    From SketchUp to Reality
    91 Posts 22 Posters 10.1k Views 22 Watching
      billbell52
      Sounds like you are thinking ahead on this. I am not an expert on this. I don't think you need to go crazy on it. However, there are lots of things that can be done that add almost no cost and don't look unsightly. The main ones I did wrong are:
      1. Make closet doors 30" or 36". I have 24" doors that could easily be larger at no real cost difference.
      2. Make hallways wider to make turning around easier. I can turn around today but just barely.
      3. Make switches/controls accessible. I have some pool controls that are hard to reach. I moved water heater from tank in attic to tankless in garage.
      4. Biggest mistake was toilet access. I could easily have added more room and changed layout.
      Other possible items
      1. Plan for grab bar attachment.
      2. Role under bathroom sink
      Things I accidentally did right.
      1. Easy ramp access to front and rear door.
      2. Bedroom is large enough to easily navigate.
      3. Pavestone walkways around house are flat and wide enough.
      I was able to put in a vertical platform lift to get between floors. It is a tight fit but it does work.
      I use to think I would move to a new house when my needs changed. In this market selling a house is difficult. So I am leaning more towards planning ahead. My mother broke her hip a few years ago and came to live with us a few months while she recuperated. My mother-in-law has problems with stairs and she visits from time to time.
      Wishing you the best on your project.
      • Mike LuceyM Offline
        Mike Lucey
        Coming along nicely Dale ๐Ÿ‘
        As regards disabled access goes over here, we have to provide quite a number of considerations as standard. While these items may not make a lot of sense to able body house holders, I remind them that they may appreciate the extra access provisions in time AND that some day they may grow old and be glad of them
          Some of those ideas just make sense even for the able bodied. Wider doors and straight runs into rooms make sense for moving furniture around. I've been in some newer homes that look great but you can't move a couch or a bed in without damaging the walls. What kind of sense does that make? The house we had designed a few years ago (but have yet to build) was, at our request, designed with 36" wide doors and other features that would make the house accessible to wheelchair users but it was more to make the house easier to live in for anyone.
            Mike Lucey
            Just wondering how progress in going? ๐Ÿ˜„
            • daleD Offline
              dale
              Mike, I apologize for the delay in updates, but it has been dawn to dusk, then fall into bed hectic around here for the past month.
              Just a couple more days of madness, and I will do a big update.
              Winter strikes hard and fast here, and I am really pushing to not get caught.
              Thanks so much for your interest.
              • pbacotP Offline
                Well that's plenty of an update. How blessed to be thus engaged. Looking forward to hearing the details.
                • daleD Offline
                  dale
                  The past month has been so hectic, that as I noted previously, I just haven't had the time for proper posting.
                  Aside from managing to get my fascia and roof on, I have been acting as the gopher for the stone mason.
                  Introducing, "he who cannot be named" himself, in "The Chronicles of a full masonry fireplace".Herb.png
                  Don't let those sad eyes fool you, this 73 year old German trained mason is a taskmaster, but master is the operative part of this statement as well.
                  This is the 3rd fireplace he has built for us, and if you have ever had one, they are hard to live without. In the end the 40,000 lb (18,200 kg) monster will keep the entire house warm in the case of power failures.
                  But it has to start somewhere: Judy shoveling in one of the 15 or so truckloads of sand.Judy and the sand.png
                  Starting at the base of the rough in, and following through with the Hearth, which cantilevers into the building.The Base rough in.pngRough in 2.png
                  • daleD Offline
                    dale
                    Continuing on to the fire box, which, if you are familiar with fireplaces, is similar to a Rumford with it's sloping back and sides, but much deeper. This is done to make the smoke shelf more effective. In the real world it means the front of the fireplace doesn't get blackened, as it virtually never smokes unless there is extreme downdraft conditions.Firebox 1.png
                    Notice the firebricks are set with there 9" depth perpendicular to the fire box. It takes more firebricks this way, but is less likely to crack, and way more efficient at maintaining heat.firebox 2.png
                    Apologies over the quality of some photos, as they were quick iphone shots.
