    How to open *.max files?
    12 Posts 4 Posters 13.7k Views 4 Watching
      http://www.cnczone.com/forums/attachment.php?attachmentid=59672&d=1210930947
        I should add that this app is post 2000 so it's a tad old. But very good even if it doesn't work for you here
        • jarynzlesaJ Offline
          jarynzlesa
          thx for replies,
          it is not important right now, but someday it could be.
          I just downloaded some cloth model (here http://cgworkshop.org/forum2/showthread.php?363-Cgw-gear) and I just wanted to try it. it's ok. thx for reply.
          http://www.vizualizaceschodiste.mypage.cz/
          • KrisidiousK Offline
            Krisidious
            I'm fairly certain Max has a trial... install, open, export as .3ds although they may now in the newest installations of Max have SU support, it seemed I remember a express tool for SU being in their online client support pack.
            you may also export as .obj
            you might also try Milkshape
            http://chumbalum.swissquake.ch/
            or Gmax
            turbosquid.com
            (www.turbosquid.com)
            By: Kristoff Rand
            • numbthumbN Offline
              numbthumb
              As was said, download the trial.
              @ krisidious: why would he need Milkshape or Gmax? Neither of them can read .max files AFAIK ๐Ÿ˜•
              Comfortably numb...
                Krisidious
                I was under the impression both of them open 3Dmax files.
                By: Kristoff Rand
                  numbthumb
                  They can, but only Autodesk .3ds files ๐Ÿ˜„
                  And Gmax canยดt even do that without the importer script. Itยดs pretty much a "dead end" app.
                  Comfortably numb...
                    301 Moved Permanently
                    (www.mootools.com)
                    Even though OP is no longer is need of it. I had the trial of this way back. Not a bad tool but to much file association with it. The Polycruncher in this is awesome
                      numbthumb
                      Does that polygon cruncher exist as a standalone app?
                      Comfortably numb...
                        Polygon Cruncher is a plugin for :
                        Polygon Cruncher interface
                        3D Photo Browser
                        Polygon Cruncher is included in 3D Photo Browser package.
                        Lightwave Modeler / Inspire 3D
                        32 and 64 bits : V6.x, V7.x, V8.x, V9.x and more
                        3DS Max / Autodesk VIZ
                        32 bits : V6.x, V7.x, V8.x
                        32 and 64 bits : V9.x, 2008, 2009, 2010, 2011.
                        No, when you register for the trial they give you a 35% discount if you purchase within 24hrs. Then 20% if you purchase within the following 24hrs. It does very good crunching but like all poly-reducers it can cause quite a mess if you go overboard.
                        The strange thing with Polycruncher is that when you launch 3D PhotoBrowser and select the model you want to crunch it then launches a second application for the crunching. Makes you wonder why not just make it standalone?
