. we will name it Author Al Klagge's choice. so please tell me which one you like most.
                                            Nomer
                                            • 2 / 3