                    Then it was putting the flagstone onto the hearth. The hearth is about 18"(45 cm) off the floor. This is so when you sit in front of the fire, you are looking right at it, and the heat is reflecting off those sloped sides and back, right at your body.Hearth flagstone.pngHearth 2.png
                    • daleD Offline
                      dale
                      With the weather holding, we moved outside to take advantage of this.
                      Chimney flue through the roof.
                      He angles the first part of his flues, as he says it causes the smoke to be pulled faster up the chimney.Cimney flue sm.png and reaching above the roof.Chimney above roof.png
                      To be continued.
                      Cheers
                      Dale
                      • daleD Offline
                        dale
                        Next we started the actual stone work with river stone that we had gathered.Start exterior stone.png
                        And continued to the soffit.[attachment=3:2ipzng5w]<!-- ia3 -->ExTerior stone to soffit.png<!-- ia3 -->[/attachment:2ipzng5w]
                        Stone above roof.[attachment=1:2ipzng5w]<!-- ia1 -->Screen shot 2011-10-16 at 7.36.11 AM.png<!-- ia1 -->[/attachment:2ipzng5w][attachment=2:2ipzng5w]<!-- ia2 -->stone above roof.png<!-- ia2 -->[/attachment:2ipzng5w]
                        And pouring the cap.[attachment=0:2ipzng5w]<!-- ia0 -->Screen shot 2011-10-16 at 7.38.12 AM.png<!-- ia0 -->[/attachment:2ipzng5w]
                        • daleD Offline
                          dale
                          Then the interior stone work. This shows the arch form with beginning of stone placement for the arch.arch.png
                            JuanV.Soler
                            German trained mason, a taskmaster,...
                            ...73 year old ๐Ÿ‘
                            you will be fine inside your home in those stormy and cold days Dale ๐Ÿ˜‰
                            • ely862meE Offline
                              ely862me
                              ๐Ÿ‘ WOW
                              Got to say this is really impressive !! I love how clean the work is ! Good luck with finishing it and living in it!
                              How are the outer rocks of the chimney held in place ? I have the impression they are not only held by concrete .
                              Cheers!
                              Elisei (sketchupper)
                              Come and See EliseiDesign
                              • jarynzlesaJ Offline
                                jarynzlesa
                                where is the stonehenge? I don't know, but I know that somebody can create a lot of beautiful things with stones.
                                keep up dale thumb up ๐Ÿ‘ .
                                http://www.vizualizaceschodiste.mypage.cz/
                                • daleD Offline
                                  dale
                                  Juan, Elisel, Jaryn
                                  Thanks for the encouragement.
                                  Amongst the moments of excitement, there are moments when I question my sanity.
                                  But on a piece like this, there is so much personal involvement when you have shovelled the sand and collected the stone, everything has a story.
                                  Anyway, for the final on the fireplace, the exterior stone completed.Screen shot 2011-10-17 at 7.09.47 AM.png
                                  And the first fire, a tribute to the mason and accompanied with a nice glass of red wine.Screen shot 2011-10-17 at 7.12.58 AM.png
                                  • AnssiA Offline
                                    Anssi
                                    In Finland, it has also been customary to have a little "first fire" celebration. Traditionally all the smoke from the fireplace comes in until the master mason has been given his vodka. Then he goes up on the roof and drops a little stone in the chimney to break the thin glass he has placed there.
                                    Good luck to your project
                                    Anssi
                                    • daleD Offline
                                      dale
                                      Anssi
                                      Our mason told us this exact ritual, although apparently the schnapps in Germany had to be accompanied by the monies owing, or the glass remained.
                                      • daleD Offline
                                        dale
                                        We got a spell of great weather at the end of the fireplace construction, so we managed to get the steel roofing on as well.
                                        • daleD Offline
                                          dale
                                          Yesterday was a big day, as with the main floor hydronic pipes in place we poured the upper floor.Screen shot 2011-10-19 at 7.02.38 AM.pngScreen shot 2011-10-19 at 7.02.55 AM.png
                                          • daleD Offline
                                            dale
                                            This house has had its share of wildlife incidents.
                                            On the way back from picking up our plumbing fixtures we saw this wolf on the highway.
                                            Maybe these are good omens.Screen shot 2011-10-19 at 7.11.02 AM.pngScreen shot 2011-10-19 at 7.11.09 AM.png
                                            • 3 / 5
